slight problem - TCCoA Forums
post #1 of 7 (permalink) Old 02-29-2008, 07:09 PM Thread Starter
Shannun's Avatar
Send a message via Yahoo to Shannun
slight problem
i just got an 87 TC and i turned the wipers on now they wont go all the way back down... anyone else have this problem and know how to fix it?
Shannun is offline
post #2 of 7 (permalink) Old 02-29-2008, 11:33 PM
Hobohuey's Avatar
Heres a link to a thread from www.turbotbird.com, sounds like it could be close to the problem your having.
http://natomessageboard.com/cgi-bin/...c;f=1;t=010409
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #3 of 7 (permalink) Old 03-06-2008, 03:04 PM
They don't go down in intermittent mode, or at all? I know on my TC, when you're using Int., they only go down to a certain point (just below where your eye sees the hood) until you turn the wipers off altogether. They'll then pull down the rest of the way behind the cowl.
oldraven is offline
post #4 of 7 (permalink) Old 03-06-2008, 03:05 PM
351cat's Avatar
Send a message via AIM to 351cat
Sounds like maybe the park switch is bad...
Originally Posted by Mitch Hedberg
"Escalator Temporarily Stairs. Sorry For The Convenience."
Originally Posted by cougar_guy04 View Post
Red Green, is that you? Might consider looking into fabbing an intake setup that isn't so, well, ghetto.
351cat is offline
post #5 of 7 (permalink) Old 03-06-2008, 05:10 PM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
I had the same symptoms, I just replaced the wiper motor.
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #6 of 7 (permalink) Old 03-07-2008, 11:18 AM Thread Starter
Shannun's Avatar
they dont go down at all just make a buzzing noise it drives me nuts lol
Shannun is offline
post #7 of 7 (permalink) Old 03-07-2008, 07:36 PM
Raoul Duke
cougarcragar's Avatar
It may be a faulty park mechanism, as 351cat suggested.
Out of the three Fox Cougars I've owned, all three had issues with the wiper motor.
If I remember correctly (this was nine years ago), I pulled the park mechanism from the front of the motor and cleaned the contacts. They were very corroded which prevented the wipers from dropping down into the cowl. I recall drilling out some rivets, too.
1996 Mercury Cougar XR7
cougarcragar is offline
