New stainless exhaust on turbo SC - TCCoA Forums
post #1 of 39 (permalink) Old 06-02-2009, 06:23 PM Thread Starter
David Neibert's Avatar
Got this new exhaust system (from the turbo downpipe to the rear bumper) made a couple weeks ago to replace the leaking mild steel exhaust that was done half azz by those jokers at Forced Fab who built the turbo system.
When removing the old exhaust the guy making the stainless stuff noticed that where the old exhaust went from single 3.5" diameter pipe to dual 3", they used a 3" X 3" X 3" Y instead of a 3.5" x dual 3" so it was choked down to 3" at the merge. The new system should be flowing a lot better and the car even feels a little stronger.
David
David Neibert is offline
post #2 of 39 (permalink) Old 06-02-2009, 06:34 PM
Downbylaw's Avatar
I've gotta say, that is a beautiful exhaust. All of those welds look very well done - the guy knows his stuff!
Downbylaw is offline
post #3 of 39 (permalink) Old 06-02-2009, 11:50 PM
Sideoiler's Avatar
Beautiful! So....how much did it cost ya? Gotta go now and wipe the drool off my aged chin.
Sideoiler is offline
post #4 of 39 (permalink) Old 06-03-2009, 04:08 AM
Top quality work, this is gonna make a big difference if your old system sucked.
post #5 of 39 (permalink) Old 06-03-2009, 06:33 AM
Very nice David! I like the way you cut the rear bumper to recess the mufflers and tips to keep everything tucked up under the car nice and clean.
post #6 of 39 (permalink) Old 06-03-2009, 06:49 AM
1995 cougar xr7's Avatar
awesome welds, nice set up, wish mine look like that
1995 cougar xr7 is offline
post #7 of 39 (permalink) Old 06-03-2009, 10:49 AM Thread Starter
Thanks...rear bumper cover wasn't cut, that's how it looks stock on the 89-93 SC.
David
post #8 of 39 (permalink) Old 06-03-2009, 10:55 AM Thread Starter
About $1750. Stainless materials are pricey, but the labor ($65 per hour) for doing all the cutting, tacking, removing, final welding, reinstalling, repeat...over and over is what cost the most. The 3" non chambered stainless mufflers are not included in that price and were reused from the original exhaust.
David
post #9 of 39 (permalink) Old 06-03-2009, 12:48 PM
EvilMooseofDoom's Avatar
You know, not to change the subject here, as the new exhaust system is almost too pretty to use....but the first thing I noticed is that you don't have all of the IRS 'fixes' plastered all over the IRS subframe. Is this in the drag car in your sig?
Yes, I hate my Lincoln. Ask me about it sometime.
My Drivetribe garbage:
https://drivetribe.com/u/ivrqNaWFWj_...SaGpcKvLTz6v9w
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
EvilMooseofDoom is offline
post #10 of 39 (permalink) Old 06-03-2009, 01:55 PM Thread Starter
Yes, it's the same car. It's not really a drag car, because I only take it to the track about once a year just to see what it will do. I don't have a cage or most of the other stuff required for the ET and MPH the car is capable of running. You are also correct about there not being many mods to the suspension or the IRS.
I'm running with stock shocks, springs, halfshafts ect. The Ford trac-loc diff was replaced with an Aburn Pro limited slip diff and stock 3.27 gears were replaced with factory 3.73 gears. All the bearings and seals were replaced and I did install a new set of factory style rubber mounting bushings when the pumpkin was installed.
If using an automatic transmission, the stock stuff holds up to a lot more power than most people think. The non locking converter provides a little more cushion against the type of shock loading that causes the IRS damage. It's only a concern if launching the car off the trans brake with a set of slicks on a sticky track. So far nothing has broken, but the most I've launched with is 6 pounds of boost. No wheel hop, and it tracks very straight when the tires spin....even when smoking the tires from a 70 mph roll
With all the changes I've made to the car in the past 9 months, it's much quicker than the numbers in my signature indicate. I'm 98% certian that it will run high 10s as driven on the street with 14.5 pounds of boost, and if nothing breaks ...high 9s with 23 pounds and race gas.
David
post #11 of 39 (permalink) Old 06-03-2009, 05:03 PM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
holy balls thats freakin awesome!
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #12 of 39 (permalink) Old 06-03-2009, 05:48 PM
David
Roger that. I don't have plans to install a 5-speed in my car, but I was curious as to how much 'abuse' the IRS can handle. I also am going to run a non-locking AOD convertor, but I don't plan on having anything that radical under the hood. Thanks for the information, sir.
post #13 of 39 (permalink) Old 06-03-2009, 06:46 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
Very nice! I bet it really makes you grin if it runs as good as it looks!
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #14 of 39 (permalink) Old 06-03-2009, 08:34 PM
VicRattlehead's Avatar
Are you bringing this one or the other one to Joliet?
