working on the DA BIRD 3/31/08 w/PICS - TCCoA Forums
post #1 of 3 (permalink) Old 03-31-2008, 10:53 AM Thread Starter
ipsd1's Avatar
i bought my 84 turbo coupe a front mount inter cooler kit. i've got it installed just need to do some finish work to get it done. i still need to mount my bpv flange and install my narrow band[] in the stock clock spot. any how enough of my jaking and on with the pics.
i built the brackets that i used to mount the inter cooler
if you look you can see the VAM brace covers that i made
with factory A/C
narrow band [air/fuel] gauge made to mount in the stock clock box so it will bolt right in. also using the clocks plug for power and ground.
here is the flange and the mounting tube that i made for the bpv. the large tube is just in the pics to show how they fit together.
Flyin with the bird's or runnin with the cat's either is better than ridin horses!
84 Turbo Coupe 2.3T, 88 intercooler/intake setup, T3-4 hyrbrid .60 trim, PC1 ECU, 35lbs/hr injectors, runnin 15psi
94 cougar xr7 inprocess of getting body fixed gonna be the new daliy, Then the turbo coupe get piant & body
ipsd1 is offline
post #2 of 3 (permalink) Old 03-31-2008, 11:16 AM Thread Starter
ipsd1's Avatar
also went from this hood
back to the original hood.
looks much better this way. i like it better this way it says regular old t-bird. not a modded t-bird.
pay no attention to the grill. i've got another one that is getting modded to install
ipsd1 is offline
post #3 of 3 (permalink) Old 03-31-2008, 03:53 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
Looking good man. I always loved the 87-88 hoods on the older 83-88 frontends. How does she pull?
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
