who has a twin turbo mn12 (front mounted) - TCCoA Forums
post #1 of 16 (permalink) Old 02-24-2006, 09:35 PM Thread Starter
who has a front mounted twin turbo mn12?
pictures?
boba is offline
post #2 of 16 (permalink) Old 02-25-2006, 11:27 AM Thread Starter
does anyone have one?
boba is offline
post #3 of 16 (permalink) Old 02-25-2006, 12:01 PM
platinummotorsports's Avatar
Send a message via AIM to platinummotorsports Send a message via Yahoo to platinummotorsports
someone has a i believe 1 front mounted turbo but i forgot his name.
platinummotorsports is offline
post #4 of 16 (permalink) Old 02-25-2006, 02:14 PM Thread Starter
i'm sorry. i meant does anyone have 'one' twin turbo setup? not just 'one' turbo.
boba is offline
post #5 of 16 (permalink) Old 02-25-2006, 07:05 PM
NiteFire's Avatar
its hard enough getting 1 turbo in the front. I highly doubt there is a twin setup
NiteFire is offline
post #6 of 16 (permalink) Old 02-26-2006, 04:19 PM
Send a message via AIM to 187bird
on a 5.0 or a 3.8 I dont see any problem with mounting one, or a twin turbo setup up front. I havent messed w/ a 4.6 thunderbird to really say anything. There is a turbo "Sc" on V6power and i'm sure its on sccoa. I dont see what the major issue is with running a turbo setup on a 3.8 or a 5.0...theres plenty of room..well there might be a problem w/ the turbo headers...but if you can find someone to make them for ya...then i dont see a problem.
Now for you guys with a 4.6...I dont see how you guys even can get around those things...4.6's are some monsters of a motor...
187bird is offline
post #7 of 16 (permalink) Old 02-26-2006, 05:17 PM
dwinthrup's Avatar
[QUOTE=187bird]on a 5.0 or a 3.8 I dont see any problem with mounting one, or a twin turbo setup up front. I havent messed w/ a 4.6 thunderbird to really say anything. There is a turbo "Sc" on V6power and i'm sure its on sccoa. I dont see what the major issue is with running a turbo setup on a 3.8 or a 5.0...theres plenty of room QUOTE]
you say funny things there is very little room under the hood of the things it not even funny
dwinthrup is offline
post #8 of 16 (permalink) Old 02-26-2006, 06:13 PM
David Neibert's Avatar
The 5.0 will be the easiest, because the engine is narrower than the 3.8 or the 4.6. If you remove the air pump there is enough room for a rather large single on the passenger side. If you delete the AC, relocate the battery and power distribution box there is room for twins. Front mount IC and related cold side piping is easier on a single but with the correct intercooler twins are possible, just more difficult.
Here's some pictures of my 93 SC with a dart block 347 and single T-76 turbo. I've been working on this car for more than 2 years...trust me it wasn't easy.
http://www.sccoa.com/forums/showpost...4&postcount=16
David
David Neibert is offline
post #9 of 16 (permalink) Old 02-26-2006, 08:24 PM
I really dont see what i said was funny dwinthrup...I have the fuse box moved, the battery is in the trunk, and I took out the AC on my car....I have plenty of room. No ac condensor in front of the radiator, plenty of room for the intercooler, run the turbos off each header, run the piping to the intercooler and up to the throttle body, then run the exhaust pipes out. If need be, convert to a manual rack and do away with the power steering and you got even more room on the driver's side. For a street car that might not be the best option, but if you just must do a twin setup(over a single), and need the extra room,I think it would be worth it personally.
* If i'm wrong...please excuse me, i'm just a 17 year old kid and trying to learn as I go, and if what i say is wrong, so be it and i'll learn from it.*
187bird is offline
post #10 of 16 (permalink) Old 02-26-2006, 10:55 PM
THNDRN 1's Avatar
Did you see the DOHC front mounted turbo bird in the Videos/Images section?
http://forums.tccoa.com/showthread.php?t=57766
Not a twin front mount but still impressive
THNDRN 1 is offline
post #11 of 16 (permalink) Old 02-27-2006, 11:30 AM
getblown's Avatar
David
Hey, if you know how to weld and move things, especially the AC and battery, its just a matter of time and finding the right turbo
jOe
p.s. that 347 is bad ***
94 Opal LX - 4v, cobra intake, remote3650, 3.73s, Detroit Trutrac. Duals and xpipe.
I need to tune this beast...
The LSC is gone.
getblown is offline
post #12 of 16 (permalink) Old 02-27-2006, 10:30 PM
She might not have a MN-12 but it is a twin turbo and one of the fastest Thunderbirds
Go to Sarahs tread for more info
http://forums.tccoa.com/showthread.php?t=78947
post #13 of 16 (permalink) Old 02-27-2006, 11:34 PM
jk69cat's Avatar
david, i have to ask, was it worth all the work? i am capable of the fabrication, but is the end product worth it?
mn12 less!
jk69cat is offline
post #14 of 16 (permalink) Old 02-28-2006, 01:01 PM
Depends on what you mean by "worth it ".
From a financial standpoint...No.
From a personal sastisfaction standpoint... Yes.
David
post #15 of 16 (permalink) Old 03-09-2006, 08:51 PM
Flying Thunder
weswing04's Avatar
Send a message via AIM to weswing04 Send a message via Yahoo to weswing04
[QUOTE=dwinthrup]
try working on a 4.6, the 3.8 and 5.0 have TONS and TONS of room compared to the 4.6
weswing04 is offline
post #16 of 16 (permalink) Old 03-09-2006, 09:37 PM
Whining Intakes Rock
Al_Florida's Avatar
More pics and info on that dohc tbird:
http://www.racerelated.com/RR%20cobra.htm
# 0 rows returned
# drop table users;_
Al_Florida is offline
