sts turbo on a 3.8? - TCCoA Forums
post #1 of 13 (permalink) Old 01-14-2011, 06:21 PM Thread Starter
tehsilver95lx's Avatar
sts turbo on a 3.8?
'got to thinking.....if sir William did it with his 4.6 (i believe) whats stopping us 3.8 guys? (except forged internals blah blah blah) i mean sts is suppouse to be a really universal turbo system so do we got some ideas?
Beater lx,current mods: cold air,drilled and slotted rotors,glass pack muffler. Scrapped
Teal terror 94...trans slip and a fram air hog filter!
94 Sc :Cobra R hood,96-97 Front lights,3.73 Trac Lok,1" Raised top,5% OD Blower Pulley,CAI,Removed resonator,Gutted cats,No mufflers. "It roams around in a open loop speed density tune. killing small children and raping helpless mothers at night."
....THAT DOES NOT MATTER!....
tehsilver95lx is offline
post #2 of 13 (permalink) Old 01-14-2011, 07:55 PM
twin turbo 281's Avatar
You could build your own setup on the cheap. Find a suitable turbo...master power is a good place to look. you don't even need STS you can buy a scavenge pump for about 200$ and run some oil lines the lenght of the car. But for the money buying a V8 car would net you more performance and reliability for less work.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #3 of 13 (permalink) Old 01-15-2011, 02:01 PM
ironworker's Avatar
scavenge pump for about 200$ no they are more then that mine was allmost 400 but i bought the best one they had and it was only 60 buck more then the cheep one
they are well worth the money
89 thunderbird twin turbo v6 sc 5 spd
spinningwheels-sc.com
ironworker is offline
post #4 of 13 (permalink) Old 01-15-2011, 04:29 PM
Depends on the brand. There are turbowerx pumps on Ebay for $230 I had one that I bought for 200 one time and a few others have had pumps that ran less. Reliability? Well that all depends theres no saying when a motor will short out. I'm sure quality does come into play but even those 1000$ STS brand pumps can fail.
Personally I don't like remote mount setups. I don't like relying on a noisy little pump to return oil to the motor. Besides on a 3.8L there is room under the hood to place a single turbo. It will take a little more work but in the end the cost can even be cheaper since you don't need a pump and 20' of oil lines.
It would also be 100x easier to just buy a SC and then ditch the blower for a turbo as you would have a strong motor and EFI setup for a boosted car.
post #5 of 13 (permalink) Old 01-19-2011, 10:47 AM
MAMN12 Posse Member
JeffTBird93's Avatar
Wasn't SW's car as slow as a stock Bird too? And if I remember right, or at least the last time I seen, he only got like 2 psi due to all of the leaks.
STS kits are cool in concept, and they sound amazing, but in the end, you're still having to pressurize 10+' of piping.
~Jeff
*signed off
JeffTBird93 is offline
post #6 of 13 (permalink) Old 01-19-2011, 02:44 PM
length of pipe does not matter when it is completely sealed.
post #7 of 13 (permalink) Old 01-19-2011, 03:09 PM
MAMN12 Posse Member
Right, that's what I was getting at. It's a lot of pipe to seal...getting the welds perfect, that kind of thing.
~Jeff
*signed off
post #8 of 13 (permalink) Old 01-19-2011, 03:31 PM
ah gotcha.....yeah, thats a lot of welds..lol
post #9 of 13 (permalink) Old 01-22-2011, 12:56 PM Thread Starter
so sombody has already done this? and got like no hp gains?
post #10 of 13 (permalink) Old 01-23-2011, 12:00 AM
plenty have seen gains with remote mounting. However you would be better served putting the turbo under the hood as there is room. If you really want to go with a turbo you would be better off ditching that NA 3.8 car and buying a supercoupe and ditching the blower for a turbo. The SC will have forged internals and a managment/fuel system already setup for a boosted motor. Trying to upgrade that NA 3.8 to handle boost will be alot of waste money compared to just buying an SC.
post #11 of 13 (permalink) Old 01-24-2011, 04:32 AM Thread Starter
o ok
post #12 of 13 (permalink) Old 01-26-2011, 09:30 AM
so, would there be gains usin this method if someone was to ditch the SC for a remote mounted turbo?
Stuckinkaos07 is offline
post #13 of 13 (permalink) Old 01-26-2011, 01:09 PM
If thew boost was turned up above the stock level and the ecu was tuned correctly. I would still rather put the turbo under the hood which would eliminate the need for a scavenge pump and 20' of oil lines.
