Latest refinements to Turbo SC - TCCoA Forums
post #1 of 17 (permalink) Old 01-01-2002, 11:47 AM Thread Starter
David Neibert's Avatar
........moved
David Neibert is offline
post #2 of 17 (permalink) Old 01-01-2002, 11:50 AM Thread Starter
moved......
post #3 of 17 (permalink) Old 05-26-2010, 02:58 PM Thread Starter
My terry cloth covered breathers on the rocker covers wern't cutting it, and once saturated with oil they didn't flow well enough to relieve crank case pressure, which caused numerous oil leaks.
In addition to fixing all the leaks, Dan Saitz over at Hyperformance modded a set of Ford Racing polished aluminum valve covers to accept 12 AN hoses along with a nice Moroso catch can that should resolve the case pressure problems. Also had him add a dedicated oil fill cap, because removing a braided hose to add oil would suck.
I think it looks much better too.
David
Last edited by Sir William; 06-10-2010 at 06:13 PM. Reason: Tried to get images to show....
post #4 of 17 (permalink) Old 06-08-2010, 06:06 PM
Send a message via AIM to turbo5oohsc
Nice
turbo5oohsc is offline
post #5 of 17 (permalink) Old 06-08-2010, 07:04 PM
david, I'm guessing you would not want to run an evap system on a turboed motor?
post #6 of 17 (permalink) Old 06-08-2010, 08:28 PM
If you took this to the track would they even let you run it 1 pass before getting the boot.
post #7 of 17 (permalink) Old 06-10-2010, 05:40 PM Thread Starter
Yeah...I usually get kicked out after making the 1st full pass. Took it to drag race school last week and practiced staging and launching then letting off at the 60ft mark, tires went up in smoke everytime I came off the trans brake.
David
post #8 of 17 (permalink) Old 06-10-2010, 05:47 PM
Sounds like you need to lower the stall a few hundred rpm to make the boost increase after launch rather than be at max boost on launch.
post #9 of 17 (permalink) Old 06-10-2010, 05:49 PM
Actually after reading the thread I am confused. Is that the auto car or a 5spd?
post #10 of 17 (permalink) Old 06-10-2010, 06:09 PM
TCCoA Founder
Sir William's Avatar
Man, I'd have looked under that hood and said there was no way you could fit anything else...but you got it squeezed in there. Nice!
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #11 of 17 (permalink) Old 06-10-2010, 07:30 PM
Is there anything left to mess with on this car!?! It looks like a magazine car under the hood.
post #12 of 17 (permalink) Old 06-16-2010, 12:28 PM Thread Starter
Alan,
It's an auto with a full manual VB and 2800 stall non locking converter. Those tires usually bite very good and were the same ones I let Chris Wise use at the Shootout to run a 10.6.
With 2 step set to 3300 I was launching with about 6 pounds of boost. I get full boost at around 4200 rpm and it currently set for 14.5-15.0 psi (street tune). I just don't think they prepped the track because most of the people participating were racing daily drivers on street tires. Next time I'll use the ET streets instead of the radials. This link has all the details on the car and several pictures.
http://www.sccoa.com/forums/garage_v..._vehicle&id=39
David
post #13 of 17 (permalink) Old 06-16-2010, 12:31 PM Thread Starter
Theres always something...next up for this car is an NHRA approved driveshaft loop.
David
post #14 of 17 (permalink) Old 06-16-2010, 10:18 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
David
It is an awesome car! I first saw it at the 08 shootout, I think you've said it's making a bit more power since then. Have you guys done any meets at Gateway yet? I want to bring my stang out some time after I get some decent tires for it.
I'd like to see you race against my friend Jeff in his Infinity G35. I've been helping him a little bit with his turbo kit install; he's hoping to have it on the dyno in a few weeks making 750 hp or so at the wheels. I'd be rooting for you to win of course
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #15 of 17 (permalink) Old 06-16-2010, 10:52 PM Thread Starter
-Rob
Rob,
It was screwed up the 2008 shootout and wouldn't make over 6 pounds of boost no matter what I did. Found out later there were several issues including bad fuel and a chunk of metal stuck inside the exhaust housing on the turbine side.
Nothing planned at Gateway except to go over on a Tuesday night sometime soon and race my v6 car in the Street car Shootout series (tuner class). A G35 making 750 hp would be something to see and he could race it in the same tuner class.
David
post #16 of 17 (permalink) Old 06-24-2010, 06:41 PM
EvilMooseofDoom's Avatar
Are you running a mechanical or electric fan on this car?
Yes, I hate my Lincoln. Ask me about it sometime.
My Drivetribe garbage:
https://drivetribe.com/u/ivrqNaWFWj_...SaGpcKvLTz6v9w
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
EvilMooseofDoom is offline
post #17 of 17 (permalink) Old 07-06-2010, 01:30 PM Thread Starter
Mrk8 electric fan with DCC fan controller and a 3G alternator with upgraded wiring. Also using a Spal 14" pusher fan on the other side of the radiator.
David
