Latest turbo 2V update - 700ftlbs on pump gas - TCCoA Forums
post #1 of 5 (permalink) Old 03-16-2010, 02:58 PM Thread Starter
nickmckinney's Avatar
My local boy Ryan just had Turbo Mike (also local) swap out his On3 kit to Mikes custom turbo header kit and picked up a couple HP:
He "only" did 620/650 before the piping swap, fixing the degree on one cam (it was 6 degrees retarded) and new rings as the first turner ran it a bit lean.
Its a forged bottom end, MHS Stage 2 heads, MHS/Bullet Stage 2 turbo cams, 70mm/68housing single turbo making about 20lbs. We are going to test swapping an Edelbrock/6061 combo shortly as well to see if we can pull some higher RPM.
nickmckinney is offline
post #2 of 5 (permalink) Old 03-17-2010, 12:42 AM
Nice! Do you have any pics of how you mounted your turbo??? And did you go with the tubular K member? Im leaning toward a single turbo setup myself
Now DOHC
StrmChkn4.6 is offline
post #3 of 5 (permalink) Old 03-17-2010, 12:39 PM
David Neibert's Avatar
Is this a Mustang ? Auto or Manual transmission ?
David
David Neibert is offline
post #4 of 5 (permalink) Old 03-17-2010, 02:54 PM Thread Starter
Mustang, manual tranny, 3.73 gears, and 400lbs of help to sit on the back trunk to keep the tires from smoking on the dyno. Should have some pictures in a couple weeks on the website (its in the articles section)
post #5 of 5 (permalink) Old 03-17-2010, 03:02 PM
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
Thats some good numbers
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
