New best ET with turbo SC - TCCoA Forums
post #1 of 40 (permalink) Old 10-27-2010, 12:09 PM Thread Starter
David Neibert's Avatar
A few of the STL area guys went over to Gateway last night for the last test & tune session of the year. I brought my turbo car to see if I could improve on my previous best ET of 10.7.
First pass with a 16 pounds of boost and badly spinning off the line and again after the shift into 2nd it ran a dissapointing 10.882 @ 133.83 with a 1.905 60ft.
Second pass I lowered the tire pressure from 15.5 to 14.5 PSI and increased the boost to 18 pounds and once again had bad tire spin in 1st and 2nd gear but still went a little quicker running 10.752 @ 134.95 with a slightly better 1.867 60 ft. At this point I was beginning to worry that I would not be able beat my 91s best ET.
Last pass I lowered the tires to 14.0 and increased the boost a little to 19 psi, and was not feeling very good about my chances for an ET lower than my 91. Luckily about 4 cars before I was supposed race, they stopped us and prepped the track for some fast cars racing in a track shootout final. That must have helped because even though it was spinning off the line it was still accelerating pretty hard and I didn't feel any spin after the shift into 2nd. When I saw the 1.633 60 ft on the scoreboard I knew it was going to be my best pass, and was expecting somethings in the 10.5s. When I got the timeslip I was pleasantly suprised to see it had ran a 10.281 @ 136.28
I'm 99% certian that with better tires and a little more boost, I can get into the 9s. The guy helping me (Dan Saitz of Hyperformance) said for the fuel we had in the car (50/50 mix 93/116 octane) we could have added 3 more degrees of timing and turned up the boost to the sweet spot of 24 psi and the car would run 9.8s. Oh yeah this was done at full street weight with the only changes being the race wheels/tires (aprox 4200 lbs). Best of all nothing broke.
http://www.sccoa.com/forums/attachme...3&d=1288194177
David
PS: This link has more details and some pictures of the car.
http://www.sccoa.com/forums/garage_v..._vehicle&id=39
David Neibert is offline
post #2 of 40 (permalink) Old 10-27-2010, 12:16 PM
did you ever put a cage in either car?
nice times homie!
post #3 of 40 (permalink) Old 10-27-2010, 03:37 PM Thread Starter
nice times homie!
No...I'm planning to install a 6 point roll bar over the winter. That will make it legal to 10.0 @ 135, which will be good enough to get away with racing it at most tracks.
David
post #4 of 40 (permalink) Old 10-27-2010, 03:49 PM
Yes sir nice !! imagine what the times would be with solid traction
post #5 of 40 (permalink) Old 10-27-2010, 08:45 PM
392Bird's Avatar
Great Job Dave. I am sure you had them all scratching there heads.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #6 of 40 (permalink) Old 10-27-2010, 09:27 PM
driller's Avatar
And that's the icing on the cake!
Congrats!
driller is online now
post #7 of 40 (permalink) Old 10-27-2010, 09:31 PM
Send a message via AIM to Red97Tbird
Almost makes me wish I hadn't sold my 4.3 stroker .. Very nice man hope you hit 9's.
4.6 explorer motor,Water meth injection, V1 Vortech, 3.48 pully,BBK 78mm, Dirty Dog 9.5 converter 3500 stall, RobertP built trans, 8.8 rear with trac lock, 3.73 gears, BrainCoating manifolds, Dual 2.5" exhaust.
Red97Tbird is offline
post #8 of 40 (permalink) Old 10-27-2010, 09:51 PM
ironworker's Avatar
thats his 347 turbo car ...... that good stuff
89 thunderbird twin turbo v6 sc 5 spd
spinningwheels-sc.com
ironworker is offline
post #9 of 40 (permalink) Old 10-27-2010, 10:40 PM Thread Starter
Thanks guys.
The old 27" MT ET streets I've got now are pretty much shot, so I'm getting a new set of 28" Hoosiers next week that should help lower the 60 ft times and give me a little more top end speed without raising the rev limiter.
If it runs high 9s with just the new tires and a little more boost that would be cool, but I don't really care if it does. Worried that if I get too carried away with running quicker and quicker track numbers, it will soon turn into a full blown race car and I'll stop enjoying it.
I'm really struggling with the idea of installing a roll bar, for the same reason.
David
post #10 of 40 (permalink) Old 11-02-2010, 04:51 PM Thread Starter
Heading to Kentucky this weekend to race the car again. With a new set of slicks and a few minor changes to the tune, rev limiter and boost settings, I'm hoping for high 9 second timeslip to end the season.
David
post #11 of 40 (permalink) Old 11-02-2010, 04:54 PM
man, I'm just surprised at the trakcs that are allowing you to run there....I guess safety is not their primary concern?
post #12 of 40 (permalink) Old 11-02-2010, 06:00 PM
Damn Dave. Those are some awsome times!!
Stuckinkaos07 is offline
post #13 of 40 (permalink) Old 11-02-2010, 06:29 PM
Jeff Bratton's Avatar
Send a message via AIM to Jeff Bratton
David...
I plan to spectate and hopefully be witness to your 9 sec. run...
Cheri and I and a friend of mine will all be there at around 10 am. Looking forward to seeing you guys again and drive safe down to KY. Right know it looks to be right at 60* for ya and NO rain..... nice cool Temps!!
see ya guys soon.
Jeff
'89 Black SuperCoupe
Louisville, Ky.
