Turbo terminology - TCCoA Forums
post #1 of 3 (permalink) Old 08-08-2005, 03:07 PM Thread Starter
Send a message via AIM to Slysc
Question Turbo terminology
Looking at the Turbonetics flow maps for their turbos, I have determined that the best size for my application would be a T66 P.68AR or T66 P.81AR.
What do those numbers stand for/ what does that mean?
Sorry for the stupid question.
Dan Sly
91 T-bird SC
Slysc is offline
post #2 of 3 (permalink) Old 08-08-2005, 03:42 PM
David Neibert's Avatar
Dan,
Here is a link to Turbomustangs.com that's called the knowledge base...look under the turbo bible section to get the answers to just about any turbo question you have.
http://www.turbomustangs.com/turbofaq.php
T66 means 66mm inlet
P means what trim the compressor wheel is
AR is something about the size of the exhaust housing area and scroll radius expressed in a ratio.
David
David Neibert is offline
post #3 of 3 (permalink) Old 08-08-2005, 08:10 PM
Hobohuey's Avatar
the .68 will spool faster than the .81 but it will stop building boost for the engine at a higher rpm.
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
