2 top transmission bolts - TCCoA Forums
post #1 of 5 (permalink) Old 08-26-2007, 01:13 AM Thread Starter
one in a million
Nightstar's Avatar
Cool 2 top transmission bolts
What is the best way to break these 2 top bolts?
I finally dropped my trans, but those two bolts are a real pain to break loose...
and that was not all the starter was a little work unbolting the top bolt on it too and looks hard to change if I ever had to it looks like you have to drop the exhaust...
I also found a leaky freeze plug on the drivers side right behind the dipstick tube next to the motor mount... thats gonna be fun changing..
next job before winter is my heater core .....
ughh I'm gonna sale my car before anything else go's on it....
Nightstar is offline
post #2 of 5 (permalink) Old 08-26-2007, 07:57 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
If you remove the cowl/wiper assembly you have all kinds of room to put a breaker bar on them. It works for any kind of work that you have to do to the back of the motor too.
tinman_72 is offline
post #3 of 5 (permalink) Old 08-26-2007, 09:49 AM
95xbird's Avatar
The starter isn't really that bad.If you can get a very small ratchet and socket on there to crack it loose than you can get a nut driver on there and run it right off.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 5 (permalink) Old 08-26-2007, 10:15 AM
coggonobrien's Avatar
i just used a box end wrench and a 6 inch piece of pipe that would slide of the wrench for a cheater. worked from underneath the car. all came off easy
coggonobrien is offline
post #5 of 5 (permalink) Old 08-26-2007, 10:39 AM
ClintD's Avatar
^^^ This is the best whay that I've used also, but from the top.^^^
ClintD is offline
