Turbo Update #2 - TCCoA Forums
post #1 of 16 (permalink) Old 01-05-2005, 02:58 PM Thread Starter
Exclamation Turbo Update #2
I know what you guys are thinking, and I know I sound like a broken record. I was informed by HP Performance this morning that the Turbo project on my '91 SC will begins this week. I will be giving you guys information as this project unfolds.
dirtybird91 is offline
post #2 of 16 (permalink) Old 01-05-2005, 08:38 PM
Tx_Cat's Avatar
Keep us posted bro.
Tx_Cat is offline
post #3 of 16 (permalink) Old 01-05-2005, 08:45 PM Thread Starter
Originally Posted by Tx_Cat
Keep us posted bro.
Consider it DONE man!
post #4 of 16 (permalink) Old 01-07-2005, 10:02 PM
5150Bird's Avatar
Send a message via AIM to 5150Bird
Same here...let me know how it turns out and prices us "common" folk would end up paying. Im lookin to get into a 91 SC this spring.
Later
Even Mustangs run from THUNDER
5150Bird is offline
post #5 of 16 (permalink) Old 01-07-2005, 10:04 PM Thread Starter
Thumbs up
Later
This week has ended, so I will call these guys on Monday to see what's up!
post #6 of 16 (permalink) Old 01-10-2005, 05:49 PM
Any updates? I would really like to know how much a kit would cost and am seriously considering going for it.
90' Cougar Sport Edition 3.8 (RIP)
92' Cougar 25th Anniversary Edition 5.0
96' Contour Sport (RIP)
01' Jaguar XJR
Stoltz13 is offline
post #7 of 16 (permalink) Old 01-18-2005, 08:52 AM
Any idea if this kit will fit on a 3.8 N/A?
88 T-Bird LX
93 T-Bird LX
91 T-Bird LX
Jhrea is offline
post #8 of 16 (permalink) Old 01-20-2005, 12:10 PM
97ThunderCat's Avatar
do it yourself for 2-3K i bet
97ThunderCat is offline
post #9 of 16 (permalink) Old 01-20-2005, 06:52 PM
I have limited mechanical experience, I can't weld and I don't have a pipe bender.... I might be inclined to get a professional installation and save the headache ! I'm not necissarily in to it for the learning experience or to prove that I am a capable hot rodder or tuner... I'm after the raw power, plus turbos and other gagets really interige me I'm just looking for a good clean installation at a decent price.
01' Jaguar XJR
Stoltz13 is offline
post #10 of 16 (permalink) Old 01-27-2005, 11:14 AM
Arro's Avatar
You don't need a pipe bender or to know how to weld. I installed two different DIY kits without a welder or a bender.
If you want bends, get onto http://www.jcwhitney.com and get them in a wide variety of diameters and mandrel (even) bends. Buy a hacksaw and hand cut them. Line the sections up with duct tape for test fitting, then use a permenant marker to mark line-up points. I used a line with a corresponding letter on either mating edge. Then take it to an exhaust shop and tell them to line them up the same way and tack them together (tacking are just tiny welds to hold it together in case you need to break them for repositioning).
Then take it to wherever on the car and see if it fits. If it does, tell the exhaust shop to weld it up all the way. BAM, you're done.
Intercooler piping is even easier. Go to a NAPA truck parts store (for the big diesels) and ask to poke around in their truck radiator hose bins. There's lots of premolded shapes to choose from. I always manage to find a hose with about two or three different bends I can use. Some of the bends you can find will help you get around tight spots. And in combination with jc whitney exhaust pipe sections and bend sections, you can make whatever airpipe configuration you need.
Image has been taken from http://home.earthlink.net/~turbogus2/cooler.html
Courtesy of Thomas "Gus" Mahon, 1948-2002 RIP
Gus was the king of ghettorigging, and this was one of his best contributions. His tip to me and mine to you is to take 45-degree bends and use them to make even less sharp bends. Depending on where you hacksaw at in the middle of the bend, you can tack up a straight piece and redirect the angle even less than 45.
Oh, and Turbonetics can sell you the turbo stuff to weld on. Also something the exhaust shop can do. Turbo flanges, BOV flanges, etc.
-J. Arro
1994 Ford Thunderbird 4.6L LX V8
Bone stock engine, *partial* Xenon Body kit.
http://www.cardomain.com/ride/750285
PLZ HELP ME FIND A XENON FRONT LIP
I also own some Turbo Dodges, a couple turbo DSM's, a few turbo Nissans, a Toyota pickup, and a supercharged VW sportcoupe.
Arro is offline
post #11 of 16 (permalink) Old 01-27-2005, 10:21 PM
If you want bends, get onto http://www.jcwhitney.com and get them in a wide variety of diameters and mandrel (even) bends. Buy a aw and hand cut them. Line the sections up with duct tape for test fitting, then use a permenant marker to mark line-up points. I used a line with a corresponding letter on either mating edge. Then take it to an exhaust shop and tell them to line them up the same way and tack them together (tacking are just tiny welds to hold it together in case you need to break them for repositioning).
Gus was the king of ghettorigging, and this was one of his best contributions. His tip to me and mine to you is to take 45-degree bends and use them to make even less sharp bends. Depending on where you aw at in the middle of the bend, you can tack up a straight piece and redirect the angle even less than 45.
Thanks for the info... now if you could just send me the motivation
I want to go fast, I just don't want to do all the work...
Btw, People like you amaze me... I almost had a panic attack from putting a fuel pump in and a differential.... and that was before I even started! I'm not patience, not a self starter and I am an absolute perfectionist when I do a project myself... It gets done faster, more efficiently and I don't notice all the imperfections when some else does it
01' Jaguar XJR
Stoltz13 is offline
post #12 of 16 (permalink) Old 01-28-2005, 10:18 AM
Arro's Avatar
SO am I all these things, take my word for it, once you start, you just won't stop!
-J. Arro
Arro is offline
post #13 of 16 (permalink) Old 02-03-2005, 11:52 PM Thread Starter
Exclamation
Sorry for the delay guys! HP Performance informed me a week ago that it would be 60 days before we get to see a turbocharged thunderbird. Thanks for hanging in there with me and being patient. I am about to loose my mind over the whole deal.
Frank
post #14 of 16 (permalink) Old 02-04-2005, 09:51 AM
Arro's Avatar
aHEM*Bill's setup*aHEM
-J. Arro
Arro is offline
post #15 of 16 (permalink) Old 02-04-2005, 08:45 PM Thread Starter
Question
??? Sorry, but I can't figure out what this means?
post #16 of 16 (permalink) Old 02-06-2005, 10:42 AM
Bill has a turbo mounted under his trunk (4.6 Bird). How does it work BTW?
There are a couple of Turbo SC's floating around this world already, just the owners are kinda shy.
David
XR7 DAVE is offline
