This inspire anyone else? - TCCoA Forums
post #1 of 24 (permalink) Old 05-25-2014, 10:24 AM Thread Starter
95_SilverBird's Avatar
http://jalopnik.com/mercedes-f1s-sec...alf-1558154190
Tighter package, less piping, less lag, cooler air...
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #2 of 24 (permalink) Old 05-25-2014, 12:16 PM
Apparently a very technical accomplishment.
Use the Force they must!
post #3 of 24 (permalink) Old 05-25-2014, 12:56 PM Thread Starter
Its actually a fairly simple idea and I'm wondering if the space/piping savings will fit a turbo under our hoods
post #4 of 24 (permalink) Old 05-31-2014, 09:08 PM
ricklovin93's Avatar
I cant see how it would save space though... Now you would have to find room to allow some sort of "driveshaft" to connect the two turbines.
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed"
ricklovin93 is offline
post #5 of 24 (permalink) Old 05-31-2014, 09:11 PM
BRONCONUT's Avatar
Send a message via Yahoo to BRONCONUT
....or connect them with a cable.
BRONCONUT is offline
post #6 of 24 (permalink) Old 06-01-2014, 09:30 AM Thread Starter
What if they were both in the valley? Shaft under a custom manifold, hot side in the back with exhaust piping and cold side in the front with option of piping to the intercooler? It'll be setup almost like a twinscrew supercharger. Am I crazy?
post #7 of 24 (permalink) Old 06-01-2014, 03:53 PM
you mean under the intake manifold?
post #8 of 24 (permalink) Old 06-01-2014, 08:58 PM
Moderator & Teksid Whore
guitar maestro's Avatar
You are. What kind of material do you plan to use for the shaft and have you calculated the harmonics using FEA? Unless you have done so properly, it won't work. It takes a crew of full-time engineers to accomplish things like this to work for more than 5 minutes.
guitar maestro is offline
post #9 of 24 (permalink) Old 06-02-2014, 07:07 AM
I agree, this is a "good" idea if you have lots of money to waste on a project that may or may not work.
post #10 of 24 (permalink) Old 06-02-2014, 11:21 AM
S4gunn's Avatar
I agree with this comment.
The prop/driveshaft between the exhaust section and the compressor section must spin at 40K-100K (wikipedia says they go as high as 250K).
Even with a commercial grade machine shop, the precision required to make a system that would last for even a "toy" car (let alone a daily driver) would be beyond what most companies could do.
Unlike F1, a hobbyist doesn't really have any "rules" limitations. Perhaps a better way to solve this problem would be something like an exhaust driven alternator coupled to an electric (not belt-driven) supercharger.
I'm not talking about the turbofan/bilge pump crap but the production quality stuff that several mfgs are developing.
http://www.caranddriver.com/features...rger-tech-dept
http://www.cpowert.com/
http://www.treehugger.com/cars/elect...co2-by-20.html
And on the input side, maybe something like this:
http://www.designworldonline.com/thi...rbo-generator/
In the end, you would have to weigh
1) the exhaust + intake pipe routing problem of having a traditional turbo and intercooler setup w/ its efficiency losses due to heat soak and friction vs.
2) the added weight of the turbo-generator and electric supercharger plus the efficiency losses of converting air flow to electricity and then back to air flow.
I'm still willing to bet that for tbirds, the big issue will be ECU tuning. Just look at all the twin turbo tbird projects that have died before fruition on these forums.
-g
http://goo.gl/csaet4
S4gunn is offline
post #11 of 24 (permalink) Old 06-02-2014, 03:13 PM
Most of em die from frustration due to pipe routing. There's just no easy way to do it, and there just not enough room.
post #12 of 24 (permalink) Old 06-02-2014, 03:23 PM
Tuning is perfectly doable so long as the tuner knows what they are doing, It's really not that much different than tuning a car for a blower. I think the rare events where someone fabs a system from scratch they tend to either be too broke or too stubborn to shell out the money to finish it off. When builds revolve around old Turbos sourced from diesels the local pick n pull or Chinese cheapos from ebay they builder is probably going into it with the idea that they're going to be able to do everything themselves and not spend any more money than what the Turbo(s) cost.
In these cars cases(namely Modular cars) pipe routing is a major issue that there's no good solution for. There's room to run the exhaust tubing, or run the intake tubing, but not both, not without putting tubing below the K member anyway, which is not a good idea.
post #13 of 24 (permalink) Old 06-02-2014, 09:11 PM
unless you don't use the stock K-member and go tubular
post #14 of 24 (permalink) Old 06-02-2014, 09:12 PM
Still waiting to see one
post #15 of 24 (permalink) Old 06-02-2014, 10:55 PM
post #16 of 24 (permalink) Old 06-03-2014, 12:58 AM
Can't wait to see that.
post #17 of 24 (permalink) Old 06-03-2014, 02:10 AM
I don't fail to deliver. Yes I deliver late, but I deliver.
post #18 of 24 (permalink) Old 06-03-2014, 08:22 PM
If there are electric superchargers available that will feed a 4.6l engine, life will be fun.
Imagine 15lbs of boost off the line, independent of rpm...
How many CFM is a 4.6l engine eating at 6k rpm?
I'd love to see one.
post #19 of 24 (permalink) Old 06-03-2014, 08:28 PM
Depends on load. Assuming ~60% load at that RPM, you're looking at 60% of 2.3L for every RPM, or 13,800 * .6 = 8280L/min or about 292 CFM (or about 23.5#/min for you MAF sensor inclined guys ).
post #20 of 24 (permalink) Old 06-04-2014, 11:54 AM
I know my old setup was doing ~31 #/min @ ~6000 RPMs.
post #21 of 24 (permalink) Old 06-04-2014, 06:00 PM
So, from all that, 500CFM should be a hellacious blower. ~500hp or near.
Look at the amount of work required to compress the air 2x @ 500cfm.
You're still talking the same roots blower, but with a big-ass electric motor too.
Change "roots" to any other type, ant it's the same.
Expensive neodymium motors, with low friction bearings could actually work...
The full boost at startup is probably do-able otherwise; you could use a clutch setup on the blower spindle and a "starter motor" to run the blower up to speed before launch, and let the engine take over as it catches up.
post #22 of 24 (permalink) Old 06-10-2014, 01:36 PM
I know it's going back to some previous posts, but what possibilities are there for a turbo mounted near the rear of the car? It would have horrible lag, but when space is as limited as we all know it seems rather practical. That's my initial project for my '94 4.6L. PI top end, forged internals, then all the works for a turbo.
fieldcrow is offline
post #23 of 24 (permalink) Old 06-10-2014, 01:53 PM
Look up Sir William's car. He was the prototype (IIRC) for an STS rear turbo setup which I don't think ever made it to production.
post #24 of 24 (permalink) Old 06-10-2014, 02:27 PM
Only if you improperly size the turbo and don't know how to keep the exhaust gases piping hot until they reach the blower, is what I say.
