Cam Q's - TCCoA Forums
post #1 of 7 (permalink) Old 06-23-2008, 02:41 PM Thread Starter
Reaper 94lx's Avatar
Send a message via Yahoo to Reaper 94lx
Cam Q's
What is the best cam to install on a stock 87 TC and will still cost less then $400 for cam and followers. I was thinking a new ranger roller cam but don't know what the best year for the ranger 2.3 was. Any help would be great.
Douglas
94 Thunderbird 4.6 4R70W 3.08 Died on 12-13-05 rearended and totaled
87 Thunderbird Turbo Coupe 2.3 T5 3.55 Locker!!! Stock and needs a cam
95 Thunderbird Black 4.6 Richard M Intake K&M 4R70W about to get a 2003 J-mod 4R70W 3.08 new owner since 4-22-06
Reaper 94lx is offline
post #2 of 7 (permalink) Old 06-23-2008, 11:41 PM
Hobohuey's Avatar
The ranger cam is anything before 91 in the 2.3's. I have an extra one with followers laying around that I can dig up and send pictures to you if your interested.
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #3 of 7 (permalink) Old 06-26-2008, 08:26 PM Thread Starter
I'm very interested I need to get the TC back on the road. I haven't taken it apart yet but it was running fine and all of a sudden it started skipping on one cylinder and I could hear a knocking sound from the valve cover. I know that TC's will flatten a cam lobe and mine does have 170000 miles on it, and it did it right after I had to replace the aux shaft, distributor, and oil pump. I had a shop do all of the work. I think when I replaced all of the parts the weakest link gave up. I want to get it up and running now that I got my stimulus check.
post #4 of 7 (permalink) Old 06-28-2008, 11:56 PM
Hobohuey's Avatar
Ive been alittl eunder the wather the past couple of days, ill try to dig it out tomorrow and send you pictures of it.
Hobohuey is offline
post #5 of 7 (permalink) Old 06-30-2008, 01:09 AM Thread Starter
looking forward to it. I'm trying to keep as much of the money as I can fix a couple of other problems it has.
post #6 of 7 (permalink) Old 07-05-2008, 05:08 PM
88TurboCoupeman01's Avatar
Send a message via AIM to 88TurboCoupeman01 Send a message via Yahoo to 88TurboCoupeman01
check this site out I found it on the turbo Coupe forum under 2.3 mods. http://turboflush_2.tripod.com/cams.htm. I have a comp cam in my Turbo Coupe and its a great cam for the street/strip and its pretty cheap. Or check this ite out http://racerwalsh.zoovy.com/category...camsfollowers/.
1988 Thunderbird Turbo Coupe 5 speed manual
Mods. tinted windows, premium sound, red interior with red velor seats,Mild Cam, 30 degree valves, HP rolor rocker Arms, Light weight Aluminum radiator., Kenwood compotion CD player, with comption 6speakers.
1988 Ford Thunderbird Turbo Coupe Dailey Driver
1997 Saturn SC2 Custom Yellow w/ EVO 5 Body Kit.
1987 Ford MUstang LX 4cyl my first car RIP
www.myspace.com/racenut97
http://cardomain.com/ride/3114339
88TurboCoupeman01 is offline
post #7 of 7 (permalink) Old 07-15-2008, 03:59 PM
actually, its anything AFTER 91 for 2.3's.
the ranger cam and 2.3dp mustangs both have roller cams from the factory and you can normally get one from the u-pull for around $35.
The ranger cam has slightly higher lift than the mustang cam though but both are good for at least getting some roller rockers which pretty much NEVER go bad lol.
boport makes a really nice set of roller cams for the 2.3t engines and they only run around $200 or so from him.
you can also get a used A237 cam off ebay for around $150 or so....but its already been proven that boport cams are better for our 2.3t engines as they were designed for it versus the A237 cam which is nothing more than a roller version of the A234 cam which is setup for n/a applications.
86 1D svo mustang
88 5.0 mustang
95 GT convertible
98 5.0 mountaineer
93 b18 turbo civic hatch
stackz is offline
