turbo bird info - TCCoA Forums
post #1 of 8 (permalink) Old 04-24-2005, 08:05 PM Thread Starter
Crossfire is offline
post #2 of 8 (permalink) Old 04-25-2005, 02:44 AM
bad link
1994 Lx, 93 Mark DOHC engine/trans/driveshaft, H&R springs, tokico blues, 17" ROH Snipers, underdrives, 2.5" true dual w/magnaflow tru-x muffler, 3.73 trac loc, and a older tune that needs redone. Wishing for a t-45 and a power adder. . .
loudpedal99 is offline
post #3 of 8 (permalink) Old 04-25-2005, 05:42 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
tinman_72 is offline
post #4 of 8 (permalink) Old 05-01-2005, 08:29 PM Thread Starter
link error
hummmmmm...when you place your cursor on the topic subject, it displays the correct addy
post #5 of 8 (permalink) Old 05-04-2005, 01:50 PM Thread Starter
here's the info....
83 thru 84 Thunderbird EFI turbo
Non-intercooled, 30 lb/hr green top injectors, 10 PSI boost, tiny camshaft-get rid of it,
"Inline" shaped intake manifold, small VAF meter (~285CFM), single exhaust
-all manual transmissions (T-5) Rated at 155 HP 3.45 posi rear gear 4.03 first gear in
transmission
-all automatic transmissions (C-3) Rated at 140 HP 3.45 posi rear gear 2.47 first gear
in transmission
85 thru 86 Thunderbird Turbo Coupe
Non-intercooled, 36 lb/hr brown top injectors, 10 or 14 PSI boost depending on;
automatic or manual transmission application, "4 square" shaped intake manifold,
-all manual transmissions (T-5) Rated at 175 HP, camshaft equivalent to the Ford
Motorsport -A231 grind 3.45 posi 7.5" rear, 4.03 first gear in transmission
-all automatic transmissions (C3) Rated at 140 HP teeny-tiny camshaft-get rid of it,
3.45 posi 7.5" rear, 2.47 first gear in transmission
87-88 Thunderbird Turbo Coupe
Intercooled, 36 lb/hr brown top injectors, 10 or 14 PSI boost depending on; automatic
or manual transmission application, "4 square" shaped intake manifold, large VAF
meter (~380CFM), dual or single exhaust depending on; automatic or manual
transmission application.
This model has the best possible EEC for swaps into other turbo cars, prior to 1987
models. Hpowever, numerous wiring changes must be made, and additional sensors
added, but horsepower and drivability are greatly improved. The recipient car should
be intercooled for maximum power gain.
-all manual transmissions (T-5) Rated at 190 HP, tiny camshaft-get rid of it, 3.55 posi
8.8" rear, 3.97 first gear in transmission, dual exhaust.
-all automatic transmissions (A4LD) Rated at 150 HP, teeny-tiny camshaft-get rid of it
3.73 posi 8.8" rear, 2.47 (?) first gear in transmission, single exhaust.
post #6 of 8 (permalink) Old 05-11-2005, 10:36 PM
lightevergreenfrost's Avatar
Send a message via AIM to lightevergreenfrost
Other than that having way too many comma's in it, it did give a lot of good info. Couple of questions though, what about the 83-84's, and why not use the good camshaft from the 85-86's (manual) in the later models.
T-Bird Registry Number 27526
My Car Domain Site
http://www.cardomain.com/ride/2282851
My Space:
http://www.myspace.com/jordonjones
post #7 of 8 (permalink) Old 06-04-2005, 10:04 AM
Bakstoy's Avatar
Before breaking both motor mounts, my 86' ran pretty decent with the high mileage it had. It had a FMS intercooler kit, bigger T/B (unsure of size) header, and a slight rough idle, 5 spd. It would smoothen right up with a little pressure on the throttle. Ran like crazy.
Bakstoy is offline
post #8 of 8 (permalink) Old 06-04-2005, 01:04 PM
Im looking into restoring a 83-84. Its believed to have a cracked head, what cars can I use the heads off of. I know I can't use the twin plugs that came out in the early 90's.
My Car Domain Site
My Space:
