engine trouble 84 TC need HELP - TCCoA Forums
post #1 of 14 (permalink) Old 08-11-2005, 05:46 AM Thread Starter
i have a 1984 2.3 turbo coupe i need to get the engine running before truck bash in 2 weeks. All i can tell u is that the car ran real good then one day took a SH*T. The car cranks over but will not run it putters for a sec then dies. It has new plugs and plug wires new starter, new dist. and cap, turbo is fine had it looked at. Also i have no cat. exhust prev owner cut it of could it be the oxygen censor? idk. Do any of u have any suggestions i am open to anything. PLEASE HELP THANKS FOR EVERYTHING.
dada1587 is offline
post #2 of 14 (permalink) Old 08-11-2005, 10:22 AM
Slacks 12 months a year
LX-Tasy's Avatar
Have you tried the module on the side of the dist.? Also what is your TPS settings? A faulty TPS will cause nightmares.
Good Luck
Chris
"My Other Ride Is Your Girl"
LX-Tasy is offline
post #3 of 14 (permalink) Old 08-11-2005, 04:14 PM Thread Starter
Engine Trouble
thanks for the info i will get right on it to see if that is it how can u tell if the module is bad? thanks and would like some more post in case that is not it.
dada1587 is offline
post #4 of 14 (permalink) Old 08-12-2005, 09:57 PM
LX-Tasy's Avatar
Whats the results?
Chris
LX-Tasy is offline
post #5 of 14 (permalink) Old 08-12-2005, 11:16 PM
Hobohuey's Avatar
Have you checked the timing?
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #6 of 14 (permalink) Old 08-13-2005, 02:14 AM Thread Starter
Engine Trouble
Originally Posted by LX-Tasy
Whats the results?
Chris
i am going to the junk yard to get a new TPS. will have resaults monday.
dada1587 is offline
post #7 of 14 (permalink) Old 08-13-2005, 02:14 AM Thread Starter
Engine Trouble
yes the timming is fine.
dada1587 is offline
post #8 of 14 (permalink) Old 08-15-2005, 12:40 AM
check your fuel pressure if you haven't already
crawdaddy1999 is offline
post #9 of 14 (permalink) Old 08-18-2005, 10:38 PM Thread Starter
good news
i just called a junk yard and priced the whole trottle body for $45 i am happy be real happy if that was the problem
dada1587 is offline
post #10 of 14 (permalink) Old 08-20-2005, 05:50 PM
I'd bet on the Ignition Module (on the side of the dizzy). They can be checked at AutoZone on their bench tester. They run around $60 new and are a common problem on all 2.3L
1994 Lx, 93 Mark DOHC engine/trans/driveshaft, H&R springs, tokico blues, 17" ROH Snipers, underdrives, 2.5" true dual w/magnaflow tru-x muffler, 3.73 trac loc, and a older tune that needs redone. Wishing for a t-45 and a power adder. . .
loudpedal99 is offline
post #11 of 14 (permalink) Old 08-22-2005, 03:35 PM Thread Starter
need help findin the engine code
need help findin the engine code for my cougar it is not the right engine in it. It is the 84 body style but not the 84 2.3 turbo engine were can i find the engine code thanks and post back asap need car
dada1587 is offline
post #12 of 14 (permalink) Old 08-22-2005, 06:54 PM Thread Starter
engine problem
found out one of the major problems the guy i bought the car off of never told me that they did a engine swap it is a 1985 Mercury Cougar XR7 with a 1983 Mustang 2.3 turbo engine so thank and if u know anything about it plz help srry for the incovience
dada1587 is offline
post #13 of 14 (permalink) Old 08-23-2005, 07:00 AM
TurboCoupe50's Avatar
I don't think there is any real difference in those 2.3s. The '86 SVO Stangs and Tbird/Xr7s had larger air meters and injectors.
As far as the oxygen sensor it will run without it, so that ain't your problem. The Vane Air Meter and TPS are the only sensors that will keep it from running. You likely have a ignition, fuel pressure problem, or possibly the cam timing has slipped(worn belt)...
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
[email protected] W/90hp shot.. [email protected]
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
post #14 of 14 (permalink) Old 08-23-2005, 07:41 PM Thread Starter
motor number
hey the motor number is RFE3Z601500 does any one know how to read it i think it is the 83 turbo out of the mustang
dada1587 is offline
