headlight swope - TCCoA Forums
post #1 of 5 (permalink) Old 07-08-2008, 08:56 PM Thread Starter
88TurboCoupeman01's Avatar
Send a message via AIM to 88TurboCoupeman01 Send a message via Yahoo to 88TurboCoupeman01
headlight swope
Could I take one of these haeadlights and put them on my car insted of the headlight inbetween the cornerlights.
The 83-96
http://images.google.com/imgres?imgu...IC:en%26sa%3DN
my 88 Thunderbird Turbo Coupe.
1988 Thunderbird Turbo Coupe 5 speed manual
Mods. tinted windows, premium sound, red interior with red velor seats,Mild Cam, 30 degree valves, HP rolor rocker Arms, Light weight Aluminum radiator., Kenwood compotion CD player, with comption 6speakers.
1988 Ford Thunderbird Turbo Coupe Dailey Driver
1997 Saturn SC2 Custom Yellow w/ EVO 5 Body Kit.
1987 Ford MUstang LX 4cyl my first car RIP
www.myspace.com/racenut97
http://cardomain.com/ride/3114339
88TurboCoupeman01 is offline
post #2 of 5 (permalink) Old 07-08-2008, 10:02 PM
not sure what your asking, but you need the whole 83-86 front end to use those headlights. if your asking if you could use the sealed beam style ones you might be able to use a bigger one from an SVO mustang or similar to fill the gap better and retain high/low beam.
you might want to check out the Fox tbird and cougar sites for more info.
post #3 of 5 (permalink) Old 07-12-2008, 07:09 PM Thread Starter
Ow its I forgot tis sealed never mined. But what I was asking was put a 83 headlight were my stock headlight and keep my stock corners so it looked like a svo.
post #4 of 5 (permalink) Old 07-12-2008, 07:18 PM
it should be doable, you may have to do something custom to mount them though(i'm guessing).
if you want the true SVO look i'd get the same sealed beam lights they used for the SVO's, using the 83-86 bird/cat ones will be too big if you used all 4 lights, and they would be too small if you used just 2 lights(plus no highbeams). the SVO lights look to be the same size as the headlight between the corner and parking lights on the birds.
post #5 of 5 (permalink) Old 07-13-2008, 08:37 PM Thread Starter
thanks.
