Oil in the intercooler - TCCoA Forums
post #1 of 4 (permalink) Old 09-26-2009, 11:37 AM Thread Starter
I have oil in the intercooler and in the bellow going to the throttle body...is this the PCV valve or am I getting some blow back?, I am new to the 2.3 and a turbo.
cyber-junkie is offline
post #2 of 4 (permalink) Old 09-26-2009, 01:27 PM
I think you will find that much of the oil will be from the PCV. Lightnings are really bad for filling up the intercooler with oil. Construct a catch for it out of a water separator designed for air compressors and put it in the PCV line.
Bangster is offline
post #3 of 4 (permalink) Old 10-17-2009, 12:56 PM
BJL
Send a message via AIM to BJL
a lil but if oil in the the intercooler is ok, if it puddling and dripping out then clean the separator on top of the valve cover.
what year is the TC? are you running a motorcraft pcv valve?
Brian J Larkin
1988 Tbird TC 5spd. few bolt ons, 308k miles
1989 Cougar XR7 AOD 110k
BJL is offline
post #4 of 4 (permalink) Old 10-22-2009, 11:01 AM
T6Rocket's Avatar
Do the TC's run a breather hose from the valve cover to intake pipe like most turbo cars?
If so, install a catch can in that line like this one: http://www.saikoumichi.com/OCC_page.htm They work great to catch oil.
And you can use gasoline to clean the intercooler out, just dry real good before re-installing!
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
