i would like alittle more info on this turbo setup - TCCoA Forums
post #1 of 9 (permalink) Old 06-03-2005, 09:03 AM Thread Starter
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
http://www.turbothunderbird.com/pics.php
Sir Will I seen these pics and i was wondering on how it was done exactly. I can do all the exhaust running and turbo piping but what baffles me is the oil set up. Could you get back to me on this.
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #2 of 9 (permalink) Old 06-03-2005, 10:31 AM
I think that Sir William has the engine oil supply feeding the turbo, with a pump on the return line to ensure that the oil doesn't back up in the turbo. Of course, I could be wrong, but this setup would work fine anyway, provided you have the correct pump.
1997 Lincoln Mark VIII
1998 Contour SVT (for sale)
SloMo228 is offline
post #3 of 9 (permalink) Old 06-03-2005, 12:11 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
He's using the oiling system from the STS rear mount turbo f-body kit.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #4 of 9 (permalink) Old 06-03-2005, 01:10 PM
95BLKLSC's Avatar
holy crap, how's the lag with that crazy long piping?? I've seen kits like that but I've never actually seen it on a car of somone on here. I just didn't realize that's the kti he was using. What happens when you drive in the rain?
My Car Domain Page
95BLKLSC is offline
post #5 of 9 (permalink) Old 06-03-2005, 04:48 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
ok cool ill have to check into the pump and see if he cant give me alittle insight on how it goes.
95blklsc did you see the mesh back that said K&N on it? that stops water from getting into the filter
ZeroRain is offline
post #6 of 9 (permalink) Old 06-03-2005, 05:24 PM
TCCoA Founder
Sir William's Avatar
No lag to speak of, not more than any other turbo car that is. 1/2 to a second or so at speed. As for rain, a bit of water on the road is fine. But a LOT of water is bad. Standing water on the road can be pulled into the intake tract. It just causes a slight miss if you crack open the throttle over 1/2, but it evaporates pretty quickly with all the air passing over it. If it rains that bad, I'll pull over or not drive at all.
As for the oiling system, it's indeed adapted from STS' kit. There are several things I would do differently knowing what I know now, but not tremendously, just a bit.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #7 of 9 (permalink) Old 06-11-2005, 09:04 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I wonder if you could cut a hole in the trunk and stick the air filter in there I know it sounds weird but it could probably work. A little moisture is alright, especially with a turbo, the turbine actually turns it into a mist and it would simulate water injection
-Thomas
Thomas is offline
post #8 of 9 (permalink) Old 06-11-2005, 10:03 AM Thread Starter
5oh Transformer
ZeroRain's Avatar
ok sir will could you tell me what system from sts you got ahold of and tell me how you set this all up? please and thanks
ZeroRain is offline
post #9 of 9 (permalink) Old 06-11-2005, 10:41 AM
Uber Luber
Thomas's Avatar
he's actually prototyping it, so it's not a kit...yet.
Thomas is offline