260 RWHP / 349 RWTQ
Email me: [email protected]
Powered By Magnum Powers MPIII & other Bolt-On's
Check out My SuperCoupe
Jeff Bratton is offline
post #14 of 40 (permalink) Old 11-02-2010, 10:51 PM Thread Starter
The race in KY this weekend is a private track rental and I won't be in the competition, just making timed runs. I was only able to make those passes at Gateway, because they were ceasing operations and closing the track within a couple days. Tinted windows and the assumption by track officials that I already had a cage if I was racing in the slick tire class didn't hurt either.
Same car had already gotten the boot in 2006 for running too quick, and had not been raced there since that time. Seriously considering the addition of a roll bar over the winter.
David
post #15 of 40 (permalink) Old 11-02-2010, 10:52 PM Thread Starter
Originally Posted by Jeff Bratton View Post
David...
see ya guys soon.
Jeff
Jeff,
That's great, I'll see you there.
David
post #16 of 40 (permalink) Old 11-03-2010, 12:15 AM
Mgino96tbird46's Avatar
Wow, those are some bad a** times! 10.281 at full weight none less. I like your set up.
Mgino96tbird46 is offline
post #17 of 40 (permalink) Old 11-03-2010, 12:28 AM
Assaultdog0351's Avatar
Send a message via AIM to Assaultdog0351 Send a message via Yahoo to Assaultdog0351
Originally Posted by David Neibert View Post
10.281 @ 136.28
RTLB, RSTB, FSTB, LECB and FSSB, MAC intake, black interior and new shoes... Soon to come: SVO blower,, AIS, SS kooks headers, SS 2.5" dual exhaust w/ x-pipes and borlas, koni shocks, 1.6" vogland drop, poly (almost)everything, 1 3/8 F&R swaybars, rebuilt suspension... Parts collection nearing completion, contemplating the "Do" phase... More like "Pay someone else to do" phase... I blame the slow results on deployments and pre-deployment training... Kill
*currently planning some chassis work*
Assaultdog0351 is offline
post #18 of 40 (permalink) Old 11-03-2010, 09:24 AM
David
makes sense....
post #19 of 40 (permalink) Old 11-03-2010, 12:56 PM Thread Starter
Main reason for racing the car, is to prove to myself what it's really capable of. I was also getting tired of explaining why the best ET with my v6 supercharged SC was quicker than the v8 turbocharged SC
David
post #20 of 40 (permalink) Old 11-03-2010, 01:52 PM
Congrats Dave.
A lot of us are turning in better times this fall. I hope to improve mine when we run the cars on the 27th at Rockingham.
post #21 of 40 (permalink) Old 11-03-2010, 03:09 PM
Congrats Dave.
I'm hoping to at least have my chassis finished before years end.....but the way my heath keeps declining, I don't think its possible.
post #22 of 40 (permalink) Old 11-03-2010, 03:11 PM
You're health? Get that hammer extracted from your head, you'll be all right.
post #23 of 40 (permalink) Old 11-03-2010, 11:02 PM Thread Starter
Congrats Dave.
Thanks and I hope you get what you're after on the 27th. BTW, I met Robert P at the Shootout. Nice guy and a nice car, sucks that he had an electrical problem with the car on race day.
David
post #24 of 40 (permalink) Old 11-03-2010, 11:26 PM
Fuel issues which are being addressed lol, I'll have over kill on the fuel system
Keep us posted I see 9s very soon in your future
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #25 of 40 (permalink) Old 11-04-2010, 08:03 AM Thread Starter
Robert
Better to overkill it on the fuel system than to come up short. I've got dual 255 high pressure pumps in the tanks of both my SCs.
David
post #26 of 40 (permalink) Old 11-04-2010, 08:51 AM
David
Got any pics of how you did that setup?
post #27 of 40 (permalink) Old 11-04-2010, 10:20 PM Thread Starter
This post has a picture of the dual pump assembly and some other details about wiring and fuel level sender, that we recently put in my 91 SC. The 93 SC was done similar, but instead of welding in pushlock fittings we used a bulkhead fitting. David Dalke made the dual pump setups for both cars, and swears he won't do another one because it takes too much work.
http://www.sccoa.com/forums/showpost...&postcount=140
David
post #28 of 40 (permalink) Old 11-09-2010, 04:26 PM Thread Starter
Ran another best of 10.17 @ 140 this past weekend at a track in Clay City, KY before breaking the transmission. New tires worked great, but they also made it very clear the converter is stalled too low at 2700 rpms. Best 60ft was 1.680 and the tires were not spinning.
Getting a new 3500 stall converter when transmission is repaired next week. Probably won't get another chance to race it until spring, so 9s will just have to wait.
David
post #29 of 40 (permalink) Old 11-09-2010, 04:33 PM
They dont give you crap for not having a cage? Congrats 140MPH is getting up there. I hope you got decent brakes and make sure to inspect everything before making runs. 9s are just a tweak away.
RICARDOA1 is offline
post #30 of 40 (permalink) Old 11-09-2010, 08:40 PM Thread Starter
Car got the boot from Gateway in 2006 for running 11.40 @ 125 without a roll bar, and on that same night my 91 got the boot for running 10.68. Didn't go back to Gateway until 2 weeks ago when the track was getting ready to cease operations and I knew that nobody would care.
I was actually surprised that I didn't get some greif from the track in KY but it was a private rental (like the Shootout) and they were extremly lax on safety stuff. They were happy if you just wore a helmet and your seat belt, I had a fire jacket on too and apparently that was safe enough for them.
I did get one funny look from the track guy who was working the staging lanes on the last pass when they were making the test and tune cars put a dial in time on the window if you wanted to keep running. I had a 10.10 on the window and the guy calling the dial in times and car numbers up to the tower did a double take and was giving me that WTF look, and I just shrugged. He just shook his head and waved me up to the burnout box.
I'll probably go back for their spring meet, because it doesn't look like we are going to have a track in STL that soon.
David
