1988 TC clutch - TCCoA Forums
post #1 of 23 (permalink) Old 07-20-2007, 10:29 PM Thread Starter
Send a message via Yahoo to Jim Allen
1988 TC clutch
Does a 1988 TC have a hydraulic clutch or a cable clutch like a 1986 TC?
Jim Allen is offline
post #2 of 23 (permalink) Old 07-21-2007, 01:42 AM
Baby Huey
warmaster259's Avatar
cable
Jim
warmaster259 is offline
post #3 of 23 (permalink) Old 07-21-2007, 09:05 AM
ipsd1's Avatar
The 87-88 Tc's have a HYD clutch. The 83-86 have cable.
Flyin with the bird's or runnin with the cat's either is better than ridin horses!
84 Turbo Coupe 2.3T, 88 intercooler/intake setup, T3-4 hyrbrid .60 trim, PC1 ECU, 35lbs/hr injectors, runnin 15psi
94 cougar xr7 inprocess of getting body fixed gonna be the new daliy, Then the turbo coupe get piant & body
ipsd1 is offline
post #4 of 23 (permalink) Old 07-21-2007, 06:45 PM
Baby Huey
Wow, news to me.
Jim
post #5 of 23 (permalink) Old 07-22-2007, 11:51 AM
Slacks 12 months a year
LX-Tasy's Avatar
Yep, the 87-88 switched to the hyd. set up while pre-87 had the cable.
"My Other Ride Is Your Girl"
LX-Tasy is offline
post #6 of 23 (permalink) Old 08-18-2007, 08:24 PM
88 turbo
yep, the 88 has hyd. I have a "carcass" in the back that is gittin hauled off soon as I get a chance. I have the 5 speed and parts plus the clutch setup. Have found no interest in them-----hate that, dont want to trash the useable stuff---
yardbird is offline
post #7 of 23 (permalink) Old 06-06-2008, 04:06 AM
Can anyone send me some pictures of the master cylinder location and how it hooks up to the clutch pedal assembly?
MACHVII is offline
post #8 of 23 (permalink) Old 06-06-2008, 07:07 AM
Was it still a T5? If so, could this setup possibly be used with an SC pedal and the TC master and slave to put a 5-speed in an MN12?
post #9 of 23 (permalink) Old 06-08-2008, 05:00 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
Mikey if Im not mistaken it was a T5. I know the stangs kept the T5 all thru the fox era and I believe the fox birds were aswell.
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #10 of 23 (permalink) Old 06-08-2008, 11:20 PM
Hobohuey's Avatar
T-5's were used in the mustangs up through the 95 model's. When they switched over to the t-5 was when they went to the T-45. The 4-cyl t-5s have different gear ratios and a different input shaft. I believe the 86-88 had the world-class t-5 with the upgraded syncros.
The master cylinder to the clutch is under the brakes master cylinder. Its held in place with two metal screws and the MC rod slips over a nipple on the clutch pedal arm. A nylon line runs down to the slave cylinder claped on the side of the bell housing. The slave cylinder pushes on a fork which pushes on the T.O. bearing.
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #11 of 23 (permalink) Old 06-09-2008, 12:31 AM
So then if you got that slave and bracket, it could be used on the side of a T5 in an MN12, right? Does the hydraulic line attach with the same fittings as they used on the SC? Do you happen to know the bore diameter of the TC slave?
post #12 of 23 (permalink) Old 06-09-2008, 01:19 AM
Hobohuey's Avatar
The bracket is really just a u-shaped fork that is cast as part of the bellhousing. Then a plastic cover bolts over it to just kinda hold it in place. If you could find a way to bolt it or clamp it to the side then sure, it could be used. I dont know about your other questions but I would be suprised if the master cylinders are different.
Have you thought about the length problem with the t-5's shifter not sitting far back enough? What are you thinking of doing to correct this?
Hobohuey is offline
post #13 of 23 (permalink) Old 06-09-2008, 03:30 AM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
You could talk to Jimbobicious here and ask him how he dealt with that issue.
