Twin entry turbine vs singel entry VNT's - TCCoA Forums
post #1 of 8 (permalink) Old 03-27-2006, 01:47 PM Thread Starter
What would be best for a VNT? Twin entry och singel entry?
Diesel n'Dust is offline
post #2 of 8 (permalink) Old 03-28-2006, 03:52 PM
David Neibert's Avatar
What's a VNT ?
David
David Neibert is offline
post #3 of 8 (permalink) Old 03-28-2006, 04:03 PM
tomaso12's Avatar
http://www.honeywell.com/sites/ts/tt...s_VNTworks.htm
= one expensive turbo, but a damn good one.
All MN12/FN10 PA/NJ/MD/DE/NY people please check out: TSTaCC, feel free to register & say hi
'Krissy' 1997 Thunderbird LX Sport 281ci
Custom doesn't come in a Box
Slide or Die
tomaso12 is offline
post #4 of 8 (permalink) Old 03-28-2006, 07:14 PM
Tx_Cat's Avatar
Originally Posted by David Neibert
What's a VNT ?
David
I was going to ask the same thing... Just get a plain turbo, will work too
Israel
Tx_Cat is offline
post #5 of 8 (permalink) Old 03-30-2006, 01:51 PM Thread Starter
I'd just like to know if singel entry would work for effektive pulse utilization say on a V8 engine or twin entry works better - especially at low revs. How does the variable nozzle affect the pulse utilization (pulse charging vs constant pressure with variable nozzle).
post #6 of 8 (permalink) Old 03-30-2006, 07:35 PM
You should probably ask the company that builds them. I don't really think anyone here has experince with that type of turbo. Another website that has a great deal of info on turbocharging is turbomustangs.com
David
post #7 of 8 (permalink) Old 04-28-2006, 10:14 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
a twin entry or "split tangenial AR housing flange" would be the best for the money. Actually, dave, isnt yours a split tange? I never saw the AR housing, but the way your exhaust feeds in to it it sure looks that way. The only problem is fitting two exhaust pipes up to the one turbo, wherever you decide to mount it (options are somewhat limited on a 4.6) the engine bay is pretty cramped for fitting two pipes up and the downpipe.
-Thomas
Thomas is offline
post #8 of 8 (permalink) Old 04-28-2006, 11:39 PM
-Thomas
Thomas,
Nope, mine is a single opening with a T04 flange (Precision T76-GTS)...The slightly larger Garrett GT42-76R has a split exhaust housing if configured with a T04 flange, but most people use them with a T06 flange. Not sure if it's split or not.
David
