Pros and Cons of rear-mounted turbochargers? - TCCoA Forums
post #1 of 30 (permalink) Old 12-15-2009, 04:34 PM Thread Starter
EvilMooseofDoom's Avatar
Hello, gang.
I'm curious about the pros and cons of some of the rear-mount (behind the rear axle) turbocharger systems I've seen pop up for sale recently. Other than a possible lag problem from having the air charge be routed through 10+ feet of tubing, and then the possible heat energy loss of not having the turbo as close as possible to the exhaust manifolds....does anyone here have some idea as to how effective they are, in comparison to traditional setups?
Thanks a bunch. I don't plan on using such a system, but I have a customer who wants to install such a unit on his 2006 Mustang GT....
Yes, I hate my Lincoln. Ask me about it sometime.
My Drivetribe garbage:
https://drivetribe.com/u/ivrqNaWFWj_...SaGpcKvLTz6v9w
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
EvilMooseofDoom is offline
post #2 of 30 (permalink) Old 12-15-2009, 05:19 PM
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
I know a couple people who run them. They are surprising in the fact that lag isnt nearly as bad as you would think.
You can get some info on them here.
http://www.ststurbo.com/
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
post #3 of 30 (permalink) Old 12-15-2009, 08:25 PM
cons more pipe...more wieght, more chances for leaks, hot side and cold side, longer oil feeds, etc... otherwise none that I'm aware of. They run cooler remote mounted due to the longer pipe.
post #4 of 30 (permalink) Old 12-15-2009, 08:26 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
Sir William if im not mistaken has a rear mounted setup on his ride.
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #5 of 30 (permalink) Old 12-15-2009, 09:48 PM
Buckcreekbilly's Avatar
I talked to the boys at STS when i was looking at my options. They told me rear mounted or mounted in place of the third cat works well on the tbirds.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #6 of 30 (permalink) Old 12-15-2009, 09:49 PM
R8D-XXX's Avatar
Cons: It can suck water up in the filter on a rainy day. I think you can cover the filter but the possibility is still there.
Oh yeah, someone could steal your turbo....LOL
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #7 of 30 (permalink) Old 12-15-2009, 09:59 PM
One con I that keeps coming to my mind is that it's more exposed to the elements. A puddle splashing up on a hot turbine housing just might really wreck the day. Maybe they aren't quite as exposed as what I'm picturing though.
Delete my account.
94 Thunderbird XX is offline
post #8 of 30 (permalink) Old 12-15-2009, 10:10 PM
I asked STS about that and they claim they've never seen that happen yet, but they sell em, so not sure if that's a fact or a sales pitch.
post #9 of 30 (permalink) Old 12-16-2009, 12:40 AM
twin turbo 281's Avatar
unless you submerge the entire turbine housing under water a little bit of water splashing shouldn't hurt it as thousands have ran remote mount setups with great sucsess. One con I can think of is relying on an oil pump to return the oil and the STS pumps are expensive. You can use a turbowerx shurflow pump and they work great. For some cars its a great solution but for a 06 mustang that has available conventional kits for it I would go with that.
http://www.moddedmustangs.com/turbon...stang-gts.html
http://www.hellionpowersystems.com/i...article&id=139
The cost for a Hellion system is about the same for a STS kit it not cheaper.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #10 of 30 (permalink) Old 12-16-2009, 10:54 AM
TCCoA Founder
Sir William's Avatar
The water splashing on the turbine isn't a big deal as the max temps the turbo housing will see is only about 650-750....not the 1200+ that you see up near the block. I did get some issues with water as on the Bird, the ONLY place to mount the turbo is behind one tire or the other....unless you move the fuel tank or cut out the spare tire well. To combat that, I added a 90 degree elbow and am mounting the filter in the rear of the trunk. This will keep it clean and dry.
The loss of energy in the exhaust isn't a big deal as you run smaller turbine than you'd normally run if the turbo were further forward....so it's able to spool on less total exhaust flow.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #11 of 30 (permalink) Old 12-16-2009, 12:44 PM
R8D-XXX's Avatar
Would you mind providing a little bit more detail about your setup? What size turbo, how much boost, what was your HP gain, ect....?
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #12 of 30 (permalink) Old 12-16-2009, 03:57 PM
Ahh...that does make sense now.
Delete my account.
post #13 of 30 (permalink) Old 12-16-2009, 07:27 PM
TCCoA Founder
I'm trying to find the turbo specs, but they're on a different PC me thinks.
I ran about 5lbs of boost. I didn't get it on a dyno or to the track once it was dialed in, but I can tell you that it would pull against Tony Cerno's Super Coupe on the highway in 2nd and 3rd. That car was dynoed at 330hp, so you can get a pretty good idea on it. I was running PI intake and cams along with 30lb/hr injectors at that point.
Sir William
TCCoA Founder
post #14 of 30 (permalink) Old 12-16-2009, 07:52 PM
R8D-XXX's Avatar
sweet, sounds like it ran pretty good. I've kinda been flirting with this idea also. I've already got 2.5" dual exhaust to make a run back and forth from the turbo if I put one on....LOL
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #15 of 30 (permalink) Old 12-18-2009, 06:41 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Thats a good idea! It would be very unlikely to suck in water, which would be my biggest fear. Being able to use a trunk-mounted intake would be a plus of running a rear turbo setup. I am kinda thinking of doing something with this, but I know very little about boosting things.
