Disc brake question. - TCCoA Forums
post #1 of 11 (permalink) Old 11-18-2003, 07:20 PM Thread Starter
I'm the new guy here and have a question about turbo coupe brakes. Do all the turbo coupes have rear disc brakes? Are they all the same....83-88?
'90 Convertible Mustang.
blackconvt is offline
post #2 of 11 (permalink) Old 11-19-2003, 03:10 PM
Only the '87 and '88 TC has rear discs. If you have an earlier TBird, it's a fairly simple matter to swap out the rear ends. Some brake plumbing work to mate the later rear to the earlier chassis, and a Mark 7 emergency brake cable assembly will work on the '86 and earlier chassis.
Johns331 is offline
post #3 of 11 (permalink) Old 11-19-2003, 05:45 PM Thread Starter
OK, follow up question? Do all the Turbo Coupes have 8.8 rear ends. If not, which ones do?
Neil
post #4 of 11 (permalink) Old 11-21-2003, 09:04 PM
TBird232ci's Avatar
Send a message via AIM to TBird232ci
TBird232ci is offline
post #5 of 11 (permalink) Old 11-21-2003, 09:33 PM Thread Starter
Cool, thanks guys.
post #6 of 11 (permalink) Old 12-05-2003, 09:19 AM
I may getting a 87 TC rearend (minus rotors & calipers) to upgrade a 89 5.0 Stang Vert.
How much are rotors and calipers for this application ??
Any tips to do this swap ??
Katmandu is offline
post #7 of 11 (permalink) Old 12-05-2003, 09:53 AM
Keep in mind that the T'Bird rear ends are about an inch wider that a Mustang rear end.
Someone correct me on that, but I'm pretty sure they are wider. Before you get it, I'd highly recommend you double check.
Just my .02.
69 F100 LWB w/460 Engine
post #8 of 11 (permalink) Old 12-05-2003, 12:29 PM
Yes, the TC rearends are 3/4" wider on EACH end.
Katmandu is offline
post #9 of 11 (permalink) Old 12-06-2003, 10:44 PM
Slacks 12 months a year
LX-Tasy's Avatar
Also the 87-88 TCs rear end gears will vary upon the trans that was used, the autos had 3:73 gears while the 5-speeds had 3:55 gears.
I did that swap in a 93 vert and it looked like A$$,I had draglites on it but still stuck out to far.I would just get the 8.8 out of a 5.0.
Chris
"My Other Ride Is Your Girl"
LX-Tasy is offline
post #10 of 11 (permalink) Old 12-06-2003, 10:59 PM
5.0 Chero's Avatar
hey KATMAN welcome to this site!
I did a 4 wheel swap on 89 vert useing a mixture of stock and modified ford parts email if you still have my email address
How is the 460 mark 7 comming?
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #11 of 11 (permalink) Old 12-07-2003, 09:13 AM
Hey 5.0 Chero! I sold the Mark a few months back and picked up a 89 5.0 Vert. Also sold my 64 Falcon Futura. I'll PM ya here...
Are there any problems (other than tire size) with the extra 1 1/2" axle width ??
Katmandu is offline
