Turbo SC dyno video from Shootout - TCCoA Forums
post #1 of 36 (permalink) Old 10-12-2005, 04:46 PM Thread Starter
David Neibert's Avatar
This was a pull I made at the Shootout over the weekend. I had not yet set the boost controller so it initially made 14.3 pounds of boost but dropped to 12.1 by the end of the pull. Ended up making 495 rwhp & 563 rwtq.
http://s92895651.onlinehome.us/David+N+495HP+Run.mov
right click save as
After making the dyno pulls we set the e-boost controller to hold 15 psi and tested it on the street. It felt considerably stronger than the couple of street runs we made prior to dynoing the car, but I'm not really sure how much stronger it was because it was too late in the day to get it back on the dyno.
The following day we went to the track. The first pass wasn't very impressive except for the MPH...it wouldn't spool up until I was about 300 ft. down the track and it ran a 12.9 @ 129. Blew a HG on the second pass as soon as I shifted into 3rd...too bad because I was up 2 mph in the 1/8 and was on track for 131 mph in the 1/4. What makes it impressive is the car was the heaviest at the Shootout with a 4250 lb. race weight. According to several of the calculators it takes over 650 rwhp to go that fast.
Not sure why the HG blew, because they are Cometics and aren't supposed to blow before bending a rod or breaking a piston first. I guess I'll find out when I pull the heads in a couple days.
David
David Neibert is offline
post #2 of 36 (permalink) Old 10-12-2005, 05:07 PM
TCCoA Founder
Sir William's Avatar
Man, with a higher stall converter and the boost all dialed in, that's gonna be one wicked runner. Congrats on the job so far. Now comes the working-kinks-out phase...good luck!
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #3 of 36 (permalink) Old 10-13-2005, 08:50 AM Thread Starter
Thanks Bill...so far I'm very happy with the performance of the car and have no doubt I will reach my 800 rwhp goal. When this thing spools up it's a rocket that never stops pulling.
In 1st the boost comes on so hard that it spins the tires and pegs the tach quicker than I can shift into second, so staying off the rev limiter is difficult. The e-boost controller I'm using can correct that but it wouldn't be nearly as much fun.
David
post #4 of 36 (permalink) Old 10-13-2005, 03:29 PM
Send a message via MSN to 96CougarXR7 Send a message via Yahoo to 96CougarXR7
That car is a V6? If it is, you are putting us V8 owners to shame. :P
96CougarXR7 is offline
post #5 of 36 (permalink) Old 10-13-2005, 05:25 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
347 Stroker, turbo'd.
...and it was MUCH cooler in person.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #6 of 36 (permalink) Old 10-14-2005, 12:35 PM
Tx_Cat's Avatar
Congrats David, REALLY impressive bro...
Tx_Cat is offline
post #7 of 36 (permalink) Old 11-08-2005, 04:29 PM Thread Starter
Pulled the heads off last week and one side had two blown cylinders and the head was torched where it was leaking. I also noticed that all the exhaust valve seals had blown off the guides.
While the heads are being repaired, I've decided to pull the motor and tear it down to inspect all the bearings and fix the leaking front and rear main seals. I'm ditching the AC because I know I'll never get around to having a custom condensor coil made. That and I need the space currently occupied by the drier to mount a catch can.
I also had a pumkin built up with an Auburn Pro limited slip diff and a set of factory Ford 3.73s to replace the 3.27s and the stock trac loc thats in there now. That should help the tranny to run a little cooler and get this heavy car off the line and into the boost a little quicker.
Should have it all back together in a month or so and will start finding the next weakest link.
David
PS: This link has some pics of the damage caused from the heads not being torqued down tight enough.
http://www.sccoa.com/forums/showthre...ootout+cometic
post #8 of 36 (permalink) Old 11-09-2005, 09:32 AM
Tx_Cat's Avatar
Wow, just wow David, I never thought it was that bad man. Hopefully you'll get it up and running fast man
Tx_Cat is offline
post #9 of 36 (permalink) Old 11-09-2005, 09:56 AM
Send a message via AIM to trife86
ah my hosting is still holding up very well
trife86 is offline
post #10 of 36 (permalink) Old 11-09-2005, 04:50 PM Thread Starter
Yeah it looked a little worse than I expected too. While the heads are in the shop I'm having a little extra work done to them to prevent the gaskets from failing in another area.
Crossing my fingers that everything is okay inside the motor. Should be back together soon. I'm not really in any hurry because I've still got my 91 in perfect running order.
David
PS: trife, thanks for hosting the video.
post #11 of 36 (permalink) Old 11-09-2005, 05:35 PM
On Probation
blown96bird's Avatar
It is still a great video.
Dose anybody have a video of my car on the dyno?
blown96bird is offline
post #12 of 36 (permalink) Old 11-10-2005, 08:00 PM
96TBirdMan's Avatar
Send a message via AIM to 96TBirdMan
That thing is SICK, great job man.
Justin
Nitrous is like a hot girl with STD's everybody wants to hit it, but is affraid of the consequences.
Eat Rice don't Drive it.
