LA2 vs LA3 Difference - TCCoA Forums
post #1 of 4 (permalink) Old 05-29-2006, 03:14 PM Thread Starter
Send a message via Yahoo to Jim Allen
Cool LA2 vs LA3 Difference
what is the difference between a 1987 TC LA2 and 1988 TC LA3
Jim Allen is offline
post #2 of 4 (permalink) Old 05-29-2006, 06:43 PM
Hobohuey's Avatar
The la2 will provide 15# of boost in premium mode in the first 2 gears. All the rest will be 10#.
The la3 will provide 15#of boost in all gears above 4,000 rpm in premium mode.
Its much easier to buy a gillus valve from boostvalve.com and take the bcs out.
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #3 of 4 (permalink) Old 05-31-2006, 05:25 PM
Hobohuey's Avatar
Assuming you have a stock 86 engine, you need an intercooler before you can increase boost. Anything over 10# will cause detionation and eventual engine failure. You will aso have to use premium fuel when boosting over 10#. (Someone else will have to chime in on the options on intercoolers since ive never had to deal with that problem and I dont want to misinform you.)
Stinger sells a nice front mount kit for $750 at stingerperformance.com. This kit does require you to change over to the SVO housing for the cool side of your turbo.
You can pick up a gillis valve at boostvalve.com for $50, it comes with detailed instructions on how to install the valve and the proper way to set it. I dont believe that the 83-86 tcs had the option of increasing boost, you were always limited to 10#.
Hobohuey is offline
post #4 of 4 (permalink) Old 06-01-2006, 06:26 AM
No More BS
HotRod88LSC's Avatar
10# from the factory yes,
Get an intercooler for it, no if ands or buts about it.
Add boost, add fuel, and pull timing HAVE FUN
1988 Lincoln Mark VII
Paxton Novi 1000 6psi kit, 30lb injectors 73mm C&L, MAF converted A3M, gt-40's, Felpro headgaskets, 1.7 Cobra RR's, typhoon intake,1 5/8 shorty headers, off road x-pipe, and full mandrel catback, electric fan, 3.73's, TKO 500, pro 5.0 shifter
372.4hp / 394.6tq 5psi
Rest in Peace Joel R. Bender.
July 30, 1979 - March 26, 2006
HotRod88LSC is offline
