need some info - TCCoA Forums
post #1 of 2 (permalink) Old 10-19-2003, 12:51 AM Thread Starter
Exclamation need some info
whats the stock boost on an 86 turbo coupe?
mine says 19-20psi is that normal?
i just got one and i was wondering if there are there any problems i should look forward to dealing with
thanks
White 86 tbird turbo coupe and a Burgandy 1987 tbird 460ci V8,3 speed C6 trans with a rev. manual valve body and hurst shifter (doing body work on it right now)
DarkMyth is offline
post #2 of 2 (permalink) Old 10-25-2003, 11:05 AM
If the boost solenoid is working properly it's 15 psi in 1st, 2nd and I think 3rd. 10psi in 4th and 5th. The overboost warning buzzer should come on at about 17.5 psi. I think it's unlikely that a stock 86 would respond well to 19-20psi, so if it's running well and you have no warning buzzer then it might just be the guage. You could easily hook up an aftermarket boost guage and find out.
You may also want to make sure that the electric fan comes on when the engine heats up. The relay that controls it is somewhat less than reliable and they can be a little hard to find and a little expensive. You can just wire in a switch if it doesn't work.
Check out turbotbird.com
Later
Kevin
3bird is offline
