Turbo SC progress pic - TCCoA Forums
post #1 of 129 (permalink) Old 07-22-2005, 09:04 AM Thread Starter
David Neibert's Avatar
Thought some of you guys might want to see a progress picture of the turbo system that ForcedFab is building for my 93 SC w/347. The turbo in the picture is just an empty case being used to fabricate the hot side plumbing. The actuall turbo (Percision T76 GTS) will have the compressor outlet facing down into the fender.
It's supposed to be done and ready to start tuning in mid August
David
David Neibert is offline
post #2 of 129 (permalink) Old 07-22-2005, 09:41 AM
Poor alternator.... warm will he be....
And how close is that exhaust to the rubber radiator hose?
69 F100 LWB w/460 Engine
post #3 of 129 (permalink) Old 07-22-2005, 10:25 AM Thread Starter
Both are close enough that they will require heat sheilding. Everything will be ceramic coated and the downpipe will be wrapped. The turbo will have a heat sheild and the wires, hoses and other stuff that are close will get heat reflective cool wrap.
I'm trying to stay with a stock hood, but it may require louvers or some other means of ventilation to keep from melting stuff.
David
post #4 of 129 (permalink) Old 07-22-2005, 11:05 AM
That's cool.... ok, no pun intended.
Even with shielding, that rubber hose may still get hot and swell, if not burst. But SS braided would solve that problem.
Looks nice.
post #5 of 129 (permalink) Old 07-22-2005, 03:18 PM
Overkill Fetish Freak
How much is this install costing you?
Dr. FrankenCougie is offline
post #6 of 129 (permalink) Old 07-22-2005, 08:15 PM Thread Starter
About $7,500 including the injectors, low impedance resistor boxes and full exhaust system.
David
post #7 of 129 (permalink) Old 07-24-2005, 12:23 AM
thats kind of how I had planned on mounting my two, but its great to see that it actually works that way. How much room is there in the side of the fender for the air filter?
Wicked6 is offline
post #8 of 129 (permalink) Old 07-24-2005, 11:48 AM Thread Starter
With a 90 degree elbow there should be plenty of room for a large cone filter. It's pretty much the same area that MAC and ZR intakes place the filter on an SC.
The drivers side of the car is much more crowded and would require relocating the power distribution box, the battery and the washer fluid tank. I'm having trouble even fitting an overflow bottle for the coolant on that side.
David
post #9 of 129 (permalink) Old 07-24-2005, 03:36 PM
BMan's Avatar
I've always wondered if a big turbo would outflow a supercharger and build more pressure in the intake pipe than in the combustion chamber.
That aside, that should be awesome. 1000hp with no lag, yowza!
You may want to do a water/methanol spray to help prevent detonation under high boost cooling mist injectors
'97 4.6...Gen II reflashed EEC, 99+ control module, J-Mod, 3:73 FRPP rear, Magnecore wires, High-flow cats, 3" into 2 2.5" Flowmasters, Nokian winter tires/BFG DRs for the summer. Oh yeah...EVO. Finally went to the strip, 14.029/99.89
BMan is offline
post #10 of 129 (permalink) Old 07-24-2005, 08:48 PM
well I'll also be fitting a water/air cooler in the fender right where the air silencer used to be, and then another one in the same spot on the driver side, below where the battery used to be. The battery is already in the trunk but I still need to relocate the fuse box into the fender and I'd like to place the starter solenoid somewhere out of the way too, probably in the fender with everything else, since thats where my battery wire is anyway.
Wicked6 is offline
post #11 of 129 (permalink) Old 07-24-2005, 08:51 PM
I dont know about 'outflowing' because it all depends on the supercharger and the turbo. But turbos consistantly produce more torque per psi than superchargers do, and similar horsepower, and they also dont rob power from paracitic drag like superchargers do. Here's an example, one guy with a twin screw autorotor on his v6 made 330rwhp at ~18psi (I believe) and maxed out his 42# Injectors, where another guy with twin turbos on a stock longblock made 450rwhp at 17psi and still has room left in his 42# Injectors.