-Rob
-Rob
Rob is offline
post #16 of 30 (permalink) Old 12-18-2009, 09:06 PM
Here's the link to show some diffrent installs...........http://www.ststurbo.com/uni_installation
post #17 of 30 (permalink) Old 12-20-2009, 09:31 PM
Black_Cat's Avatar
The biggest con is that they can easily be cut off of your exhaust in 5 minutes with a saws-all while your in your local Wal-Mart.....No thanks, I'll take something safe under my hood
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #18 of 30 (permalink) Old 12-28-2009, 12:55 PM
cougar_fan's Avatar
I've always been intrigued by the STS kits. When I was looking to buy my C5 Vette, I was seriously considering this route, but I never went that way. I'll tell you a good person to talk to about this (and not to take away from the vast knowledge of other members on this site) is ssrogers. He is a really good freind of mine and is vastly knowledgable. He may be a newbie, but the boy knows his stuff. Give him a PM and I am sure he would be happy to lend an opinion, but be prepared for a novel in terms of the explination.
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/forumdisplay.php?f=95
cougar_fan is offline
post #19 of 30 (permalink) Old 01-01-2010, 04:36 AM
HGainiac's Avatar
Great... I'd forgotten that... I've been thinking about a turbo 'specially after seeing the results around here, but you just reminded me there was a rash of a$$#@les around here a while back doing just that... then again they were cutting cats for the precious metals as well... build the 'bird an leave it home...
HGainiac is offline
post #20 of 30 (permalink) Old 02-03-2010, 09:55 PM
Woodman's Avatar
I like turbos, but I prefer them with manual transmissions. To combat turbo lag, downshifts are a necessity... the time to drop from 5th to 3rd to get a nice pass on slower traffic is more than enough time to make up for any turbo lag.
Since it's so difficult to get a manual in the Tbirds (unless you've got a supercoupe, and if you do why turbo it?) I wouldn't put one in mine, but that's just my opinion.
Woodman is offline
post #21 of 30 (permalink) Old 02-04-2010, 04:25 PM
David Neibert's Avatar
Why?? To make it faster.
David
David Neibert is offline
post #22 of 30 (permalink) Old 02-04-2010, 05:24 PM
I actually would think the auto would be better suited to the turbo. With a manual, every time you shift, its going to bog down and lag, then spool up and pull. With an auto, it keeps the engine loaded, so once you start going, you'll never feel the lag again until after you lift off.
MadMikeyL is online now
post #23 of 30 (permalink) Old 02-04-2010, 11:17 PM
This = True
Now DOHC
StrmChkn4.6 is offline
post #24 of 30 (permalink) Old 02-06-2010, 02:55 PM
Woodman's Avatar
Originally Posted by StrmChkn4.6 View Post
This = True
I think it depends on the type of driving you do...
For example, I don't care for drag racing, I like twisty roads and power at need. My experience with Turbos were with a 1985 Cougar XR-7 5 speed, a 1985 SVO Mustang 5 speed, and a 1987 Merkur XR4Ti with an auto.
Essentially, the motors are the same across the board, so the main difference was the transmission. The Cougar and SVO both liked to drop from 5th to 3rd to get right into the power band, and I never noticed any lag when dropping two gears. If I only dropped down to fourth, it took longer for boost to build, but the difference in RPM wasn't as dramatic between 5th to 4th as it was from 5th to 3rd.
The Merkur did better off from a standing start due to the ability to preload the turbo, but in the twistys the car seemed to hunt for gears, but my overall dislike of performance driving in an auto may be clouding my memory.
So let's just say that my personal preference is a manual with a turbo.
Woodman is offline
post #25 of 30 (permalink) Old 02-06-2010, 03:00 PM
MATLOCK's Avatar
i have had rear mounted on my stang and now have it in the engine bay and i can tell you I would never go to rear mount again....IMO
All the ponies below are located at my ranch in INDIANA if anyone wants to go for a ride...haha
1989 XR7 SC 5-speed
1996 Bronco on 33's
1995 Mustang GT mild 302 Quicktime Turbo kit 543hp on 9lbs
MATLOCK is offline
post #26 of 30 (permalink) Old 02-08-2010, 02:07 AM
When it comes to the corners a manual transmission can really work the IRS to the fullest extent.
I was considering a remote turbo.... Do share???
Now DOHC
post #27 of 30 (permalink) Old 02-08-2010, 09:28 AM
MATLOCK's Avatar
the matterials needed.....tuning is diff. and took us way longer and ...rear mounted exposes vital parts to road hazzards.....running oil lines is no fun and you will have to run at least 1.75 (i ran 2 extra quarts in mine) more quarts of oil do to the long oil line and the return line..also the drain of oil from the turbo has to be assisted by pump since gravity return is not an option any longer....also the amount of cold side piping is insane espec. if you run an IC.
1989 XR7 SC 5-speed
1996 Bronco on 33's
MATLOCK is offline
post #28 of 30 (permalink) Old 02-08-2010, 10:48 AM
winkysrides's Avatar
Send a message via AIM to winkysrides
David
lol go ask ira about turbos....lol
  • "Chuck Norris built my shortblock. It runs on the tears of small children and makes 10,000 hp. He said it's his 'street version' "
wheel hoppin and poppin!
91 Thunderbird sport 357W 5speed
88 stripped out 5.0 C4 and 4:56 gears in a 9in Ford
winkysrides is offline
post #29 of 30 (permalink) Old 02-08-2010, 11:07 PM
Are you talking about the same Ira who is in this video ?
http://www.youtube.com/user/Blown38#p/u/74/__IDq1i63ng
He's a real nice guy with one of the fastest SCs in the country. Just don't understand why I should ask him about turbos, when I know he doesn't have one.
David
PS: Here's one with me racing against Ira later that day.
http://www.youtube.com/user/Blown38#p/u/61/SaX4Z7M4LPE
post #30 of 30 (permalink) Old 02-09-2010, 08:18 PM
Tx_Cat's Avatar
Nice vids David..
Tx_Cat is offline
