How well will my car run with a turbo? - TCCoA Forums
View Poll Results: How will the turboed thunderbird sc run?
Mid to low 14's 1 4.17%
13 second car 8 33.33%
12 second car 10 41.67%
11 second car 5 20.83%
Voters: 24. You may not vote on this poll
post #1 of 28 (permalink) Old 02-04-2005, 12:17 AM Thread Starter
There was a poll on the SCCOA's polls forum about my upcoming turbocharged supercoupe. People over there seem to have various opinions, but I am also interested in what you guys think.
The car will have the following upgrades:
Turbo (or turbos)
Blow off valve
Possible Alcohol Injection
Custom front mount intercooler
N/A intake
Upgraded injectors, fuel rails
255lph fuel pump
Custom radiator
Custom Exhaust
Custom turbo headers
Chip or standalone computer
Art Carr Extreme AOD w/2500 stall
slicks
dirtybird91 is offline
post #2 of 28 (permalink) Old 02-04-2005, 12:50 AM
Banned
Kodiak Kid's Avatar
Send a message via Yahoo to Kodiak Kid
slicks
can't say from experience...but, might wanna look into another tranny....use search to see what I am talking about.
Shane
Kodiak Kid is offline
post #3 of 28 (permalink) Old 02-04-2005, 12:53 AM Thread Starter
Shane
Too late for that. I already spent 2K on it and had it installed before the car left for New Mexico and HP Performance. I can only cross my fingers at this time and hope for the best.
post #4 of 28 (permalink) Old 02-04-2005, 09:50 AM
96bird's Avatar
How are we to make a guess? You didn't put how much boost you were planning on running? Nothing about if it is going to be stock bottom end or not? The car should run low 12's with decent boost(350rwhp or so). If you put a nice bottom end under it and turn up the boost then I think you will really see what it is capable of. I wonder what kind of effect the intake is going to have on the car? If I was to take a guess I would say that you are going to have a huge amount of midrange torque.
96bird is offline
post #5 of 28 (permalink) Old 02-04-2005, 02:49 PM Thread Starter
Lightbulb
I am hoping for around 13-18psi, because the stock Supercoupe can handle boost in that ballpark.
post #6 of 28 (permalink) Old 02-06-2005, 05:36 PM
Send a message via AIM to 1997T-Bird Send a message via Yahoo to 1997T-Bird
Heres my response...
FAST....
..VERY fast.
Currently: 2004 Honda Civic Ex 5 Speed
17X7 BSA Wheels - 215/45/17 Falkens; Complete JL System; Magnaflow Catback; Lowered 1.4"
Last Car:
Custom Magnaflow Dual Exhaust; 2003 Cobra Rims with Kelley 255/45/17s;Steeda U/Ds; B&M Transmissoin Cooler; Dirtyd0g's custom 2800 Stall Torque Converter; J-Mod Kit installed by Dirtyd0g; SCT Tuned by Darrin; Lowered with Spring Tech Springs
Want great work done on your tranny? Have dirtyd0g do it! He made a believer out of me!
1997T-Bird is offline
post #7 of 28 (permalink) Old 02-07-2005, 08:13 AM
TbirdSims's Avatar
Send a message via AIM to TbirdSims
Talking
You should go with This Set up! Supercharged Twin Turbo
Hayden Trans Cooler, R2C Cold Air intake, BBK Tuned Shortie Headers, Pypes High Flow Cats, Flowmaster 40's, SCT VMP Custom Tune, 06 spinner center caps, Mach 1 Chin Spoiler, Smoked Fogs, Blackout headlight covers, 8000K HID Headlights, Sequential Tails.