Stock 4.6 RIP......begin Project Kenne Bell 351
there is no replacement for displacement
96TBirdMan is offline
post #13 of 36 (permalink) Old 11-17-2005, 03:56 PM
Send a message via AIM to 94TbirdV8
That is one sick car man, couple questions for ya. what tranny are you running and did you beef it up, thats a lot of power for a basically stock tranny and rear-end. 2nd is you motor a 5.0 that was stroked to a 347 or is it a crate. Good work and hope the bird is up and running soon.
Bryan
HAVE YOU CHASED A BIRD LATELY???
SPEED KILLS. SAVE LIVES. DRIVE A HONDA!!!
The yellow street beast!!!
AIM:TBirdRacingV8
2nd car: 95 supercoupe 5spd fully loaded with 13k original mileage. Can You Say TORQUE????
R.I.P Joel
94TbirdV8 is offline
post #14 of 36 (permalink) Old 11-17-2005, 04:28 PM
DakotaEpic's Avatar
Wow, that's some tough luck. Sorry CHP fell through. Are your heads 165's, 185's ??? Good luck getting that beast back on the road.
DakotaEpic is offline
post #15 of 36 (permalink) Old 11-17-2005, 09:24 PM Thread Starter
Bryan
Thanks, the transmission is a custom Lentech AOD with soild input shaft and strip terminator Reverse/Third valve body. It's rated at 1000 HP.
The rear end was stock but the new one I just got built with the Auburn Pro diff should be alot stronger. Should be okay unless I launch real hard with sticky tires.
The motor was also custom build to my specs. It's built around an 8.2" deck Dart 302 block. Yes a forged stroker crank to get 347 CID.
Heads are AFR 205s.
David
post #16 of 36 (permalink) Old 11-17-2005, 09:55 PM
Well i am sorry guys my hosting just went down. im going to try and get it back up on another server until than the link is down
trife86 is offline
post #17 of 36 (permalink) Old 11-24-2005, 02:06 PM
seawalkersee's Avatar
I was dissapointed that you were not there Sir Will. I was SOOOO looking forward to seeing the 4.6 Turboed bird.
Chris
seawalkersee is offline
post #18 of 36 (permalink) Old 12-11-2005, 10:05 AM
Nativedetroiter's Avatar
Wow, I don't want to use the word impressive, rather depressing, that kind of money sunk into an engine and something so simple, tighten head bolts to specs. If I did that at my job, I would be in leavenworth smashing small rocks smaller. Good luck, hope to see that thing in vids soon!
Nativedetroiter is offline
post #19 of 36 (permalink) Old 12-11-2005, 11:11 AM
JustinH's Avatar
ugh the link is dead, anyone want to rehost?
JustinH is offline
post #20 of 36 (permalink) Old 12-15-2005, 08:55 AM
yeah I saw this a week ago and the link was dead and I didn't wanna hassle anyone but since justin asked... how about a rehost
FunktasticLucky is offline
post #21 of 36 (permalink) Old 12-22-2005, 03:39 PM
David
Did you ditch the AC yet, i would love to see a picture step by step of that done cause i would like to do the same. Very nice work you've done.
post #22 of 36 (permalink) Old 12-24-2005, 12:27 PM Thread Starter
While making repairs to the motor, I am ditching the AC. I've already started reassembling the motor and should have it back in the car within a couple weeks. Fine tuning for streetability will likely be the biggest challenge. The stock EEC and SCT chip I'm using now may need to be upgraded to a standalone system if I can't get rid of a few quirks.
David
post #23 of 36 (permalink) Old 12-24-2005, 09:16 PM
Can you host that vid again David? I STILL have not seen it.
Chris
post #24 of 36 (permalink) Old 12-27-2005, 03:45 PM Thread Starter
Chris
Chris,
It wasn't me that hosted it. I'm sure Bill could host it here...I don't have enough space.
David
post #25 of 36 (permalink) Old 12-27-2005, 07:39 PM
Teeps's Avatar
I can host it as well, just added 200gb to my server.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #26 of 36 (permalink) Old 12-29-2005, 01:11 PM
TCCoA Founder
I'll gladly host it Dave. Just send it my way. No biggie.
Sir William
TCCoA Founder
post #27 of 36 (permalink) Old 12-30-2005, 05:29 PM
13's or Mildly Broken
I've got a video of Dave on the dyno as well. I'd upload it, but GlobeDomain bites my butt. PM or e-mail me if you can upload it in case I miss the post
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #28 of 36 (permalink) Old 01-31-2006, 08:56 AM Thread Starter
Did anyone ever e-mail Bill the video ?
David
post #29 of 36 (permalink) Old 01-31-2006, 12:08 PM
Tx_Cat's Avatar
Hey David, long time man, you never answered my email bro... I see how it is...........
Tx_Cat is offline
post #30 of 36 (permalink) Old 02-01-2006, 07:48 AM Thread Starter
Sorry, my e-mail has been really screwed up for the past week or two, just got it fixed yesterday. Please resend or PM me.
David
PS: Got the turbo car running again yesterday.