CMP Drag Racing
VicRattlehead is offline
post #15 of 39 (permalink) Old 06-04-2009, 02:46 AM
This is the fastest semi stock appearing SC around.
post #16 of 39 (permalink) Old 06-04-2009, 12:56 PM Thread Starter
Keith,
If I can't get the engine cooling issues resolved on the new 4.3 motor that was recently installed in my 91 SC, then yes I'll be bringing this car to race in the same class.
Since it's not track legal for anything quicker than 11.5, I'll just use a set of the MT drag radials I've got mounted on Cobra Rs instead of lugging the Bogarts and real race tires.
David
post #17 of 39 (permalink) Old 06-04-2009, 01:03 PM
very nice work David.
Have you got a sound clip yet?
post #18 of 39 (permalink) Old 06-04-2009, 01:05 PM Thread Starter
It actually runs a lot better than it looks, and yes very big grin everytime I drive it. BTW, I drove it to work this morning.
Here's a picture of the exterior....it looks like your average 14 second SC.
David
post #19 of 39 (permalink) Old 06-04-2009, 01:08 PM Thread Starter
Nope....One of these days I'll learn how to upload a video to youtube.
David
post #20 of 39 (permalink) Old 06-04-2009, 01:12 PM
David
Take a vid, e-mail it to me, I'll host it for you.
if that doesn't work, we can try something else.....if you're interested.
post #21 of 39 (permalink) Old 06-04-2009, 03:40 PM
Send a message via AIM to Kleckner
Wow. Very nice fitment and welding there.
Kleckner is offline
post #22 of 39 (permalink) Old 06-04-2009, 05:31 PM
Great.....another thing to try to keep clean and shiny.
Badass all the way!
Delete my account.
94 Thunderbird XX is offline
post #23 of 39 (permalink) Old 08-25-2009, 01:07 PM Thread Starter
David
Just to follow up on this prediction. I brought the car to Joilet last month and raced in the NMRA true street class. Since I was only legal to run 11.50 I didn't try making a full pass until the 3rd run after the street cruise. In full street trim weight (aprox 4250 lbs) with a hot motor on 275-40-17 MT ET steet radials it ran 10.82 @ 130 mph. Would have went a little faster, but ran out of rpms and was on the rev limiter about 150 ft before the finish line.
Here are a few pictures Keith (aka Vic Rattlehead) took.
http://www.sccoa.com/forums/attachme...8&d=1248800221
http://www.sccoa.com/forums/attachme...5&d=1248800553
http://www.sccoa.com/forums/attachme...1&d=1248800221
http://www.sccoa.com/forums/attachme...0&d=1248800221
This was with about 15.5-16.0 pounds of boost. Looking forward to seeing what it will do with the Bogart wheels, larger diameter slicks and skinnys with about 24 pounds of boost.
David
post #24 of 39 (permalink) Old 08-25-2009, 01:58 PM
car looks good.
and I would really like to know what it runs, once the wick is turned up!
post #25 of 39 (permalink) Old 08-25-2009, 02:00 PM
Scottie6.0's Avatar
Wow!!
Lools Like Mine w/ the 3inch..
But I Ran It Single Out The Back
MISSILE DRIFTER
WeldedDiff-JetPerformanceChip-K&N/Intake-IntraxDropSprings-KYBGR2RearShocks-Single Exhaust-WireSet/Plugs-Gutted-n' Driftable..
""SOON TO BE T-45 5-SPEED"" What Drive Shaft, Shifter,Motor Mod, Tune n' Other Stuff Do I Need!? ""Plz PM..""
driftstl.com
Scottie6.0 is offline
post #26 of 39 (permalink) Old 08-25-2009, 02:05 PM
How in the heck are you keeping head gaskets in it?
BYE2YOU
growing old is inevitable
growing up is optional
94 SC
05 PT Cruiser GT Turbo Convert
Ken Horner is offline
post #27 of 39 (permalink) Old 08-25-2009, 02:05 PM
he welded the heads to the block..
post #28 of 39 (permalink) Old 08-25-2009, 02:08 PM
Scottie6.0's Avatar
There Arnt Any Left..
Hahahahaha!!
MISSILE DRIFTER
driftstl.com
post #29 of 39 (permalink) Old 08-25-2009, 02:08 PM
Scottie6.0's Avatar
David..
You Should Come Drift At MM Sometime..
MISSILE DRIFTER
driftstl.com
post #30 of 39 (permalink) Old 08-25-2009, 04:46 PM Thread Starter
I've got a Dart block, modified AFR205 heads with 1/2" APR studs, Cometic MLS gaskets, and couple coats of copper spray on the block side torqued to 110 ft lb. But what really keeps the heads on, is the Fast XFI standalone engine managment and a very conservative tune.
David
