Tt 5.0 - TCCoA Forums
post #1 of 9 (permalink) Old 12-13-2009, 09:56 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
Tt 5.0
Well after doing alot of posting in ironworker's thread i thought i should start my own. So without delay here are some pictures and such.
Here are the turbos. They are kkk k26 turbos. They belong to Porsche 924 at one point in time.
Now we have the header work. What i plan to do is run whats left of the tube right up to the turbo. The newest piece of piping should run right next to exhaust port for #1 cylinder.
This is just a position i was considering for the hot side. I like this but in the second picture it seems like it will give me alittle more room to work with the mass air and cold side piping.
Last we have both turbos sitting in there respective locations and hot side orientation will probably stay unless someone has a better idea. Im open to all options here. This is my first turbo build after all.
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #2 of 9 (permalink) Old 12-14-2009, 01:39 PM
ironworker's Avatar
the one im doing is mine allso.. u copyed my idea lol it will work its going to be tight like mine but it will work
ironworker is offline
post #3 of 9 (permalink) Old 12-14-2009, 04:30 PM
Please get rid of those factory manifolds. They are a major restriction, and with all the time and money you will be putting into this build, at least get some mustang shorties and cut them up. Otherwise those manifolds will definitely be holding you back.
post #4 of 9 (permalink) Old 12-14-2009, 04:39 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Mike you think the factory manifolds will hold it back that much? I thought they would be plenty good to spin the smaller turbos. Also where would be the best placement for the o2's? Before or after the turbos?
Zero
ZeroRain is offline
post #5 of 9 (permalink) Old 12-14-2009, 05:42 PM
I definitely think they will hold you back. Just look at how small those ports are, and then they constrict even more to get around the bolts. You can pick up a set of cheap aftermarket mustang 1-5/8 shorties for under $100. If it were me, I would buy those now, and since you are flipping them and cutting them up anyway, you can easily deal with any fitment issues that may come up, and this way you'll be good to go for whatever you want to throw at it, and you won't have to re-fabricate anything down the road.
post #6 of 9 (permalink) Old 12-14-2009, 06:11 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Hmm didnt even look at it that way. See this is why i post here. lol. Ill start looking for a set of them then before i go any further with my build. Know anyone with a decent set?
Zero
ZeroRain is offline
post #7 of 9 (permalink) Old 12-14-2009, 06:37 PM
PostSkank
StupidFly's Avatar
Zero
Find something with thick flanges, and thick primaries... just look for thick. You might be able to find something used locally. Check craigslist and the papers. SOMEBODY has an old set of 5.0 mustang headers near you.
math > pasta
StupidFly is offline
post #8 of 9 (permalink) Old 12-14-2009, 09:27 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
I actually think i found a set of shortys here localy for 30. Guy should be sending me an email shortly!
Zero
ZeroRain is offline
post #9 of 9 (permalink) Old 01-16-2010, 09:23 AM Thread Starter
5oh Transformer
ZeroRain's Avatar
Well the guy with the shortys fell thru. Still looking for some and im also going to need a new cold side for one of my KKK's. It has a crack in it but the guy i got them from says he has another unit with a broken shaft.
Zero
ZeroRain is offline
