1995 Vibration issues - TCCoA Forums
post #1 of 3 (permalink) Old 08-27-2007, 11:25 AM Thread Starter
I currently have my car about 20 inches in the air ready to attack. Here's my issue. I have a groan from the drivetrain (seems like). It's not noticable until over 65 then it progressively get's worse. If i'm going 100 and slow down I get this nasty shudder. I was thinking u-joints but they seem ok. I really don't want to drop the shaft unless I HAVE to. I do have a 93 1pc aluminum waiting to go in. All the bushings look intact. My steering wheel also moves left to right for no apparent reason but everything up front looks ok. Could a wheel bearing be to cause and just droning though the car?
I've done all the normal checks and everything seems ok. I'm about ready to drop this thing off a cliff or sell it soon if I can't figure this out. And getting smoked by a 93 S10 didn't help me either.
TheNoachSHO is offline
post #2 of 3 (permalink) Old 08-27-2007, 11:57 AM
jco1385's Avatar
check front camber bolts. tighten them to 105ft/lb. if you have a 1 pc aluminum shaft, why not go ahead and put it on. that way if it is u joints, problem fixed. if not it's one more thing off the list to check.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #3 of 3 (permalink) Old 08-27-2007, 03:11 PM
A worn out tie rod or ball joint could be the cause of the steering wheel movement. Also could be a bad tire.
Just throwing that out there.
Jay
FordMan77 is offline
