What Turbo - TCCoA Forums
post #1 of 44 (permalink) Old 12-18-2007, 03:26 PM Thread Starter
T-BIRD 90's Avatar
What Turbo
Hey i was wondering about turbo i have done a little seaching and was swondering what turbo to use,some of the posts said they used a volvo/saab turbo,is that just any volvo/saab turbo
T-BIRD 90 is offline
post #2 of 44 (permalink) Old 12-18-2007, 03:59 PM
twin turbo 281's Avatar
single or twin turbo setup? Is this for your 4.6? What kind of power are you wanting to put down? Traditional under hood setup or is this going to be remote mounted? Are you looking for lower range torque or high revving HP>? These are just some of the questions you need to think about.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #3 of 44 (permalink) Old 12-18-2007, 04:16 PM Thread Starter
T-BIRD 90's Avatar
well i've got 200k on my motor,so low psi maybe 4-5,and i found a volvo turbo for $200,and just a little power,and remote turbo i guess,how much power do you think it would give me
post #4 of 44 (permalink) Old 12-18-2007, 04:21 PM
what kind of turbo is it? I'm just guessing its some kind of garret T3. Look for all the stamped markings on the turbo. There should be a .AR number on the turbine housing (exhaust side) and compressor housing (cold side) That will tell you a little more and also If you know the exact motor it came off of? Most likey its going to be too small just on its own unless you find a twin.
post #5 of 44 (permalink) Old 12-18-2007, 04:36 PM Thread Starter
T-BIRD 90's Avatar
how much did it cost you to do a twin setup,if you don't mind the question
post #6 of 44 (permalink) Old 12-18-2007, 04:47 PM
TCCoA Founder
Sir William's Avatar
Before you undertake something like this, there are some things you'll need to know how to do. Can you cut and weld exhaust tubing? Can you handle lubricating it? Can you handle the added fuel needs? How much thought have you put into all this before you jump in? It's not an easy task....believe me, I know.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #7 of 44 (permalink) Old 12-18-2007, 05:23 PM Thread Starter
T-BIRD 90's Avatar
how much will a turbo drop your fuel milage
post #8 of 44 (permalink) Old 12-18-2007, 05:34 PM
TCCoA Founder
None.
Sir William
TCCoA Founder
post #9 of 44 (permalink) Old 12-18-2007, 05:39 PM Thread Starter
T-BIRD 90's Avatar
oh well what did you man by added fuel needs?
post #10 of 44 (permalink) Old 12-18-2007, 07:46 PM Thread Starter
T-BIRD 90's Avatar
what kinda turbo do you use for a single setup
post #11 of 44 (permalink) Old 12-18-2007, 09:37 PM
Chapter Director Coordinator
jamesD's Avatar
forcing more air down the gullet leans the mixture, you have to offset it by allowing more fuel in... ie, bigger pump and injectors
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #12 of 44 (permalink) Old 12-18-2007, 09:43 PM Thread Starter
T-BIRD 90's Avatar
would that be a problem just running 4-5 pis,or would i still have to upgrade
post #13 of 44 (permalink) Old 12-19-2007, 01:32 PM
David Neibert's Avatar
If you have a 200K mile motor in the car....you don't really want to be messing with a turbo. It's not worth all the effort for a lousy 4 or 5 pounds of boost.
David
David Neibert is offline
post #14 of 44 (permalink) Old 12-19-2007, 03:54 PM Thread Starter
T-BIRD 90's Avatar
i think it would be the coolest way to get,maybe 50-60 hp,an i though i saw on a thread that iron is better for forced induction,im not completely sure but i could do a pi head swap and have a decent engine .............i could have just said all those things that were wrong so,please correct me,but i like the idea of a turbo,even if just 4-5 psi,....oh and thanks for your input,any more will help
post #15 of 44 (permalink) Old 12-19-2007, 04:49 PM
Suggest going to turbomustangs.com and read up on what is involved to make the turbo system work. They have a good do it yourself forum that will also be helpful.
