Power of the TurboCoupe's turbo?? - TCCoA Forums
post #1 of 14 (permalink) Old 07-10-2004, 09:42 PM Thread Starter
Send a message via AIM to 1997T-Bird Send a message via Yahoo to 1997T-Bird
I am asking this because my friend took the TC's turbocharger and put it on a 2.3L engine and slapped all of this into a beat up Ford Ranger, according to the guage, he was pushing an incredible 20 lbs of boost!!
Does the TC push similar numbers??
Currently: 2004 Honda Civic Ex 5 Speed
17X7 BSA Wheels - 215/45/17 Falkens; Complete JL System; Magnaflow Catback; Lowered 1.4"
Last Car:
Custom Magnaflow Dual Exhaust; 2003 Cobra Rims with Kelley 255/45/17s;Steeda U/Ds; B&M Transmissoin Cooler; Dirtyd0g's custom 2800 Stall Torque Converter; J-Mod Kit installed by Dirtyd0g; SCT Tuned by Darrin; Lowered with Spring Tech Springs
Want great work done on your tranny? Have dirtyd0g do it! He made a believer out of me!
1997T-Bird is offline
post #2 of 14 (permalink) Old 07-10-2004, 09:58 PM
93TbirdSC's Avatar
Send a message via AIM to 93TbirdSC
which turbo is it??? the 87-88s use the IHI which i think was 10-14 stock psi but 18psi is max on that turbo because its so small
on a 83-86 it was a T3 with 10psi stock but safely run 21-22psi max
may wanna double check my info cuz im fairly new to the TC and turbo game
And in the 7th game Lord Stanley said, "Let there be Lightning"
Tampa Bay Lightning, 2004 Stanley Cup Champions!!!!!!!!
Super Coupe Club of Florida
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
93TbirdSC is offline
post #3 of 14 (permalink) Old 07-13-2004, 09:16 AM
93sleeper's Avatar
How hard was the swap? I was gonna drop a compleatly rebuilt tc eng and trans in my buddys mustang.
1986 Pontiac Fiero/Kit Lamborghini Diablo replica-UPDATE: Prep for paint in Jan
1988 Mx-6 Gt with 4ws-Update: Fitting roll cage after weight reduction
1973 Yamaha Tx750:RARE Est 200
1988 Mx-6 dx: Parts car
Port and Polishing, custom painting on small to large parts, Custom Machining-Quick Turn around, and the lowest guarenteed prices.
93sleeper is offline
post #4 of 14 (permalink) Old 07-13-2004, 09:58 AM
The boost is based on the wastegate, which uses a pulsed signal from the EEC to bleed off the exhaust from the turbine.
There is a metered orifice in the boost line that feeds the wastegate actuator and the EEC sends a pulsed signal to engage the wastegate solenoid, which will bleed off some of that pressure. The EEC regulated the pulses to maintain the boost. The wastegate is nothing more than a diaphram that moves the valve in the turbocharger turbine housing to bleed off exhaust gasses which slows down the compressor.
On my 85 TC, I changed the complete wastegate system to provide 10 psi below 3K, 15 psi from 4500, and 20 psi above. All that was using rpm activated switches and stock wastegate solenoids. The OEM setting is 8 psi at some rpm and then 14 psi above that (don't quote me on those exact numbers since I'm pulling this from memory)
It’s a pretty neat system.
69 F100 LWB w/460 Engine
post #5 of 14 (permalink) Old 07-13-2004, 10:43 AM
93TbirdSC's Avatar
all i can get from my 85 TC is 10psi....on ocasion its gone up to 14 but im not sure why.
the swap should be farely easy if you have the experience...its been done plenty and the stang came with the motors for a while to....might even be farely similar to the NA 4cyl stangs(mounting positions and such)
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
post #6 of 14 (permalink) Old 07-13-2004, 03:47 PM
93sleeper's Avatar
Mine will only go up to 10 at max, but thats just driving around the yard, Its got no brakes at all. Kinda the reason im gonna drop it in the stang.
post #7 of 14 (permalink) Old 07-13-2004, 11:28 PM
Duplicate Account
You are correct in that fact that the wastegate controls that amount of boost that the turbo will produce however it is not controled by the EEC unless he is using the stock Boost Control Selenoid (BCS). If the BCS is connected and functioning properly the boost will be set at 10psi of boost for an Auto or 15psi for a Manual and this is controled by the EEC. The waste gate on the IHI turbos is set at 4psi not sure about the t-3's wastegate. The BCS has a big role, you can always use a manual boost controller. If he has a vaccum hose connected straight to the wastegate it will keep the wastegate closed and he can make as much boost as he wants . The IHI will continue to make boost even past its efficent range of 17-18psi. Right now my IHI is pushing 18psi with the stock intercooler. The only thing problem i can think of with running that much boost is detonation, : In a TC its bad but in a hyperpathetic block its catastophic. Hopefully he swapped the entire engine. So basically they can all make 20+psi of boost but whether or not they are efficent is a different story.
2.3L_of_Fury(LimitedEditionBird) is offline
post #8 of 14 (permalink) Old 07-22-2004, 12:06 PM Thread Starter
I'm not really sure which turbo was in it, but the guage was reading around 18 to 20 lbs of boost, and you sure could hear it!!!!
You think that little truck would be any fast?
It is a 83 Ranger with a rebuilt 2.3L and TC turbo, and he has a Flowmaster exhaust system on it.
Last Car:
post #9 of 14 (permalink) Old 07-22-2004, 07:02 PM
93sleeper's Avatar
Factory boost guages suck, upgrade and you will find out what it is really doing.
post #10 of 14 (permalink) Old 07-22-2004, 09:36 PM
93TbirdSC's Avatar
you might want to tell him to dump the flowmasters and go with some kind of straight thru design muffler like dynomax
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
post #11 of 14 (permalink) Old 07-23-2004, 11:11 AM Thread Starter
Well, as of right now he is going to get it repainted, then he wants to lower it and put aftermarket wheels and do some custom interior work to it. It will look really neat when he is done... I told him to go magnaflow because there isn't any BS in the muffler like Flowmaster, but he said his Flowmaster didn't use that Delta flow technology.
This vehicle is like his "fishing" truck, it is the only time he uses it. His daily is a 97 C5 with around 370 to 400 RWHP. That thing is sick too .
He also has a SVO stang with upgraded turbo.. I want him to let me drive that sooo bad.
Last Car:
post #12 of 14 (permalink) Old 08-27-2004, 05:19 PM
Send a message via AIM to FOMOGO Send a message via Yahoo to FOMOGO
Guys... What do you want to bet that his wastegate has no boost referance going to it?
Jim
FOMOGO is offline
post #13 of 14 (permalink) Old 08-27-2004, 09:57 PM
No More BS
HotRod88LSC's Avatar
HAHA Didnt think about that. That would do it.
1988 Lincoln Mark VII
Paxton Novi 1000 6psi kit, 30lb injectors 73mm C&L, MAF converted A3M, gt-40's, Felpro headgaskets, 1.7 Cobra RR's, typhoon intake,1 5/8 shorty headers, off road x-pipe, and full mandrel catback, electric fan, 3.73's, TKO 500, pro 5.0 shifter
372.4hp / 394.6tq 5psi
Rest in Peace Joel R. Bender.
July 30, 1979 - March 26, 2006
HotRod88LSC is offline
post #14 of 14 (permalink) Old 08-30-2004, 06:11 PM
TurboCoupe50's Avatar
Jim
You're probably right... I had '88 XR4TI that would make 24lbs because the wastegate actuator had a bad diaphram...
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
[email protected] W/90hp shot.. [email protected]
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