Wicked6 is offline
post #12 of 129 (permalink) Old 07-24-2005, 10:09 PM Thread Starter
I have already purchased a water/alky injection kit from Snow Performance. It has the , boost activated progressive controller, 7 qt trunk mounted tank, 220 psi pump and dual nozzels. Should be able to get real close to my 800 rwhp goal using pump gas with the alky injection.
David
post #13 of 129 (permalink) Old 07-24-2005, 11:21 PM
TCCoA Founder
Sir William's Avatar
Yikes Dave. I can't wait for a ride in that beast. I may have to make a trip up to STL before next year's WFC.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #14 of 129 (permalink) Old 07-25-2005, 08:19 AM Thread Starter
Bill,
Just make the trip over to OKC this fall for the Shootout and you can drive it then.
David
post #15 of 129 (permalink) Old 07-25-2005, 11:36 AM
TCCoA Founder
Great, I'd planned on coming anyway.
Sir William
TCCoA Founder
post #16 of 129 (permalink) Old 07-31-2005, 06:09 AM
seawalkersee's Avatar
Anything new on the STS system bill?
Chris
seawalkersee is offline
post #17 of 129 (permalink) Old 07-31-2005, 09:54 PM
TCCoA Founder
Not yet seawalkersee. Hopefully by then.
Sir William
TCCoA Founder
post #18 of 129 (permalink) Old 08-02-2005, 07:35 AM
Send a message via AIM to Slysc
Dave,
Looks great. Can't wait to see it.
Are you leaving the IRS in that car?
Are you going to intercool it? If so, what are you doing for an intercooler?
What size turbo is that?
Dan
Dan Sly
91 T-bird SC
Slysc is offline
post #19 of 129 (permalink) Old 08-02-2005, 10:05 AM
Tx_Cat's Avatar
Originally Posted by Slysc
Dave
Dave
Dave
I belive he should leave it, why would you want an open diff?
Tx_Cat is offline
post #20 of 129 (permalink) Old 08-02-2005, 10:06 AM
Tx_Cat's Avatar
Oh, BTW David, aswome bro Can't wait to see it done. Make sure to take vids bro.....
Israel
Tx_Cat is offline
post #21 of 129 (permalink) Old 08-02-2005, 10:46 AM
That car is NEVER going to run like that...the plug wires arent even hooked up...800 hp my eye...
Chris
post #22 of 129 (permalink) Old 08-02-2005, 11:27 AM
Tx_Cat's Avatar
Chris
Have you ever heard the word "Progress?" Who said it was finished? Come on Chris, dont be jealouse man
Tx_Cat is offline
post #23 of 129 (permalink) Old 08-02-2005, 11:29 AM
Get err dun!!!!
-Scott
post #24 of 129 (permalink) Old 08-02-2005, 02:07 PM
And one of these days you will see the humor in that. You should check out the SCCoA site for the delays in this project. I have to say that Dave is a VERY patient man. I would be very unhappy with the time delays that he had faced...I was merely making note since the housing in the pic is empty.
Chris
post #25 of 129 (permalink) Old 08-02-2005, 02:33 PM
Tx_Cat's Avatar
Chris
Believe me, I know about the delays man.... They have taken their sweet time, and yes, I saw the humor in it, didnt you?
Israel
Tx_Cat is offline
post #26 of 129 (permalink) Old 08-02-2005, 02:38 PM
Guess Im kinda stoopid
Chris
post #27 of 129 (permalink) Old 08-02-2005, 06:00 PM
I belive he should leave it, why would you want an open diff? [/QUOTE]
He would replace the IRS with an 8.8" solid axel because he will break the IRS axels too often.
Dan Sly
91 T-bird SC
Slysc is offline
post #28 of 129 (permalink) Old 08-03-2005, 01:36 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
nonsense, I'm very confident that they IRS would hold up, it would just take some strengthening, which isnt hard at all. What's the point of a fast car if it cant corner well? IRS is half the novelty of an MN12.
-Thomas
Thomas is offline
post #29 of 129 (permalink) Old 08-03-2005, 04:02 PM
That should do it..
Delays during a project?? Whoever heard of such a thing...
Get 'er done!!
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #30 of 129 (permalink) Old 08-04-2005, 09:55 AM
95BLKLSC's Avatar
wow those are some mean looking half shafts!!!! how much do those bad boys go for?
My Car Domain Page
95BLKLSC is offline
