compression question - TCCoA Forums
post #1 of 10 (permalink) Old 06-25-2005, 08:50 PM Thread Starter
Hobohuey's Avatar
What would be the easiest (if possible) way to drop the compression without having to go into the short block? After owning a turbocoupe I have an undying love for turbos.
Hobohuey is offline
post #2 of 10 (permalink) Old 06-27-2005, 01:16 PM
Tx_Cat's Avatar
Only way to drop the compression is changing you internals to lower compression ratios(pistons, rods, rings crank), no ther solution and certainly not cheap..
Israel
Tx_Cat is offline
post #3 of 10 (permalink) Old 06-27-2005, 01:21 PM
Or bolt on a set of DOHC heads.... that will lower your CR by about one full point.
And… give you a HUGE nightmare trying to get everything to work!!
And.... 4.6L's have hypereutectic pistons.... which are not the "best" piston for boost.
And… if you're looking to turbo a 4.6L, plan on having deeeeeeeep pockets.
Have fun and good luck.
69 F100 LWB w/460 Engine
post #4 of 10 (permalink) Old 06-29-2005, 04:01 PM
David Neibert's Avatar
You may want to call Cometic and see if they offer thicker head gaskets that will fit your motor. I know they have them for the 5.0.
David
David Neibert is offline
post #5 of 10 (permalink) Old 06-30-2005, 03:27 AM
Refrigerator Raider Hater
GreenBird's Avatar
They do make them for the 4.6, although I have been unable to find exact thicknesses (haven't called them though).
If they make a .090 compressed thinkness it'll drop you to ~8.5:1 compression. .039 is the stock compressed thinkness (technically it's 1mm).
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 10 (permalink) Old 06-30-2005, 05:04 AM
Sweet T
SanDiegoLXBird's Avatar
You could also try alcohol or water injection.
SanDiegoLXBird is offline
post #7 of 10 (permalink) Old 06-30-2005, 11:16 AM
Tx_Cat's Avatar
I think it wouldnt be a good idea on just slaping in the gasket knowing that our internals are really weak when they go above 350HP. I mean, sure compression will go low, but I think more of a future effieciency. Did I make sense?
Tx_Cat is offline
post #8 of 10 (permalink) Old 07-01-2005, 12:08 AM
CAMS
IF you install the correct cam with correct overlap/duration, it can lower EFFECTIVE compression ratio.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
post #9 of 10 (permalink) Old 07-10-2005, 05:08 PM
Send a message via AIM to AtroXR7 Send a message via Yahoo to AtroXR7
Everything I've ever read says water injection is a really BAD solution to things... in the ultimate race application, people do anything and everything to gain an inch, but for street/strip use... no way. 2cc's can be gained by grinding out the swirl fins... but i dont know how the drivability would be when not under boost.
AtroXR7 is offline
post #10 of 10 (permalink) Old 07-15-2005, 04:19 PM
GreenBird's Avatar
Taking out the swirl dams is never a good solution. A thicker HG is the easiest way.
Tx_Cat, while your right the stock shortblock can't take a ton of abuse, lowering the compression ratio allows more boost, making more power for the same cylinder pressures.
96 Alpine Green V8
