Latest round of dyno testing - TCCoA Forums
post #1 of 9 (permalink) Old 04-08-2007, 08:37 AM Thread Starter
David Neibert's Avatar
After replacing the motor mounts, timing cover and balancer I tried doing some more dyno testing/tuning. Unfortunatley everytime we got to around 660 rwhp the boost would suddendly drop off and then recover. This thread over on turbomustangs has some dyno charts and videos of the car that I thought you guys might be interested in seeing.
http://www.theturboforums.com/smf/in...?topic=81156.0
David
PS: Car runs great on the street....can't wait to see what it does at the Dayton meet next month.
David Neibert is offline
post #2 of 9 (permalink) Old 04-08-2007, 09:31 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
holy balls!!
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #3 of 9 (permalink) Old 04-08-2007, 08:43 PM
96bird's Avatar
Very nice power...definitely not everyday that you see a street 'bird with that kind of power.....and a turbo.
Russ
96bird is offline
post #4 of 9 (permalink) Old 04-08-2007, 08:48 PM
CobraRThunder's Avatar
Yes yes the dayton meet, cant wait. So I'll get to see it full tilt...sweeet!
4R70W From DirtyDog
CobraRThunder is offline
post #5 of 9 (permalink) Old 04-08-2007, 10:36 PM Thread Starter
Chris,
Yes...full tilt. Should be making close to 800rwhp at the track
David
post #6 of 9 (permalink) Old 04-08-2007, 10:42 PM
CEO, WT Club
GODSPEED's Avatar
Originally Posted by David Neibert View Post
Chris,
David
**** cracker taco bell!
Amazing work David, you ever gonna make it over to the west side of the state to show it off?
-Joel
Previous MN12s:
GODSPEED is offline
post #7 of 9 (permalink) Old 04-11-2007, 05:23 PM
Tx_Cat's Avatar
So your problem are the tires?! That's whats causing your boost problem?!
Tx_Cat is offline
post #8 of 9 (permalink) Old 04-11-2007, 07:49 PM
jk69cat's Avatar
wow i think its time for a power adder
mn12 less!
jk69cat is offline
post #9 of 9 (permalink) Old 04-11-2007, 11:08 PM Thread Starter
I think it's a lack of load.....others think the tires are spinning. If you take the load off a turbo motor the boost will start falling, so either one could cause it. Doesn't have that problem on the street or a load bearing dyno...just a dynojet. It's not really a problem, just annoying that I can't get a clean pull on the type of dyno that is the easiest for me to get on for testing.
There is another place in the area with a load bearing dyno (mustang) but it cost more and needs to be scheduled in advance. I've made enough pulls at around 20 pounds to feel comfortable that racing it at that or a bit higher power levels won't hurt the motor, so I'm not really concerned about the dyno problem.
My biggest concern is using real slicks and launching off the trans brake. The drag radials are much more stable above 100 mph, but I just don't think they will grip well enough. Doubt the track officals at KilKare are going to allow me to make very many passes without a roll cage, so I plan to start off with about 22 pounds of boost (well over 700 rwhp).
David
