EGR Delete? - TCCoA Forums
post #1 of 4 (permalink) Old 10-05-2005, 06:55 PM Thread Starter
EGR Delete?
I have a Cougar XR7 turbo a few weeks ago I took the turbo out thinking that it was bad, after finding out it wasnt and replacing multipule parts I belive I fixed the problem (Fuel Pressure Reg) but upon putting the turbo back on the EGR emissions tube running from the EGR to the Exaust Manafold broke. I have tried a few fixes (High temp hose and welding a slightly larger pipe around) but it starts leaking almost immediatly every time. Ford has discontinued the part and I have had no luck at Junk yard or parts stores either. I heard that you can just plug off the manifold and take the pipe off with little adverse effect (worse fuel eccon being most major) is this true, and what do I need to purchase to make this happen? Or if anyone can tell me where to get one that would work also
iamshades78 is offline
post #2 of 4 (permalink) Old 10-06-2005, 07:07 AM
BogusSVO's Avatar
Send a message via AIM to BogusSVO Send a message via Yahoo to BogusSVO
think of the EGR like a built in fire exstinger(sp) if you plug it off on a street car you can get pre-det,Due to higher cyl head temps.
so get it fixed
If you cant find one let me know I think I have another one
BogusSVO is offline
post #3 of 4 (permalink) Old 10-06-2005, 10:31 AM Thread Starter
I drove 80 miles yesterday to go to a junck yard that said they had 3 and not a single one of them was usable, someone told me to use copper and build my own, but I would rather have one I know wont blow apart
post #4 of 4 (permalink) Old 10-20-2005, 09:50 AM
http://www.40bob.com/accessories.html, they have an egr block-off plate.
xturbocoupex is offline