TbirdSims is offline
post #8 of 28 (permalink) Old 02-07-2005, 07:44 PM
Well heres the thing, boost doesn't matter. Boost is the amount of backpressure that is present in your intake. Thus if you have high flowing heads and intake vs. stock heads and intake it will show up as more boost eventhough your wastegate is set for the same amount. Also 13 lbs of boost from a T-3 turbo will not be the same power as 13 lbs from say a PT-44. The bigger turbo should make more power at lower boost, because it will move more air. The real determining factor will be in turbo size and strength of your bottom end. Do you have any idea of what size turbo will be used? If the right turbo is used and the bottom end is strong you could make as much power as you want. I like the idea, it should run much better than with the blower.
scottrob is offline
post #9 of 28 (permalink) Old 02-08-2005, 05:11 PM Thread Starter
That really makes sense to me. I will be going with a stock Supercoupe bottom-end at first just to demonstrate to others the potential. I am building a really strong bottom end in my garage, and I will be going with some Coy Miller "R" heads next year. HP Performance has not informed me of what size blower they will be using yet. I understand that they plan to select the right turbo by properly sizing it to the 3.8 SC engine.
post #10 of 28 (permalink) Old 02-09-2005, 12:21 PM
Wow I really think you should have some input on what turbo should be used, considering only you know how much power you want to make. I have seen an SC put 320hp to the wheels with a stock engine, but it did pop a few head gaskets. It had ported heads, blower pulley, and nitrous. The turbo is a far better way to go in my opinion than the blower. Its a really cool idea. Since you are planning a stronger engine in the future I would suggest you pick a turbo that will support the hp you plan on making with that engine. That way you can simply run more boost to increase the power on the new engine. I would suggest a 60-1. They are relatively inexspensive and will support up to 550 hp.
scottrob is offline
post #11 of 28 (permalink) Old 02-09-2005, 07:49 PM Thread Starter
Thumbs up
Thanks Dude!
post #12 of 28 (permalink) Old 02-11-2005, 10:17 PM
I said 11's, but it's really hard to say and depends a lot on traction... I've seen cars on the track with a lot of power that spun the whole way down the line because they didn't hook up... I guess in that case a bit of turbo lag wouldn't be a bad thing!
90' Cougar Sport Edition 3.8 (RIP)
92' Cougar 25th Anniversary Edition 5.0
96' Contour Sport (RIP)
01' Jaguar XJR
Stoltz13 is offline
post #13 of 28 (permalink) Old 02-11-2005, 10:18 PM Thread Starter
Exclamation
That's true, but I plan on a new set of slicks to set things straight. My insurance agent is so cool that he agreed to sponsor half the cost of the tires!
post #14 of 28 (permalink) Old 02-12-2005, 11:16 AM
mannysc's Avatar
Send a message via AIM to mannysc
itll turn 13s quit dreaming Frank! lol polls dont make a car fast lets wait and see.
so calif supercoupe parts fabricator
msd inverted blower [email protected]
http://community.webshots.com/user/mannysc
Mannysc 's paysite for paypal
http://http://www.freewebs.com/mannysc1991/index.htm
mannysc is offline
post #15 of 28 (permalink) Old 02-12-2005, 01:25 PM Thread Starter
Exclamation
LOL Manny! So I guess since you predict 13's means i'm dreaming. I'm glad to know that you seem to know something that the rest of us don't about Turbo's.
OK! Since you started a poll over on SCCOA and half agree that the car will run 13's or slower YOU WIN!
I am really confused if have offended anyone about this situation because reality is that I am only trying to mod this car in an effort to reach my goals. If I have offended anybody by asking HP Performance for a 12 second car, I apologize if they deliver me one as promised.
So, SORRY (in advance).
P.S.- Funny how this poll looks a hell of a lot different than the one over at SCCOA.
post #16 of 28 (permalink) Old 02-12-2005, 02:32 PM
mannysc's Avatar
yeah different people turbo dudes know turbos and blower guys think limited.
I hope it turns 12s I figure if we down play it they at hp will make sure it does better than we ever expected , shoot it has to or they look lame.
they have future costumers at stake so it better make a m90 look like a childs toy. and really make it look bad or its a waste of time and money.
mannysc is offline
post #17 of 28 (permalink) Old 02-12-2005, 02:44 PM Thread Starter
Talking
HEHE. You are right Manny. I agree, but we are not just after the M90. We want to make the other blowers look silly too.
post #18 of 28 (permalink) Old 02-12-2005, 04:42 PM
And with any reasonable effort you will... there's no reason a turbo car cannot out perform a SC and be more efficient while doing it!
