Transmission Bushing Installation Questions - TCCoA Forums
post #1 of 1 (permalink) Old 08-27-2007, 12:23 PM Thread Starter
I've got a set of the transmission crossmember bushings from spinningwheels-SC and I'm trying to figure out how to install them properly. First off, they come with metal shim inserts. Does this mean I should replace the bolts I took out that have the shims built in? The other important part is determining what direction I should put the two bushings & washer on either side. A simpel description or picture would be of great help.
FordofSin is offline
