Bcs - TCCoA Forums
post #1 of 2 (permalink) Old 12-04-2011, 10:01 PM Thread Starter
Bcs
OK well I posted this on http://www.foxtbirdcougarforums.com/ and they have not replied back. So what I need to know is on the boost control valve does it matter witch way the lines are hooked up. When I got this 88 TC the old one was broken up and bypassed. Thanks
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #2 of 2 (permalink) Old 12-20-2011, 01:24 PM
On your two port boost valve it does not matter which hose is on top and which is on bottom.
So, hook it up, and switch it to premium to take advantage of that full boost.
dwiggy is offline
