twin turbo part II - TCCoA Forums
post #1 of 455 (permalink) Old 11-24-2007, 06:32 PM Thread Starter
twin turbo 281's Avatar
twin turbo part II
it runs
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #2 of 455 (permalink) Old 11-24-2007, 09:40 PM
Tx_Cat's Avatar
I have the same welder dude.... I love that welder....
Is there a way you could move your pipes a tid bit higher?! I have the same clearence problems though...
Tx_Cat is offline
post #3 of 455 (permalink) Old 11-24-2007, 09:45 PM Thread Starter
skip ahead
post #4 of 455 (permalink) Old 11-24-2007, 09:47 PM
Tx_Cat's Avatar
Oooohhh...... Mine isnt lowered and I still think my pipes are not tucked in as much as I wanted.... Looks good. What's the tank use for?!?
Tx_Cat is offline
post #5 of 455 (permalink) Old 11-24-2007, 09:53 PM Thread Starter
skip ahead
post #6 of 455 (permalink) Old 11-24-2007, 10:00 PM
Tx_Cat's Avatar
Isn't the tank to big dude?!?! You need like a smaller tank...
Tx_Cat is offline
post #7 of 455 (permalink) Old 11-24-2007, 10:06 PM Thread Starter
skip ahead
post #8 of 455 (permalink) Old 11-25-2007, 07:08 AM
BLittle500's Avatar
This may sound dumb, and I may be missing it in the pics, but is there going to be a break in the exhaust twards the back so you can still drop it out of the way if need be? But looking closer your pipes never connect by the way it looks so I guess you could just unbolt from the manifolds/headers, and unbolt from the turbos, and drop out the whole long tube. Just a thought I had.
Sweet pics though, I hope everything works out for you, gonna be one bad ass ride!
Brandon
BLittle500
2008 Racing Shirts Are In!!!
1995 Ford Thunderbird LX 4.6L (Race Car)
1994 Ford Thunderbird LX 4.6L (2009 Race Car)
2003 Ford F-250 Superduty 5.4L (Daily Driver) FOR SALE
2004 Honda CBR600RR uhhh 0.6L (Sh!ts & Giggles)
1995 LX Dirt Oval Race Car
BLittle500 is offline
post #9 of 455 (permalink) Old 11-25-2007, 01:02 PM Thread Starter
skip ahead
post #10 of 455 (permalink) Old 11-25-2007, 11:39 PM
fordmuscle's Avatar
thats awesome, I wonder what the turbos will sound like from inside the car, with them being in the trunk. That should be pretty cool. Nice work man.
'77 F-350 460ci- Daily Driver
''94 T-Bird LX 4.6L SOHC
Mostly stock w/ 189,000 mi., but not for long. Soon to be a nitrous breathing 4000 lb. IRS terror.
fordmuscle is offline
post #11 of 455 (permalink) Old 11-26-2007, 12:23 AM
The Great Obucina's Avatar
havent you compromised the rigidity of the unibody by eliminating that section of the trunk? why dont you have filtration for the turbo oiling? how do you plan on tuning this thing properly? and with all due respect, why did you "gut" the car just to lay claim on "twin turbos"?
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 455 (permalink) Old 11-26-2007, 12:49 AM Thread Starter
skip ahead
post #13 of 455 (permalink) Old 11-26-2007, 08:47 AM
wildturkey's Avatar
man, it might get warm in that trunk.
wildturkey is offline
post #14 of 455 (permalink) Old 11-26-2007, 01:03 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
Originally Posted by twin turbo 281 View Post
I don't believe i have weakened the uni body one bit. I only cut small very thin section of the bottom of the spare tire well. I plan to dyno tune and i still need a lot of gadgets like a wide ban and a egt monitor, and so on. I will have an in line filter with the oiling system on the pressure side after the pump and if later necessary a cooler.
I can't wait to hear the sound...whats more is the sound from the rear of the car since the compressors face the factory back up light holes.
Wouldn't it make more sense to have the filter before the pump so the pump receives filtered oil too?
I'll give you credit for the work your doing to get this done; but I wouldn't ever go the same route as you did on my car. I've become attached to my interior over the years.
