Timing help - TCCoA Forums
post #1 of 2 (permalink) Old 04-15-2006, 08:21 PM Thread Starter
spetz01's Avatar
Exclamation Timing help
First of I'm timing a 93 Stang (girls) but I think they are similar to the Turbo Coupe I had.
It's a 2.3l and I just replaced the timing belt and I think it's a little off. Can anyone tell me the proper sequence here. I think it should have the crank key at 12 (top) and the cam at 6 (bottom) then install the belt. This is how it was on the 3.8l I just finished. Any help would be great.
1990 SC 5spd Black/Black Leather Magnum Powers III Conversion, 80mm TB, 76mm Maf, Mag cold air, Raised top, Mag Intake, BHJ Harmonic, Billet pullys, 15% OD, Kooks Mid-lenth headers, 255lph pump, 42# injectors, SPEC stage II clutch.http://www.cardomain.com/ride/2322222/1
2005 F-150 FX4 Crew, AIRAID, Hypertech, Straight pipes http://www.cardomain.com/ride/2322119/1
1963 Chevy II Station Wagon 327 300hp, 3 spd auto http://www.cardomain.com/ride/2253507
1963 Chevy II Two Door HT (gonna be meaner)
Is That your sister's Mustang?
spetz01 is offline
post #2 of 2 (permalink) Old 05-09-2006, 12:35 AM
Id hope by now you have it sorted out, but if you need help still, PM me.
Jeremy
CougarLS is offline
