Turbo Ranger - TCCoA Forums
post #1 of 16 (permalink) Old 09-14-2005, 02:28 PM Thread Starter
PJB
Turbo Ranger
Lately Ive been thinking about getting a '93-'95 Ford Ranger pickup with a 2.3 and converting it to a 2.3 turbo like in Turbo Coupe Thunderbirds. Im not looking at '96+ models because we have emissions testing on '96+ vehicles in NY so unless a turbo would pass the test the newer trucks are out of consideration.
Would I need the whole turbo motor or just parts off it? I dont know if theres a big difference internally.
Would the turbo just bolt right on to the exhaust of the regular 2.3?
If I need the whole motor will it work in a '93+ without too much modification and computer programming, etc?
Ive seen older style Rangers with turbo 2.3's in magazines but not a newer style one.
Id like to leave the truck looking stock but with some work under the hood as a sleeper.
Its only an idea now and I dont have a Ranger or a turbo 2.3.
PJB is offline
post #2 of 16 (permalink) Old 09-14-2005, 05:55 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
I looked into it before for my '93 Ranger 2.3L. IIRC, you would need to get a complete motor because the block is different. Also, I don't know if it would "bolt right in" or not. Pre-'93 2.3's have different motor mounts.
tinman_72 is offline
post #3 of 16 (permalink) Old 09-15-2005, 06:38 PM
Blue LS's Avatar
I know for my old 89 it would have been a drop in for the motor. But for yours I think you would have to fab up some mounts. And dont forget the wiring that goes with it. There was one running around before with the 2.3 turbo and man that thing could haul ***.
The N/A block wouldnt hold up to a turbo. The exhaust will not bolt up directly either from what I heard.
"She aint a Cadillac and she aint a Rolls, but there aint nothin wrong with the radio"
Of course everyone loves a hard worker, they do all the work!
90 LS - gone damn city drivers
93 Explorer XL 2dr 4x4 - totalled does anyone in that f*ckin city know how to drive
OK, that was twice in 6 months, red means STOP
Blue LS is offline
post #4 of 16 (permalink) Old 09-15-2005, 07:38 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
Why not just get an older one......cheaper, easier to mod, etc etc. Just be careful of rear frame rails.
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #5 of 16 (permalink) Old 09-15-2005, 08:26 PM
Who is John Galt?
Is the Ranger 2.3 a 2.3L OHC or a HSC?
"Won't work, can't be done"
cougar_guy04 is offline
post #6 of 16 (permalink) Old 09-15-2005, 08:42 PM
Blue LS's Avatar
2.3 OHC, the HSC was in the tempo and taurus
Blue LS is offline
post #7 of 16 (permalink) Old 09-15-2005, 09:32 PM
Who is John Galt?
Okay, that's what I thought, but wanted to double check.
post #8 of 16 (permalink) Old 09-16-2005, 12:05 AM Thread Starter
PJB
I like the newer style better. I suppose I could settle for an older one if I had to but theyre kinda hard to find in good shape around here.
If I did go with an older one what is different for the wiring?
PJB is offline
post #9 of 16 (permalink) Old 09-17-2005, 10:53 AM
TurboCoupe50's Avatar
AFAIK externally the 2.3 OHCs are identical, should be no problem installing a turbo 2.3 in place of a NA using the truck motor mounts. That said you'll need to do a lot of rewiring on the later models(DIS), whereas it ain't a big deal to modify the earlier harnesses to use the turbo VAM and extra sensors. Unfortunatly the '87-'88 TC harness is a nightmare due to the complexety of those models, and would be tough to swap into anything else(but it could be done).
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
[email protected] W/90hp shot.. [email protected]
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
post #10 of 16 (permalink) Old 09-18-2005, 07:07 AM
Hobohuey's Avatar
The whole motor will be needed. Not only is the block different but the head is different as well. The turbo motor also has forged internals as compaired to cast. I believe that ive heard about a couple of people installing a dis. It wouln't be hard in my opinion.
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #11 of 16 (permalink) Old 09-18-2005, 08:40 PM
x182dan's Avatar
Send a message via AIM to x182dan
i know of a guy with a 5spd ranger with the tc motor. As far as I know it has tc motor and tc rear not sure of tranny, if you have any questions let me know and I'll ask him for your
1995 Mustang GT(331stroker, trickflow heads, cam, intake, cobra seats, foose nitrous rims, 410s, etc)-your average slow sn95
2002 Ranger XLT(daily driver)
1994SC to 5.0 conversion(gone)
1990 SC-b&m shifter, SCP exhaust, ported exhaust manifolds, ported and polished heads, cold air intake, mark8 mafs(sold)
1989 Taurass SHO(sold)
x182dan is offline
post #12 of 16 (permalink) Old 10-06-2005, 10:55 PM
281_TBird's Avatar
What's an HSC motor?
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #13 of 16 (permalink) Old 10-07-2005, 12:23 PM
BogusSVO's Avatar
Send a message via AIM to BogusSVO Send a message via Yahoo to BogusSVO
Hey I have a 84 Turbo ranger, there light and quick, and the rear will not hook
83 TC engine and T5 with a volvo FMIC, battery and fuel cell in the bed
If ya run the T5 you'll have to fab up a tranny cross member,
I got lucky mine is a old USFA flight line truck so it came with a limited slip rear and front rear sway bars.
BogusSVO is offline
post #14 of 16 (permalink) Old 10-07-2005, 12:50 PM
Blue LS's Avatar
What's and HSC motor?
High Swirl Combustion (?) its the design of the head on the OHV 2.3s used in the tempo/topaz and taurus.
Blue LS is offline
post #15 of 16 (permalink) Old 10-07-2005, 01:23 PM
Traveler's Avatar
I saw a T-Bucket in a car show a few weeks ago. It was in a long line of other T-buckets. They all had Big or small block Fords or chevies. Some blown with a Roots blower, some fuel injected.... But ONE had a 2.3L Ford lifted straight up out of a Turbo Coupe. Engine, transmission, everything (Well, no A/C ) It looked good.
Point is; if it can be done to a T-bucket, I'm certain it wouldn't be difficult to do to a Ranger. I think its a great idea actually.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 16 (permalink) Old 10-08-2005, 01:15 PM
BogusSVO's Avatar
the HSC is a 2.3L pushrod engine, HSC stands for High Swril Combustion
they crack if you look at them sideways
BogusSVO is offline
