How fast are Turbo Coupes? - TCCoA Forums
post #1 of 11 (permalink) Old 07-15-2004, 01:45 PM Thread Starter
quick35th's Avatar
Like the title states how fast are stock Turbo Coupes? How fast can modded TC be?
Shane
Shane Glynn SCCA Member number: 328085_0
2008 SCCA OVR C Prepared Champion
'92 Thunderbird SC 5.0L (35CP) Sponsored by AAA Ohio Auto Club
'99 Ford Expedition Eddie Bauer
Corner workers run and hide in fear when they see me take course
quick35th is offline
post #2 of 11 (permalink) Old 07-15-2004, 10:32 PM
93TbirdSC's Avatar
Send a message via AIM to 93TbirdSC
'83-'86 TurboCoupe SPECIFICATIONS
VEHICLE TYPE: Front-engine, rear-drive; 2-door 5-passenger sedan
WHEELBASE: F/R: 58.1/58.5 in
POWERTRAIN: 2.3L IL4 OHC, EFI, Turbocharged
HORSEPOWER: 155 @ 4600
TORQUE: 180 @ 3800
BRAKES: F/R: vented disc/drum
TRANSMISSIONS: Manual: Borg Warner T-5
Automatic: Ford C3 - 3 SPEED, optional "Select Shift"
TIMES: 1/4 Mile: 16.5 @ 85 mph
1983 started the era of the Aerodynamic Thunderbird, it marked the turning of Ford from the corpulent excesses of the previous "square bird". With it Ford introduced the EFI version of the 2.3 L OHC engine that proved superior to the carburetor equiped 2.3L of 1979.
And in the 7th game Lord Stanley said, "Let there be Lightning"
Tampa Bay Lightning, 2004 Stanley Cup Champions!!!!!!!!
Super Coupe Club of Florida
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
93TbirdSC is offline
post #3 of 11 (permalink) Old 07-15-2004, 10:33 PM
93TbirdSC's Avatar
'87-'88 TurboCoupe SPECIFICATIONS
Vehicle Type: Front-engine, rear-drive; 2-door 5-passenger sedan
Engine:
2.3L (2295cc, 140 cu in) 4 cylinder engine
2 valves per cylinder, overhead cam
190 HP with 5 speed trans, 150 HP with automatic trans
Torque 240 @ 3400
8:0:1 compression ratio
Bore and stroke: 3.780" x 3.126" (96.0mm X 79.2mm)
MPEFI injection
Cooling fan turns on at 221 degrees F
Turbocharger:
IHIRHB-52 turbo with integral waste gate
air to air intercooler, dual active air scoopes on hood
intercooler cools air by ~60% on its way to the cylinder head
(denser air=more HP)
Transmission:
Manual: Borg Warner T-5 short throw 5 speed manual trans
Top speeds per gear: 1st - 33mph, 2nd - 56 mph, 3rd - 89 mph,
4th - 131 mph, 5th - 143 mph
Automatic: Ford A4LD - 4 speed automatic with overdrive
Gearing:
3:55 final drive ratio with T5 transmission,
Gear ratios: 1st - 3:97, 2nd - 2:34, 3rd - 1:46, 4th - 1:0, 5th -0:0.8
3:73 with the A4LD auto transmission
8.8" rear end
Miscellaneous Specs:
wheelbase = 104.2"
length = 202.1"
height = 53.4"
width = 71.1"
front tread = 58.1"
rear tread = 58.5"
trunk volume = 14.6 cu.ft.
fuel capacity = 22.1 gal.
weight = 3415 lbs (3419 lbs with AOD trans)
5 passenger capacity
0.36 Cd drag coefficient
steering: 2.4 turns lock to lock, curb to curb circle = 39.4 ft, 15:0:1 on center rack and pinion
firm suspension settings kick in (in ~40ms) with 0.3g or more cornering or braking, when throttle is floored, when boost exceeds 10 psi,
or when speed exceeds 80 mph
Miscellaneous numbers, times, and levels:
1/4 mile - 16.3 seconds @ 84.5 mph
60 mph to 0 mph stopping distance - 138 ft.
0.82 lateral g
700 ft slalom speed average = 61.2 mph
0-30 mph in 2.5 sec, 0-50 mph in 5.9 sec, 0-60 mph in 8.5 sec, 0-70 mph in 11.7 sec, 0-80 mph in 14.5 sec
0-100 ft in 3.2 sec, 0-500 ft in 8.8 sec, 0-1320 ft in 16.3 sec
interior noise: at idle - 54 dBA, 1st gear max - 84 dBA, 70 mph steady - 71 dBA
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
post #4 of 11 (permalink) Old 07-15-2004, 10:35 PM
93TbirdSC's Avatar
heres the fastest 25 list over at turbotbird.com
http://natomessageboard.com/Forum16/HTML/000074.html
hope this answers all your questions!
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
post #5 of 11 (permalink) Old 07-16-2004, 07:09 AM
Send a message via AIM to zero89lx
I have a question: what did they do to de-tune the auto 87-88 by 40 HP?
I hate this place! Nothing works here! The medication doesn't work! I've been here seven years! I hate this place!
zero89lx is offline
post #6 of 11 (permalink) Old 07-16-2004, 07:51 AM
Note that first gear ratio.
I also think the first few year TurboCoupe 5-speeds had a 4.03 first gear ratio.
( http://www.smartworx.com/TurboTekToy...c/0000000e.htm )
Even though they may be down on power, the gearing for out of the hole is pretty good.
Another car to look at for info on the Turbo motor are the 84 to 86 SVO's. 205 hp I think.
69 F100 LWB w/460 Engine
post #7 of 11 (permalink) Old 07-16-2004, 09:28 AM
93TbirdSC's Avatar
because the a4ld was a piece of **** transmission...lol it couldnt handle any power
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
post #8 of 11 (permalink) Old 07-16-2004, 09:39 AM
Nono, I know *why* they de-tuned it. I wanted to know *what* they did to it. Was it just a downgraded computer program? smaller heads? what?
zero89lx is offline
post #9 of 11 (permalink) Old 07-16-2004, 09:42 AM
I'm not 100% sure, but I think all they did was decrease the boost levels (via the EEC) by 3 psi across the board. To my knowledge everything internally is identical. But it's been a while since I researched the turbo 2.3L.
post #10 of 11 (permalink) Old 07-16-2004, 09:44 AM
93TbirdSC's Avatar
oops....sorry man....i believe 94 daily drivn is right but ill look around for ya
My Car Page
Rekless Racing
1993 Thunderbird SC
89 xr7-parts car
post #11 of 11 (permalink) Old 07-16-2004, 01:16 PM Thread Starter
quick35th's Avatar
Thanks for the info guys.
Shane
