Idle Question - TCCoA Forums
post #1 of 3 (permalink) Old 11-09-2005, 10:01 AM Thread Starter
13's or Mildly Broken
Idle Question
There's a local Turbo Coupe guy who is having idle issues. In case it matters, it's an 88 5spd. He says the idle will go between 750 and 1250 RPM. Could this be a vac. leak somewhere? He wasn't exactly descriptive since he was leaving for work. He also said that after it's warm, it sometimes has trouble starting.
I don't know too much about it - We will talk again in a day or so and I'll get more info on it. Any leads on where to start would be appreciated.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #2 of 3 (permalink) Old 11-09-2005, 03:18 PM
Maybe it's a vacuum leak. How about checking his IAC? Or maybe the MAF (if the TC has an MAF).
Steve
S_Mazza is offline
post #3 of 3 (permalink) Old 11-13-2005, 06:54 PM
Thumbs up
Clean out the IAC Using brake cleaner or carb cleaner. Its a possibility that this could be the problem. If not, Usually a hunting idle condition is caused by a vac leak or the TPS being out of spec. Follow the directions in the link below to adjust the TPS and re-set the base Idle.
http://www.turbotbird.com/techinfo/I..._June2005.html
Shaihullud is offline