01' Jaguar XJR
Stoltz13 is offline
post #19 of 28 (permalink) Old 02-12-2005, 04:58 PM Thread Starter
Talking
You are right about that Stoltz13. Turbo is definately the way to go, and I am really glad to be a part of something like this. Kudos to you others with turbo cars that are resoursful enough to live outside the box.
Don't get me wrong, you have others like XR7Dave who is making bold positive moves away from the M90 and I have nothing but respect for him. But what gets my goat is when you try something new and someone comes out the woodwork and tells you why it won't work. So much negativity. I don't want to know about what does not work. I am concerned with what CAN and will work. Now with that being said, it's not like we are trying to reinvent the wheel around here. LOL, ricers, buick guys, and pontiac guys have already proven this recipe over and over again!
post #20 of 28 (permalink) Old 02-12-2005, 05:04 PM
Exactly... people are just scared of anything different... so don't let it bother you!
01' Jaguar XJR
Stoltz13 is offline
post #21 of 28 (permalink) Old 02-12-2005, 05:48 PM
TCCoA Founder
Sir William's Avatar
LOTS of people told me mounting a turbo in the back of the car would never work too......
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #22 of 28 (permalink) Old 02-12-2005, 05:58 PM Thread Starter
Smile
I bet that setup is pretty cool. I have seem various articles where people put them on Z28's and T/A's. I have not had a chance to research your car much, but how well does it work? What's the dyno sheet look like?
post #23 of 28 (permalink) Old 02-12-2005, 07:49 PM
TCCoA Founder
No dyno sheet yet. Still workin some misc. bugs out. Hopefully I'll have numbers by summer.
Sir William
TCCoA Founder
post #24 of 28 (permalink) Old 02-12-2005, 08:01 PM Thread Starter
Thumbs up
Thanks William! I look forward to that!
post #25 of 28 (permalink) Old 02-12-2005, 08:55 PM
mannysc's Avatar
im totally scared of anything thats not stock id never try something off the wall. you got guts and muncho potential with the turbo setup. I just like riding Franks back its all in fun Im wATCHING HIS EFFORTS cant wait to see how it turns out.
mannysc is offline
post #26 of 28 (permalink) Old 02-13-2005, 09:44 AM
BMan's Avatar
Maybe this will help you understand what it will take.
1/4 mile time. power to weight
'97 4.6...Gen II reflashed EEC, 99+ control module, J-Mod, 3:73 FRPP rear, Magnecore wires, High-flow cats, 3" into 2 2.5" Flowmasters, Nokian winter tires/BFG DRs for the summer. Oh yeah...EVO. Finally went to the strip, 14.029/99.89
BMan is offline
post #27 of 28 (permalink) Old 02-16-2005, 01:48 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
that is extremely vague. It asks nothing of power curves. I think the better idea would be to do an estimated dyno sheet on desktopdyno or something, see what it gives you, and estimate the quarter mile that way. Any knowledgable mn12 person knows what it runs like on a track according to power.
-Thomas
Thomas is offline
post #28 of 28 (permalink) Old 02-16-2005, 06:28 AM
mannysc's Avatar
exactly no mention of tire size gear ratios , temps fuel, alitude, stock suspension?
ive seen stockers smoke the tires all the way , and Ive seen em grab on and launch like a prostocker. 5spd or auto , first gear ratios, s
all effect E.T.s and much more hp is not the ultimate factor!
torque why can a 70 w31 olds with 390 hp keep up with a 70 ss 454 chevelle with 450 hp? Torque also the hemi cuda lighter car 425 hp turned almost same times . why does a ss Impalla turn almost same times as a sc t bird almost same lbs but ss has 345 hp sc 210 hp .
mannysc is offline
