1988 Turbo Coupe trouble code reading - TCCoA Forums
post #1 of 7 (permalink) Old 08-17-2005, 10:26 PM Thread Starter
I just picked up a 1988 Turbo Coupe and I want to read the trouble codes.I found the 6 sided connector no problem but can't seem to find the single wire STI wire anywhere.My code reader manual says some 1988 and newer vehicles don't have the single wire connector, should my 88 have one?
351lx is offline
post #2 of 7 (permalink) Old 08-23-2005, 07:02 AM
TurboCoupe50's Avatar
Kinda late, but yep it should have the single connector as well.
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
[email protected] W/90hp shot.. [email protected]
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
post #3 of 7 (permalink) Old 08-23-2005, 09:31 AM Thread Starter
I figured it out.On most vehicles there are 3 wires going into the six sided connector that you hook your code reader to and a seperate STI wire.On my car, there were 4 wires going into the six sided connector and no seperate STI wire as it seems Ford incorporated it into the other connector.The STI wire is white with a red stripe, I simply cut it and put a spade connector on it and hooked it to my code reader that way.I was then able to pull the codes with my reader.
351lx is offline
post #4 of 7 (permalink) Old 08-23-2005, 06:02 PM
Cool... Someone must have stuck it in the large connector, as I've owned 11 '88 TCs and all had a seperate STI connector.
post #5 of 7 (permalink) Old 08-23-2005, 08:16 PM Thread Starter
Actually, the way I figured it out was I did a search on another T-bird site NATO and found a post by someone with the same problem as me.They couldn't find the STI wire and someone mentioned it was white with a red stripe.They noticed there was a wire that color going into their six sided connector so they pulled the codes with a voltmeter using the STI wire in the six sided connector.I just figured I might as well cut it and hook a spade connector to it.So there are at least two 1988 Turbo Coupes with no seperate STI wire.Maybe it has something to do with the date of manufacture as my car was made Oct 1987.
351lx is offline
post #6 of 7 (permalink) Old 08-24-2005, 11:35 PM
Maybe the harness mfg'er screwed up on a few, but i've owned '88 TCs built between Oct '87 & July-'88 and not had the issue(also owned three '87s again no prob)
post #7 of 7 (permalink) Old 08-25-2005, 04:14 PM
Hobohuey's Avatar
My tc was made in 86 (its an 87) and it has the seperate connector.
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
