Auto VS Manual - Need help quick - TCCoA Forums
post #1 of 4 (permalink) Old 04-29-2003, 08:48 AM Thread Starter
Hi! I am new to this so bear with me.
I am planning to buy an 87 Turbo Coupe On Thursday, so need the answer before then if you can
I am buying an 87 TC and want to put the motor in my Suzuki Samurai (please don't hate me). It is currently an automatic, but I am planning on putting a T-5 behind it. I have read that the 2.3Turbo is 190HP from factory with a manual, and only 150HP with the automatic. Is there a difference in the motors with either trans, or is the difference just because of the auto's gearing? (Basically, is it ok to put the Manual behind the motor, or do I have to change programing or anything? is the motor the same in both models?)
Thank you,
Jonathan
Jonathan
jpsandberg is offline
post #2 of 4 (permalink) Old 04-29-2003, 12:08 PM
I'm not sure about the power rating but I doubt the Suzuki transmission would accept a Ford engine. If it would, I kind of doubt it would be able to handle the torque for any extended period of time. But I'm just a naysayer saying nay.
DSMonsta is offline
post #3 of 4 (permalink) Old 04-29-2003, 02:13 PM Thread Starter
That is why I stated the TC has an automatic now, but I want to put a T-5 behind it. T-5 is FORD and is a manual. I am not using the suzuki tans.
Jonathan
Jonathan
post #4 of 4 (permalink) Old 04-30-2003, 04:26 PM
TurboCoupe50's Avatar
The engines are the same, the main difference is the turbo setup. It was limited to 8-10psi on the automatics because its a weak POS, the 5 speeds got 15psi boost. All that is necessary is to add a bleeder valve to the wastegate and you can get more boost. Its a good idea to limit it to 16-17 psi as the IHI turbo becomes very inefficent at higher levels.
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
[email protected] W/90hp shot.. [email protected]
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
