swamping a 351 in an 88 TurboCoupe - TCCoA Forums
post #1 of 5 (permalink) Old 10-27-2003, 01:48 PM Thread Starter
Ig to a friend with a good loking 88 turbo coupe with a toasted motor. He has a 351 he is going to put in it. can you give any details or poiters or suggestiosn on doign this on what type of incompatibilites that we may run into. thank
Regg
reckmann is offline
post #2 of 5 (permalink) Old 10-27-2003, 09:21 PM
TurboCoupe50's Avatar
You talking EFI or carbed????
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
[email protected] W/90hp shot.. [email protected]
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
post #3 of 5 (permalink) Old 11-02-2003, 03:10 PM Thread Starter
Carborated 351 1970s vintage with a performer intake cam and carb. thanks
reckmann is offline
post #4 of 5 (permalink) Old 11-22-2003, 05:17 PM
Send a message via AIM to Crymson Thunder
I know the firewall on my 85 had to be slightly modified on the passenger side to fit the manifold but I have a Cleveland so if that's what your friend has I think that's the only thing you have to look out for fitment wise. I'm not sure about mechanical problems right off hand although my car does have a push button start so the ignition might be something to look out for.
Matt
~If speed kills then buy a Honda~
~I'm not addicted to gambling... I'm addicted to sitting in a semi-circle~
83 Thunderbird with a 351 Cleveland
Crymson Thunder is offline
post #5 of 5 (permalink) Old 11-24-2003, 11:26 AM
mercoug302's Avatar
A carbed setup will more or less fit the same way the 302 does. With a TC though, the driver's side valve cover may interfere with the ABS. With a high-rise intake, the air cleaner will interfere with the hood. A single plane might help you escape getting a cowl hood.
Mine comes very close to hitting the stock M/C.
1988 XR7
5.8L EFI, tremec 3550,spec stage III clutch,90mm L-MAF, TFS heads, GT40 intake, lunati cam,Fordchip.com,diablo chip 311rwhp 375 rwft/lbs.13.2 @107.2. with 3.08's
2004 Pontiac GTO LS1 6 speed black/red RIP
mercoug302 is offline
