Turbo Upgrade? - TCCoA Forums
post #1 of 20 (permalink) Old 03-07-2007, 10:20 AM Thread Starter
Send a message via Yahoo to GOTHALOSISM
Turbo Upgrade?
He all I just got a 88 t/c and was wondering what kind of a turbo upgrade can i do? I'm looking at around 250 or so horses nothing to major. I was thinking of a t3/t4 setup. Does any one know where to get some thing like that? of course I will be upgrading to the ranger cam and FMIC, headers and full exhaust.
Drive till it hurts...
88 T/C
78 Datsun 280z
79 Datsun 280zx
GOTHALOSISM is offline
post #2 of 20 (permalink) Old 03-07-2007, 06:08 PM
Chuck W's Avatar
Send a message via MSN to Chuck W Send a message via Yahoo to Chuck W
You can get 250hp out of std T3 (60/.63 or 60/.48) used on the rest of the EFI turbo Fords... No need for a hybrid
Chuck W is offline
post #3 of 20 (permalink) Old 03-08-2007, 05:01 PM Thread Starter
thats kool, any idea what car i can pull one off of at a junk yard?
88 T/C
78 Datsun 280z
79 Datsun 280zx
post #4 of 20 (permalink) Old 03-08-2007, 09:45 PM
the turbo already on your car should be able to support the power you want.
turbo86xr7 is offline
post #5 of 20 (permalink) Old 03-08-2007, 09:59 PM Thread Starter
Its An Ihi So How Should I Go About Upping It? I Don't Want To Push More Than 10psi Out Of It Until I Get The Cam And Exhaust.
88 T/C
78 Datsun 280z
79 Datsun 280zx
post #6 of 20 (permalink) Old 03-08-2007, 10:41 PM
twin turbo 281's Avatar
just build a forged bottom end before you turn up the pressure or youll be sorry
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #7 of 20 (permalink) Old 03-09-2007, 08:59 AM Thread Starter
thats what i thought. I'm really new to all of this ford stuff. I know Datsuns really well.
88 T/C
78 Datsun 280z
79 Datsun 280zx
post #8 of 20 (permalink) Old 03-10-2007, 02:38 AM
im actually not sure how much boost a tc 2.3 can take?
post #9 of 20 (permalink) Old 03-10-2007, 01:11 PM
PDL2MDL
krazy4's Avatar
the stock block is said to withstand about 400 hp.
So boost the crap out of it.
http://www.youtube.com/watch?v=oMjdto07tuk
LX w/ true duals, cutouts
cone filter
Bird is gone replaced by an LS1.
krazy4 is offline
post #10 of 20 (permalink) Old 03-10-2007, 04:45 PM
just have the fuel and timing dialed in right then and go for it!
post #11 of 20 (permalink) Old 03-11-2007, 01:22 PM Thread Starter
ok so save up for a mega squirt system!!!
88 T/C
78 Datsun 280z
79 Datsun 280zx
post #12 of 20 (permalink) Old 03-16-2007, 12:51 PM
I am running 17-18 PSI on my 87 TC just fine. I would guess that you can hit 250 HP with that turbo. If you want to get closer to 300, go with a T3 like the earlier turbo coupes had. The ranger cam isn't really necessary, but a good 3" exhaust system is.
Inspiribomb is offline
post #13 of 20 (permalink) Old 03-18-2007, 06:47 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
to crank up your boost go with a manual boost controller. If i remember from my 2.3 days that you can git about 18 pounds or so on stock injectors and pump before you start to get a fuel cutout going on. 3' is good but an overkill on stock ihi 2.5 duals works and looks great for these cars and keeps nice back pressure. also fmic is a must. get that ic away from that hot ass manifold. bob long makes some grear high flow logs for these things. check him out at www.40bob.com he also guts and rotates the upper intakes.
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #14 of 20 (permalink) Old 03-19-2007, 11:18 AM
Chuck W's Avatar
Originally Posted by ZeroRain View Post
3' is good but an overkill on stock ihi 2.5 duals works and looks great for these cars and keeps nice back pressure..
A 3' exhaust is definitely overkill, but a 3" is not.
"Back-pressure" on a turbo exhaust? Uh...no...you want as free-flowing as possible.
You do realize that 2 2-1/2" pipes flow more air than a single 3"...
So you pretty much say that a 3" exhaust is overkill, but then suggest a dual set-up that flows more but would provide "nice back pressure"..... Hrmmmm....
Check out Stinger Perf for exhaust parts.
The stock bottom end has forged pistons and is pretty stout. For your desired output it is MORE than adequate.
Your fuel system is fine for your expected power levels. You might think of a fuel pump upgrade (190-255lph) should you need to replace the stocker. Make sure your fuel filter has been replaced.
Chuck W is offline
post #15 of 20 (permalink) Old 03-19-2007, 01:50 PM
5oh Transformer
ZeroRain's Avatar
talk to the guys over at turbotbird.com if given the op many of them would go with a 2.5 dual instead of 3 single. says the car just looses its umph.
ZeroRain is offline
post #16 of 20 (permalink) Old 03-19-2007, 02:35 PM
Chuck W's Avatar
<---- Has been a member of NATO since the beginning......So I am one of the "guys" at turbotbird.com....
No...most guys go duals for the looks.... For most 2.3T applications under 350-400hp, you're not going to notice a difference between a single 3" vs a dual 2-1/2" system.
Chuck W is offline
post #17 of 20 (permalink) Old 03-20-2007, 10:15 AM
I agree with Chuck, the turbo presents enough backpressure, you want everything after that as open as possible. In addition to looks, a lot of guys go with the duals to get a deeper, more mellow exhaust sound. I love the sound (and performance) of my single 3" dump :-D
post #18 of 20 (permalink) Old 03-20-2007, 10:43 AM
Chuck W's Avatar
On mine I like the "period correct" look of the single twin tip.
I'm rebuilding the exhaust this spring with full single 3" system (custom turbo outlet). Still keeping the twin tip as well.
Inline engines don't sound right with dual mufflers. My old 2.3T Pace Car had a dual system from a previous owner...never was right to me. At least they put a 3" DP on it.
Chuck W is offline
post #19 of 20 (permalink) Old 03-22-2007, 08:33 PM
Hobohuey's Avatar
If I repeat something someone else has said, im sorry, but the conflicting info is confusing me a little.
The stock fuel system (Injectors, rail, FPR) is good for roughly 300 hp. Any higher then 18psi and you might want to start thinking about replacing the fuel pump. The stock bottom end can handle anything the IHI or the t-3 can throw at it. Crank up the boost with the gillis valve. http://www.boostvalve.com
Open the exhaust up!!! Weather you go duals or single here is up to you, just be sure that you include a 3" downpipe either way. You can even tell a difference just having a 3" dp on the factory exhaust. I went with a single 3" side-dump, I could feel an incredable power difference in the lower rpms because of the quicker spool. However, the smaller turbo does start to run out of steam at around 5K. Its just the nature of a small turbo. Even with the smaller turbo, I can roast the tires through 3 gears .
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #20 of 20 (permalink) Old 03-24-2007, 07:18 PM
PDL2MDL
krazy4's Avatar
If you do decide to go for more then 250hp then go for a holset, those things are badass.
cone filter
krazy4 is offline