David
post #16 of 44 (permalink) Old 12-19-2007, 09:31 PM Thread Starter
T-BIRD 90's Avatar
thanks i will go there now
post #17 of 44 (permalink) Old 12-19-2007, 10:03 PM Thread Starter
T-BIRD 90's Avatar
i still don't know what size i can use what about this one
http://cgi.ebay.com/ebaymotors/SUPER...QQcmdZViewItem
post #18 of 44 (permalink) Old 12-19-2007, 10:39 PM
PostSkank
StupidFly's Avatar
You might want to go out and do some general turbo research, learn about compressor and turbine sizing etc, before you go shopping for turbos. That's how I'd approach it anyway.
math > pasta
StupidFly is offline
post #19 of 44 (permalink) Old 12-19-2007, 11:22 PM Thread Starter
T-BIRD 90's Avatar
so what i read is that a to big of a turbo will take a long time to spool up(turbo lag),and to small of a turbo will no put enough psi.....is that right
post #20 of 44 (permalink) Old 12-19-2007, 11:25 PM
jamesD's Avatar
in a general sense of the whole thing. yes.
jamesD is offline
post #21 of 44 (permalink) Old 12-19-2007, 11:35 PM Thread Starter
T-BIRD 90's Avatar
i read a little on the turbomustang page an i kinda got a sense of it,so on of those small turbo(unless it had a twin )would be kinda useless so would a t3/t4 work or is that a small turbo
P.S. i know my questions are a little stupid to you guy,but hey,im learning...thanks a bunch
post #22 of 44 (permalink) Old 12-20-2007, 03:34 PM
Tx_Cat's Avatar
Took me more than 1 year of research, I wanted to be informed before I started to drop loads of money to the cougar. You have to learn force induction before you make a decision to turbo your car. It's not as simple as it looks. Ive been working on my TT Cougar for 1 year now and still haven't finished it.
You have to read more before you start spending money like crazy.
Tx_Cat is offline
post #23 of 44 (permalink) Old 12-20-2007, 05:27 PM
Mark M. TCCoA VP's Avatar
For 50 or 60hp just use a small shot of nitrous and be done with it.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #24 of 44 (permalink) Old 12-21-2007, 04:55 AM
Generally on a rear mount turbo you want a smaller .AR on the exhaust side than a traditional front mount setup. That turbo on ebay that you linked is most likely a junk Chinese turbo that may come apart. If you want to stay on a budget either go with a junkyard turbo(s) or check out master power turbos (Brazilian garret knock offs) They have good quality turbos that won't empty your pocket. For a rear mount you will need a scavenge pump to return the oil back to the motor. If you don't know how to fabricate expect to spend $$$$ at least 4-6K on even a mild setup.
post #25 of 44 (permalink) Old 12-21-2007, 05:03 AM
oh and my project is still in construction at almost 2 years now and the bill is still climbing. I belive I have spent about 700 so far but i still have tuning gear, fuel system and so on. That 700 is on a junkyard DIY project that isnt even done yet and Ive done all the work so far.
post #26 of 44 (permalink) Old 12-21-2007, 08:32 PM
fordmuscle's Avatar
I have 190, 000 mi on my 4.6 bird, and was gonna do a single remote mount setup too, running just 4-5 psi. I have a Borg-Warner GM-5 turbo, from a Chevy diesel that I was gonna use. But after researching, and doing a cost/work estimate, I decided I'm gonna sell the turbo, and buy some cheap nitrous. Easy to install, 50-75 horses.
Good Luck!
'77 F-350 460ci- Daily Driver
''94 T-Bird LX 4.6L SOHC
Mostly stock w/ 189,000 mi., but not for long. Soon to be a nitrous breathing 4000 lb. IRS terror.
fordmuscle is offline
post #27 of 44 (permalink) Old 12-21-2007, 09:26 PM Thread Starter
T-BIRD 90's Avatar
well $700 aint that bad,but you have bill to pay,i understand,but i haven't got much money at all,oh and what welder do you think would be a good one(for the future im no jumping in to this right away,im just gathering info).and thanks
p.s. i think nitrous is cheating,its for tuners who need it
post #28 of 44 (permalink) Old 12-21-2007, 09:41 PM Thread Starter
T-BIRD 90's Avatar
post #29 of 44 (permalink) Old 12-21-2007, 10:02 PM
PostSkank
StupidFly's Avatar
Tuners who need what? Another 60-70 hp? sound familiar?
math > pasta
post #30 of 44 (permalink) Old 12-21-2007, 10:10 PM Thread Starter
T-BIRD 90's Avatar
who need nos to keep up,just talkin bs there,just talkin smack about tuners
