true deals and turbo charging? - TCCoA Forums
post #1 of 21 (permalink) Old 04-22-2008, 08:08 AM Thread Starter
punkrokr1701's Avatar
Send a message via AIM to punkrokr1701 Send a message via MSN to punkrokr1701 Send a message via Yahoo to punkrokr1701
I want to run true duels all the way to the tip as my exhaust system so won't I need to run two smaller twin turbos rather than a single large turbo? just some of the thoughts floating around my head for the future
98% of teens have turned to rap; if your one of the 2% who still listen to "real" music copy this
punkrokr1701 is offline
post #2 of 21 (permalink) Old 04-22-2008, 08:14 AM Thread Starter
yeh im pretty sure that's a dumb question and i think i already know the answer just to be sure I'll ask though haha
post #3 of 21 (permalink) Old 04-22-2008, 08:35 AM
97Cat's Avatar
If you would like all 8 cyls exhaust to power the exhaust turbine on a single turbo, than no, you won't be able to have a true dual engine back setup because in a typical setup you would have to couple the exhaust coming from the block first so that it can enter the exhaust side of the turbo, and then exit the turbine into the exhaust and be split from their.
On a dual turbo setup, you can run each turbo separately and then couple the compressed air either before the FMIC, or get an FMIC that has two entrances and one exit that than delivers the ambient temp compressed air into the TB, unless you have a car that is running twin or multiple throttle bodies, which your 95 tbird does not. With this setup, you can run a true dual engine back exhaust system, although it sort of loses the meaning once you are running boost.
Hyundai Tiburon GT, 2.7l V6:
Ark DT-S dual exhaust, headers, Injen SRI, TWM short throw shifter, TWM weighted shift knob, drilled/slotted rotors, DC front and rear STBs, 6000K HIDs, SAFC 2, Tuscani Badging, Espelir Springs, ark black shorty antenna, 5Zigen FN01r-C wheels, full urethane motor mounts, NGK Iridium, 8.5 magnecore wires, NGM Sniper supercharger MP62, APE traction bars...
Mercury Cougar XR-7, 3.8l V6:
nothing, that's why I'm here...
97Cat is offline
post #4 of 21 (permalink) Old 04-22-2008, 08:47 AM Thread Starter
yeh I kinda of knew that just needed reassurance lol, btw I planning on using a Mark VIII engine which has a twin TB so I need not worry about that, Yeh if i ever run torbos which I plan too some where down the road I definitely need a twin turbo set up not only b/c I want to run dual exhaust but I need my power in the lower rpm band b/c the Mark DOHC engine makes most of it's power up top and doesn't really have lower end power and so smaller twins is my path, but first, i have an engine to rebuild, just needed to get the basics down which I have now, thanks
post #5 of 21 (permalink) Old 04-22-2008, 08:49 AM
97Cat's Avatar
also, what is your goal? Do you just want to have a true dual engine back exhaust just so you can say you have one, or for more power? Same question for either a single turbo or a twin turbo setup, what are your goals? Most people run a twin turbo not because it produces more power, but a) to say they have one, or b) to deliver power more efficiently and reduce turbo lag by having one turbo set up to run boost quicker and the other to turbo offset to deliver power higher up in the powerband. With the twin turbo setup, MOST of the times, you will not have a dyno queen, but you will probably have a very nice powerband. With a single monster turbo setup, especially on a v8, you will have more lag, especially since the exhaust has to travel further before any boost is created, but the end result is a more efficient larger turbo that will create a crazy amount of top end whp b/c you have 8 cyls powering a turbine instead of 4.
97Cat is offline
post #6 of 21 (permalink) Old 04-22-2008, 08:55 AM
97Cat's Avatar
twin throttle bodies huh? Definitely makes running a twin turbo setup sound more interesting.
97Cat is offline
post #7 of 21 (permalink) Old 04-22-2008, 09:15 AM
TCCoA Founder
Sir William's Avatar
NO production Mark VIII ever had twin throttle bodies. Period.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #8 of 21 (permalink) Old 04-22-2008, 09:25 AM
97Cat's Avatar
good to know.
97Cat is offline
post #9 of 21 (permalink) Old 04-22-2008, 09:36 AM Thread Starter
well I'm sorry thats what I was told, I haven't bothered looking at my engine yet b/c I'm still organizing my tools, lol i'll go look when i get off, and ijust realized i put true"deals" in my heading which is supposed to be true duals, lol my bad, lotta stuff i gotta do today.
post #10 of 21 (permalink) Old 04-22-2008, 01:57 PM
David Neibert's Avatar
Most exhaust systems use an X pipe or and H pipe tying the two sides together, which ends up doing pretty much the same thing as running a big single pipe and splitting off to duals just prior to the rear axle. Mine has a single turbo with a 3" downpipe, then it increases to 3.5" just past the starter, and splits off to dual 3" near the rear.
If your serious about doing a turbo some day, then spend some time now educating yourself. A good source of info is turbomustangs.com go there and read for a couple months.