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #14 of 23 (permalink) Old 06-09-2008, 08:07 AM
The length won't be an issue. I had a 94 cougar I did a T45 swap on, and I will be doing another T45 swap on my MarkVIII. I'll just build a bolt-on relocation for the shifter using a heim joint and linkage to have the handle coming up in the stock location, but not cutting up or welding onto the T45. I never liked the idea of the shifter extension box. I'm actually not planning on doing a T5 swap at all, I was just exploring this to open up doors to other people who do want to do a 5-speed swap.
post #15 of 23 (permalink) Old 06-29-2008, 10:28 PM
88TurboCoupeman01's Avatar
Send a message via AIM to 88TurboCoupeman01 Send a message via Yahoo to 88TurboCoupeman01
Yes thetrans is a T-5
Yes the Mnual Trans are T-5s and I believe the all automatic Thunderbird including the Turbo Coupe had a AOD 4 speed. If I not right Please tell me.
http://en.wikipedia.org/wiki/List_of_Ford_transmissions
88TurboCoupeman01 is offline
post #16 of 23 (permalink) Old 06-30-2008, 10:30 PM
Pony Boy's Avatar
Send a message via AIM to Pony Boy
Only the 87-88 Turbo Coupes had the 4 speed AODE. The 83-86 TC's had a C3 3-Speed automatic in them.
Pony Boy is offline
post #17 of 23 (permalink) Old 06-30-2008, 11:25 PM
Hobohuey's Avatar
if im not mistaken all the tc's had a4ld's in them. junk transmissions which is why all auto tc's were detuned from the factory.
Hobohuey is offline
post #18 of 23 (permalink) Old 07-01-2008, 08:25 AM
Pony Boy's Avatar
Whoops, my mistake. The 4-speed auto was an A4LD, not AODE. But only the '87-'88 TC's had the 4-speed A4LD. The '87-'88 TC automatics were detuned from the factory, but from '83-'86 the autos with the C3 tranny made the same horsepower as the manuals. My '86 has the C3 3-speed, and I have done a couple mods to bump up the horsepower, and it's taking all the abuse I can give it. With the A4LD, you have to take it easy on the mods if you want to keep the tranny alive.
1995 Thunderbird LX 4.6 Gone but not forgotten!
1986 Thunderbird Turbo Coupe '87 Intercooler, '87 Hood, LA2 Computer, Gillis Boost Valve.
1994 Mustang GT 5.0, 5-Speed.
1982 Yamaha Seca Turbo
Pony Boy is offline
post #19 of 23 (permalink) Old 07-01-2008, 10:08 PM
Hobohuey's Avatar
Yep your right.
The only reasons the autos made the same power as the manuals in the 83-86 models was because the t-3's were non-intercooled, so they were limited at 10lbs of boost accross the board. The 87-88's had the top mount intercoolers so the boost could be boosted to 15#s.
The a4lds are the same as the c-3 just with overdrive, but their french built. Might have something to do with why the early versions were junk.....
Hobohuey is offline
post #20 of 23 (permalink) Old 07-02-2008, 10:11 AM
Pony Boy's Avatar
Just out of curiosity, are the C3's supposed to be as weak as the A4LDs? I haven't heard about many junk C3's as opposed to everyone complaining about their junk A4LD's.
Pony Boy is offline
post #21 of 23 (permalink) Old 07-03-2008, 04:10 PM
Hobohuey's Avatar
I think they are the smae design but the a4lds suffered from severe overheating problems (maybe from design changes to add the overdrive) and I think were built cheaply from sub-standard materials. Another big problem was the torque converters would come apart and take the pump and the rest of the transmission with it.
The newer versions of the a4ld are much much better and are still being used as a 5-speed auto now, its called the 5R55.
There is a guy on NATO in the 12 or 13's running a built c-3 from a 74 fairmont.
Hobohuey is offline
post #22 of 23 (permalink) Old 07-03-2008, 05:44 PM
Send a message via AIM to pouter
header valve
hey does anyone have a header valve for a 2.3 turbo laying around i need one for the back off the turbo going into the exhaust mines broke
pouter is offline
post #23 of 23 (permalink) Old 07-20-2008, 09:10 PM
Does anyone know if Ford Racing makes a light weight flyeheel and stage 2 cluch for the Turbo Coupes.
1988 Thunderbird Turbo Coupe 5 speed manual
Mods. tinted windows, premium sound, red interior with red velor seats,Mild Cam, 30 degree valves, HP rolor rocker Arms, Light weight Aluminum radiator., Kenwood compotion CD player, with comption 6speakers.
1988 Ford Thunderbird Turbo Coupe Dailey Driver
1997 Saturn SC2 Custom Yellow w/ EVO 5 Body Kit.
1987 Ford MUstang LX 4cyl my first car RIP
www.myspace.com/racenut97
http://cardomain.com/ride/3114339
