88 Turbo Coupe Heat Issues - TCCoA Forums
post #1 of 5 (permalink) Old 01-21-2006, 07:52 PM Thread Starter
I have auto climate control in my TC. During normal driving, the heat works fine. Stopped at a light, within 30 seconds, the car starts blowing cold air into the car. I've replaced the heater core and heater control valve, along with the climate control head unit. Anyone have any ideas? Thanks.
eds88tc is offline
post #2 of 5 (permalink) Old 01-23-2006, 01:55 PM
Heat
Well try this , watch the temp. gage as you drive and then as you stop , does it drop in temp. or is it the same , that will let you know if its in the rad. or not . Is your cooling fan on the rad. running all the time . DW
Ballman is offline
post #3 of 5 (permalink) Old 02-01-2006, 05:48 PM
you might want to check the thermostat out or another question is whats your coolant look like, maybe it could stand changed. But if thats good i agree with the above post of the fan might not be coming on all the time. Hope these ideas help you out and good luck finding the problem.
Edgel is offline
post #4 of 5 (permalink) Old 02-05-2006, 08:14 PM
SLEEPER T-BIRD 87's Avatar
Send a message via AIM to SLEEPER T-BIRD 87 Send a message via Yahoo to SLEEPER T-BIRD 87
try replacing the sensor for the auto climate control it is in the heater hose.
1987 TURBO COUPE -- 429/c-6 .headers,motorsports cam,ported heads,750 holley,high rise intake,electric waterpump,big shot plate kit,much much more!!!!!!
new numbers coming soon!!!
1988 5.0 BIRD ------ BEATER
long tubes,2.5 h pipe hi flow cats,mac flowpath mufflers,h.o intake/throttlebody swap,underdrives,short belt, electric fan, etc.............................
SLEEPER T-BIRD 87 is offline
post #5 of 5 (permalink) Old 02-07-2006, 08:34 AM
Classic symptom of low coolent. Did you "Burp" the system after you changed all you did?
88 Thunderbird TC : Black, Full Griggs GR-40 Suspention, Gillis Valve set at 20 LBS, 2.5" cat back exhaust with flowmaster 50 series mufflers and 3" chrome tips. Leather, Sunroof, LOADED.
Shaihullud is offline
