A Weird Turbo Setup - TCCoA Forums
post #1 of 6 (permalink) Old 03-10-2007, 11:09 AM Thread Starter
A Weird Turbo Setup
these are some pics of my old 83 thunderbird with a JYT twin turbo 5.0 setup.
tell me what you think.
http://voice.htmlplanet.com/twinturbotbird.htm
boss102371 is offline
post #2 of 6 (permalink) Old 03-10-2007, 12:36 PM
SuperNewbie
supergordo's Avatar
Looks like it would be fun to drive. Darn unique for sure.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #3 of 6 (permalink) Old 03-11-2007, 01:24 PM
Send a message via Yahoo to GOTHALOSISM
dang talk about a pipe dream
Drive till it hurts...
88 T/C
78 Datsun 280z
79 Datsun 280zx
GOTHALOSISM is offline
post #4 of 6 (permalink) Old 03-11-2007, 01:49 PM
Definitely looks unique. I do have a few questions/comments though:
How are you sealing the throttle shafts?
"stock fuel pump" Please tell me you're kidding!!
Are those marine exhaust manifolds, which are designed to be water cooled?
There's going to be a lot of heat awfully close to your brake cylinder.
Cylinders 1 and 2 are going to get heat soaked with the exhaust so close to the runners.
Any rubber hoses have to stay a good distance away from that exhaust/turbochargers.
Those short pieces of rubber hose on the oil feed lines might melt and rupture due to the heat.
I’m not trying to be harsh, but I see multiple things in those photos that are very dangerous and could easily cause a fire. Let alone not even run properly. I foresee a lean condition and a melted piston as being very possible. Keep in mind that exhaust system may get to the point where it is glowing red hot. Rubber just can’t handle that kind of heat so close to it.
I’m sure it is still a work in progress, but I think some more research is indicated.
Good luck!!
69 F100 LWB w/460 Engine
post #5 of 6 (permalink) Old 03-11-2007, 10:08 PM Thread Starter
well the car is gone but not from mechanical problems, it just went into a tree. I oil lines were not the best idea in the world but i use what i had. as for a lean problem... well it wasnt lean, it was a rich problem. real rich. it was fun while it lasted.
post #6 of 6 (permalink) Old 03-13-2007, 12:36 PM
rbrown's Avatar
That's too bad.
rbrown is offline
