Fuel pump? - TCCoA Forums
post #1 of 11 (permalink) Old 09-28-2005, 05:44 PM Thread Starter
Pony Boy's Avatar
Send a message via AIM to Pony Boy
Fuel pump?
alright,how can you tell if a fuel pump is bad on an 87 turbo coupe.There is no fuel or pressure in the fuel rail,so I followed it back to the fuel filter.Gas will flow out of the line going into the filter,but not much gas will come out if the hose is hooked to the filter.I can hear the filter filling up with gas when I hook the fuel line back up but no gas comes out when it is hooked up.I can blow fuel through the filter with air,also,but how much of a restriction should there be.Also,shouldn't gasoline come pouring out of the fuel line going to the filter when you try to start the car?Or does the line have to be hooked up to the filter?So, what is wrong,fuel filter,or fuel pump? Thanks for any help
Pony Boy is offline
post #2 of 11 (permalink) Old 09-28-2005, 06:39 PM
BogusSVO's Avatar
Send a message via AIM to BogusSVO Send a message via Yahoo to BogusSVO
Do you hear the fuel pump "whirr" on when ya cycle the kea.
as for resting in the fuel filter on the fram ...almost none...inless its clogged
and check your fuel pump reset switch...in the trunk by the driver side tail light
unplugg it and see if it has started to melt
stock fuel presser should be 38-42
BogusSVO is offline
post #3 of 11 (permalink) Old 09-28-2005, 06:57 PM Thread Starter
Pony Boy's Avatar
Honestly,I'm not sure if I hear the pump turn on,but I don't think it does.I know what it sounds like on my 95 T-bird,and I don't hear it on the turbo coupe.The fuel pump is in the gas tank on these cars,correct?and I'll check the fuel pump reset,I couldn't find it earlier,thanks for your help!But anyway,if the fuel pump was working wouldn't gas squirt out of the line when the line is disconnected?
Pony Boy is offline
post #4 of 11 (permalink) Old 09-28-2005, 09:26 PM
No More BS
HotRod88LSC's Avatar
The Fuel pump Inertia switch is in the trunk directly behind the drivers side tail light, you have to pull some carpet back, Also ya might wanna check the fuel pump relay if it's stock it's OLD and time to replace it anyway.
1988 Lincoln Mark VII
Paxton Novi 1000 6psi kit, 30lb injectors 73mm C&L, MAF converted A3M, gt-40's, Felpro headgaskets, 1.7 Cobra RR's, typhoon intake,1 5/8 shorty headers, off road x-pipe, and full mandrel catback, electric fan, 3.73's, TKO 500, pro 5.0 shifter
372.4hp / 394.6tq 5psi
Rest in Peace Joel R. Bender.
July 30, 1979 - March 26, 2006
HotRod88LSC is offline
post #5 of 11 (permalink) Old 09-29-2005, 07:30 AM
BogusSVO's Avatar
he has a 87 tc, so he has a IRCM("J" box) up in the engine compartment, pass side fender in front of the shock tower.
BogusSVO is offline
post #6 of 11 (permalink) Old 09-29-2005, 08:42 AM Thread Starter
Pony Boy's Avatar
so, what does the j-box do?
Pony Boy is offline
post #7 of 11 (permalink) Old 09-29-2005, 10:30 AM
BogusSVO's Avatar
it is the relay box for the fans and fuel pump
BogusSVO is offline
post #8 of 11 (permalink) Old 09-29-2005, 02:04 PM
No More BS
Thats right you can snag one from the junkyard from another thunderbird, i have found that a taurus one works too
post #9 of 11 (permalink) Old 09-29-2005, 03:32 PM
BogusSVO's Avatar
Make sure it has the J on it, I thought they were all the same but wernt. I fried the ecu
BogusSVO is offline
post #10 of 11 (permalink) Old 09-29-2005, 04:52 PM Thread Starter
Pony Boy's Avatar
Alright everybody,Thanks a million for answering all my questions.I finally figured out that it was the fuel pump,so I'll see how it goes after a new fuel pump.Thanks for everyone's help!
Pony Boy is offline
post #11 of 11 (permalink) Old 09-30-2005, 07:34 AM
BogusSVO's Avatar
if you need a fuel pump, ya might as well call JDperformance....and get the 255lph pump
He was running a kit the fuel pump and Adj fuel press reg for about $160.00
Ill post the web addy later today for ya
BogusSVO is offline