David
David Neibert is offline
post #11 of 21 (permalink) Old 04-22-2008, 03:43 PM
97Cat's Avatar
David
Couldn't agree more, if you really plan on doing a boosted application, get educated first, it'll save you time, money, and frustration later on. I'll be honest, your question today alone means you definitely should do some reading on the subject. Personally, I encourage reading actual tried and true literature so you can tell what is bs out there on forums and who actually knows accurate info to share with you. A must read IMO if you are doing a custom turbo setup is Corky Bell's "Maximum Boost". Here's a pdf file for it:
http://www.sufi.cc/Maximum_boost.pdf
97Cat is offline
post #12 of 21 (permalink) Old 04-22-2008, 04:07 PM
twin turbo 281's Avatar
you have alot of reserach to do. if you want a turbo under the hood do a single kit it will cost less and be easier to setup. and yes you can have dual exhaust with a single turbo
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #13 of 21 (permalink) Old 04-22-2008, 04:24 PM
97Cat's Avatar
plus a single turbo would be easier to tune than a twin turbo setup, if he's going sequential.
but if I'm understanding his question accurately, he was wondering if you can have a true dual, or engine back dual exhaust, which he wouldn't be able to on a single turbo, although, yes, he would be able to split it off into a dual afterwards. Unless you know some secret that I'm unaware of like a twin exhaust turbine turbo or something.
97Cat is offline
post #14 of 21 (permalink) Old 04-22-2008, 10:52 PM
PDL2MDL
krazy4's Avatar
You can have a dual exhaust with a single turbo although there will always be Y pipe with a single turbo.
http://www.youtube.com/watch?v=oMjdto07tuk
LX w/ true duals, cutouts
cone filter
Bird is gone replaced by an LS1.
krazy4 is offline
post #15 of 21 (permalink) Old 04-23-2008, 11:41 PM
Ditto.
There's only one outlet on one turbo.
And THEN there's probably a most important question riding shotgun with this....
just where are you planning to put this turbo(s)? Believe me, I've mapped this idea out a bit. Dodge 2.2 turbos are easy to come by, and given a proportional factory turbo size to displacement, are perfect for a 4.6L if run as a dual setup, in my opinion. (and they're water-cooled to boot. Skip the GM equivilants) Some here have managed to get one or two (possible aftermarket) turbos in there, but I can almost guarantee that it isn't gonna look factory. Either way, you either have metal fab skills to D.I.Y. as much as you can, or a fat checkbook to counter.
Delete my account.
94 Thunderbird XX is offline
post #16 of 21 (permalink) Old 04-24-2008, 05:04 AM
You could fit a single MP70 where the air box is you will also need to delete the ac build custom manifolds and hot side parts. Cold side plumbing, wastegate, intercooling, fuel system upgrades, possibly ignition upgrades and for big power lots more will have to be upgraded it can get spendy
post #17 of 21 (permalink) Old 04-24-2008, 05:52 PM
Tx_Cat's Avatar
Stock ford ignition should work up to 400HP last time I've hear. If you plan on going beyond 500hp, then you do...
One thing though, it's not cheap. So be prepared to spend lots of money...
Tx_Cat is offline
post #18 of 21 (permalink) Old 04-24-2008, 05:55 PM
The Great Obucina's Avatar
I only trust two people in this Turbo thread.....bill and Senor Neibert. Everything else I am hearing is a bunch of useless hodgepodged info without much to back it up.
"Booyah". Stu Scott.
The Great Obucina is offline
post #19 of 21 (permalink) Old 05-03-2008, 05:41 PM
Well, after a little measuring and "dummying up" under the hood, I think it is indeed possible to have two turbos under the hood here. One in the stock battery location (moving the battery to say, the trunk), and one over in the stock airbox location (obviously deleting the whole shebang in lieu of the complete turbo air intake system). Would take some creative fabbing to plumb, but it could cetainly be done. Keep in mind though I'm choosing and using the stock mopar 2.2L Turbo as my own personal dimension guidelines simply because of my familiarity of those, so YMMV for whatever aftermarket setups you may have.
Now, my next thorn here would be heat. You can bet that the paint will blister and peel right off the hood where the turbos are.....might have to get creative with some vents of sorts on the hood over where the turbos are located, keeping the airflow working to exchange the heat while still keeping any rain and wet from dripping down on the hot stuff.
Delete my account.
post #20 of 21 (permalink) Old 05-03-2008, 10:12 PM
i built two front mounted setups with flipped JBAs and the chrysler Tb03s and had one of them running. The chrysler T3s have a .42/.48 ar housings they spool quick. My 4.0 spools one chrysler T3 by just under 2K. You will have to make flanges for the inlet as no aftermarket T3 flange will fit ( they use a special chrysler specific T3 flange)
with this setup below i could still run the radiator just tilted froward at the bottow. as for heat even if there an inch from the hood wrap them in a turbo blanket and they should be fine.
post #21 of 21 (permalink) Old 05-04-2008, 07:28 AM
Banned
Send a message via MSN to rollingthunder4000
tt281 LUVVSSS his turbos, of course in the end don't we all? haha
rollingthunder4000 is offline
