transmission swap - TCCoA Forums
post #1 of 8 (permalink) Old 07-06-2007, 04:01 PM Thread Starter
94thunderchicken's Avatar
transmission swap
Can someone tell me if there is any threads that can tell me about transmission swaps?
94 lx : sold
94thunderchicken is offline
post #2 of 8 (permalink) Old 07-06-2007, 04:03 PM
The Great Obucina's Avatar
there is an entire thesis about it in the tech articles.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 8 (permalink) Old 07-06-2007, 04:13 PM Thread Starter
which ones do i did to look at? i have a t-5 or a t-4 out of a mustang that i need to put in my 88 turbo coupe and i need help to do it. thats why i need to know which threads.
thanks
94 lx : sold
post #4 of 8 (permalink) Old 07-06-2007, 04:17 PM
Bradone's Avatar
thanks
This should at least give you some ideas:
http://www.tccoa.com/articles/tranny/T45/index.html
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #5 of 8 (permalink) Old 07-06-2007, 04:24 PM
thanks
tuurbocoupe is a fox body....its not any different than a trans swap in a fox body.
post #6 of 8 (permalink) Old 07-07-2007, 12:56 AM
fox body is a direct bolt in. Just go get everything off a 5-speed mustang. Only thing that will be different is the driveshaft, but I'm pretty sure you can just swap the T5 yoke onto your AOD driveshaft and it will work. Also the flywheel for the 2.3 is probably different than on the 5.0, so pick up a clutch and flywheel for a 5-speed turbo coupe.
MadMikeyL is online now
post #7 of 8 (permalink) Old 07-07-2007, 10:04 AM
rbrown's Avatar
The T-5 for the 2.3 was different than the 5.0.
http://www.allfordmustangs.com/Detailed/349.shtml
This is pretty good too.
http://www.fordmuscle.com/archives/2000/09/t5swap/
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #8 of 8 (permalink) Old 07-07-2007, 04:16 PM
SuperNewbie
supergordo's Avatar
great info thanks! I wasnt even asking, but i have a friend trying to swap a T-5 into his 66 mustang. great timing!
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