Also, how were you planning on running the cold side back to the front? Through the interior, underneath, etc?
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #15 of 455 (permalink) Old 11-26-2007, 01:14 PM Thread Starter
skip ahead
post #16 of 455 (permalink) Old 11-26-2007, 01:18 PM
I think there are all sorts of ways that trunk-mounted turbos could be dangerous. At the least, I would put in some sort of metal bulkhead. Perhaps a fire extinguisher system would be a good idea too.
Steve
S_Mazza is offline
post #17 of 455 (permalink) Old 11-26-2007, 01:56 PM
Mark M. TCCoA VP's Avatar
You could setup an emergency Halon Fire suppression system in the trunk. That would be cool.
You will need vents anyway since you will be pulling air with the turbos and you won't need a fan as you will already have two air pumps
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #18 of 455 (permalink) Old 11-26-2007, 11:19 PM
holy crap, last time i sa this car they were tucked under where the back seat was lol. what a change...but still looks bad a$$.
how far off do you think you are from firing it up?
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #19 of 455 (permalink) Old 11-27-2007, 04:56 AM Thread Starter
skip ahead
post #20 of 455 (permalink) Old 11-27-2007, 08:50 AM
man that thing's janky. you better make it fast as hell to shut everybody up, otherwise you'll never hear the end of it. It will sound awesome though.
marvintpa is offline
post #21 of 455 (permalink) Old 11-27-2007, 02:19 PM
All I can say is .... wow ....
Gotta give you credit for not letting little things like comfort and safety get in the way of a good idea ....
I'm not criticizing or judging what your doing,
But I had an experience with GB that woke me up to the need for clear thinking about safety in a high powered, modified car. Actually I had two experiences:
One was at the track, the first time I jammed the accelerator pedal and the car went sideways, I got off it, she upshifted to 2nd, I got back on it and she headed sideways for the other lane again - I saw how easily and fast bad stuff can happen.
The other experience was while I was test driving GB on the street. It had to do with a loose injector "O" ring, and gasoline spraying out of the fuel rail. Nothing caught fire, but it easily could have been a huge disaster.
Shtuff happens to modified race cars, it happens often, and it happens fast ...
so if it were me, I'd want a solid partition between me and those turbos, and the hot oil running around back there. If something lets go at 25,000 rpm or higher, I wouldn't want to be in the way, or have whatever is flying around loose escape, possibly rupture a fuel cell and expose the gas to superheated, compressed air, or just fly and hit me, or someone else. I also would not want to risk the escape of any exhaust into the cabin.
And all this talk about "sounding cool"... I suspect that the high pitched whine of a turbo in an enclosed cabin with nothing between the turbos and your ears will have a detrimental effect on your hearing. I suggest some really good earplugs, like the kind we used on the airfield when I worked for Continental.
I know, I'm an old phart, and don't heal as easily as I used to, so I don't want to take the risks you youngsters take...
but that's just me ...
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #22 of 455 (permalink) Old 11-27-2007, 03:00 PM Thread Starter
skip ahead
post #23 of 455 (permalink) Old 11-27-2007, 05:04 PM
Ok, now that you have spelled out that you are going to take some precautions, I think a lot of people will breathe easier. Before, it wasn't really clear how you were going to leave the thing set up.
Steve
S_Mazza is offline
post #24 of 455 (permalink) Old 12-08-2007, 06:17 PM Thread Starter
skip ahead
post #25 of 455 (permalink) Old 12-08-2007, 07:26 PM
954.6tbird's Avatar
cool set up!
im just wondering how are you getting oil out of the tank?
do you have some sorta oil pump inside the tank?
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
post #26 of 455 (permalink) Old 12-08-2007, 07:36 PM Thread Starter
skip ahead
post #27 of 455 (permalink) Old 12-10-2007, 01:55 PM
more power to ya
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #28 of 455 (permalink) Old 12-14-2007, 11:41 PM Thread Starter
skip ahead
post #29 of 455 (permalink) Old 12-30-2007, 05:35 PM
seawalkersee's Avatar
Any updates on this? Im liking the way this is looking.
Chris
seawalkersee is offline
post #30 of 455 (permalink) Old 12-30-2007, 09:55 PM Thread Starter
skip ahead
